Ich habe heute auf Version 0.6.0-103 umgestellt. Leider bekomme ich den MQTT Client nicht zum laufen. Als Broker ist mosquitto 1.4 installiert, andere Clients laufen problemlos, sowohl von localhost als auch von anderen Geräten im Netzwerk.
Im Homegear Logfile finden sich folgende EInträge:
04/05/15 16:49:09.312 Start listening for packets...
04/05/15 16:49:09.723 Initializing RPC client...
04/05/15 16:49:09.724 Starting MQTT client...
04/05/15 16:49:09.724 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/05/15 16:49:09.733 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/05/15 16:49:11.573 Could not publish message, because we are not connected to a message broker. Topic: homegear/1234-5678-9abc/event/0/-1/HUMIDITY_BAD_OLD Data: [34.000000000000000]
Der Client wird also gestartet, jedoch kann ich bei mosquitto keinen Verbindungsversuch feststellen.
Meine mttq.conf sieht wie folgt aus (für den brokerHostname habe ich ebenfalls localhost und die LAN-IP ausprobiert):
[code]
mqtt.conf
MQTT settings.
Set this to “true” to enable MQTT.
Default: false
enabled = true
Hostname or IP address of your MQTT message broker.
brokerHostname = 127.0.0.1
Port of your MQTT message broker.
brokerPort = 1883
Name of this client.
clientName = Homegear
Unique ID of this Homegear instance. Change this, have you have multiple
Homegear installations.
homegearId = 1234-5678-9abc
When authentication by username and password is enabled, uncomment the
following two lines.
#userName = myUser
#password = myPassword
TLS options
Set to “true” to enable SSL encryption for MQTT.
enableSSL = false
The path to the certificate authority’s certificate
#caFile = /path/to/ca-certficate
verifyCertificate checks if the server certificate received by the
MQTT broker is signed by one of the root CAs in /etc/ssl/certs. If you use
a self signed certificate, please put your root certificate in that
directory. Only disable the verification for testing purposes. Without
verification any attacker can pose as your MQTT broker.
Default: verifyCertificate = true
#verifyCertificate = true
The path to the PEM encoded client certificate.
#certPath = /etc/homegear/mqtt.crt
The path to the PEM encoded client keyfile.
#keyPath = /etc/homegear/mqtt.key[/code]
Hat jemand einen Tipp für mich, wo es klemmt?
