Ich hatte heute einen kurzen Stromausfall. Nach dem reboot scheint der RPCServer irgend ein Problem zu haben.
Openhab und Hm-Manager können nicht mehr auf die Homematickomponenten zugreifen.
Error log:
03/11/16 18:51:07.720 RPC Server (Port 2001): Warning: RPC method not found: getAllScripts
03/11/16 18:51:07.729 RPC Server (Port 2001): Warning: RPC method not found: getAllScripts
03/11/16 18:51:17.522 Error: Server's address too short: binary://
03/11/16 18:51:17.523 Warning: Error calling XML RPC method "system.listMethods" on server binary:// with port 9125. Error struct:
03/11/16 18:51:17.523 Error: Server's address too short: binary://
03/11/16 18:51:17.523 Error calling XML RPC method "listDevices" on server binary:// with port 9125. Error struct:
03/11/16 18:56:17.544 Error: Server's address too short: binary://
03/11/16 18:56:17.544 Warning: Error calling XML RPC method "system.listMethods" on server binary:// with port 9125. Error struct:
03/11/16 18:56:17.545 Error: Server's address too short: binary://
03/11/16 18:56:17.545 Error calling XML RPC method "listDevices" on server binary:// with port 9125. Error struct:
03/11/16 18:57:17.573 Error: Server's address too short: binary://
03/11/16 18:57:17.574 Warning: Error calling XML RPC method "system.listMethods" on server binary:// with port 9125. Error struct:
03/11/16 18:57:17.574 Error: Server's address too short: binary://
03/11/16 18:57:17.574 Error calling XML RPC method "listDevices" on server binary:// with port 9125. Error struct:
Homegear log:
03/11/16 19:02:22.755 RPC Server (Port 2001): Info: Client number 17 is calling RPC method: listBidcosInterfaces Parameters:
03/11/16 19:02:37.761 RPC Server (Port 2001): Info: Client number 17 is calling RPC method: listBidcosInterfaces Parameters:
03/11/16 19:02:52.766 RPC Server (Port 2001): Info: Client number 17 is calling RPC method: listBidcosInterfaces Parameters:
03/11/16 19:03:07.739 RPC Server (Port 2001): Info: Client number 17 is calling RPC method: init Parameters:
(String) binary://:9125
03/11/16 19:03:07.745 RPC Server (Port 2001): Info: Client number 17 is calling RPC method: init Parameters:
(String) RF-b871e4d0
03/11/16 19:03:07.751 RPC Server (Port 2001): Info: Connection to client number 17 closed (3).
03/11/16 19:03:07.771 RPC Server (Port 2001): Info: Connection from 192.168.1.220:40181 accepted. Client number: 18
03/11/16 19:03:07.771 RPC Server (Port 2001): Info: Client number 18 is calling RPC method: listBidcosInterfaces Parameters:
03/11/16 19:03:17.746 Info: Calling XML RPC method "system.listMethods" on server binary:// and port 9125.
03/11/16 19:03:17.746 Error: Server's address too short: binary://
03/11/16 19:03:17.747 Warning: Error calling XML RPC method "system.listMethods" on server binary:// with port 9125. Error struct:
(Struct length=2)
[faultCode]
(Integer) -32700
[faultString]
(String) No response data.
03/11/16 19:03:17.747 Info: Calling XML RPC method "listDevices" on server binary:// and port 9125.
03/11/16 19:03:17.747 Error: Server's address too short: binary://
03/11/16 19:03:17.748 Error calling XML RPC method "listDevices" on server binary:// with port 9125. Error struct:
(Struct length=2)
[faultCode]
(Integer) -32700
[faultString]
03/11/16 19:03:22.775 RPC Server (Port 2001): Info: Client number 18 is calling RPC method: listBidcosInterfaces Parameters:
03/11/16 19:03:28.720 HomeMatic BidCoS packet received (My-COC, RSSI: 0x3F): 0CF1867025137600000000E22C
03/11/16 19:03:37.780 RPC Server (Port 2001): Info: Client number 18 is calling RPC method: listBidcosInterfaces Parameters:
Kann mir jemand weiterhelfen?
Beste Grüsse
Silvan
