Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception
HI
ich habe eine raspi 3 mit Jessi.
Darauf laeuft im Wesentlichen openhab mit homegear mit einem SCC.
Keine weiteren cpu lastigen server Activitaeten.
seit einiger Zeit bekomme ich folgende Meldung:
01/24/17 06:25:32.100 Info: Backing up database...
01/26/17 06:25:31.651 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
01/27/17 06:25:39.907 Info: Backing up database...
01/27/17 09:38:18.018 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
01/27/17 09:38:18.113 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
01/27/17 09:38:18.206 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
parallel seh ich im openhab log:
2017-01-27 06:25:11.337 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 06:25:14.340 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 09:32:08.337 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 09:32:08.343 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 09:32:13.353 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 09:32:14.347 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1b5015e' takes more than 5000ms.
2017-01-27 09:32:41.340 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
2017-01-27 09:38:26.337 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@8d094d' takes more than 5000ms.
die cpu last is immer im untern 10% Bereich, memory und swap sind 60% und 100% frei.
soweit seh ich keine Beeintraechtigung. es ist halt verwunderlich und sollte doch eigentlich nicht sein?
hat jemand eine idee wie man weiter debugen kann?
vielen Dank
Jipp
Hallo @Jipp,
kannst du mir den Ausschnitt aus der homegear.log dazu posten?
Hi
danke für die Rückmeldung.
ich habe inzwischen eine Freiwillige Änderung vorgenommen.
vorher nutzte ich /dev/ttyS0. Die Meldungen habe ich damit beobachtet.
Nach nochmaligem Studium der Doku hab ich mich entschieden /dev/ttyAMA0 zu nutzen und dementsprechend die Config umgestellt.
Danach sah ich die Meldungen nicht mehr.
nach weiteren 4 Tagen ist mein Raspi 3 gecrashed und liess sich nicht mehr wieder beleben.
Die Logs sind wahrscheinlich noch auf der SD karte, ich komme nur leider zur Zeit nicht an sie ran.
sobald ich die logs habe werd ich sie posten
Hi
Sieht so aus als ob die SD Karte den Geist aufgab. Also leider keine Logs.
tut mir leid
Hallo @jipp,
Schade… Bezüglich SD-Karte kaputt: Das neue Homegear-Image hat jetzt ein Readonly-Dateisystem. Damit sollten die SD-Karten jetzt viele Jahre halten (kalkuliert mit nur Homegear bezogen auf die Schreibvorgänge weit über 20).
