Hallo, seit der Installation von Homegear meldet meine CCU3 ständig das in Programm nicht richtig läuft. Im Log gibt es jede Menge Fehler. Beim Versuch der Deinstallation kommt auch eine Fehlermeldung.
Was kann ich tun ?
Hier ein Auszug aus dem logfile:
Sep 23 22:31:58 de.eq3.ccu.system.http.service.EnergyPriceController ERROR [vert.x-worker-thread-15] Can´t read the config file for the energy counter: /etc/config/energyPrice (No such file or directory)
Sep 23 22:32:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:20 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:25 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:30 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:35 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:40 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:45 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:50 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:32:55 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:33:00 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:33:05 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:33:10 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
Sep 23 22:33:15 de.eq3.ccu.bidcos.dispatcher.BidCosRpcDispatcher ERROR [Timer-2] Could not register Homegear_java
