it’s a little bit mysterious…
I’m using 0.8.0-3128 and I have added the “function” blocks to the device definitions, for BC-RT-TRX-CyG, BC-TC-C-WM-4 and BC-RT-TRX-CyN. But it’s like as I even did not change anything…
- Channel 1 and all Parms are missing
- Channel 2 is there and empty
I will try an update to 0.8.0-3169 on Raspian Buster (it’s only 1 version newer then 3128) to have a look. But I would like to take an image of the SD-Card before
Just wait and see.
If 3169 should work fine (I pray and hope). Then a dev should be able to find the bug within the diff.
