MAX packet received - mehrfach?
Hi @bigcookie,
there’s a problem with the autocompilation at the moment. I just triggered a Stretch build manually. Was amd64 correct?
Cheers,
Hi, yes, it is amd64… Thanks for your help! I will need for the docker image to be updated as well as the nightly installation script doesnt work in the docker image when manually triggered.
I checked the latest nightly: 0.8.0-2832
Negative:
The devices still blink 3 times, which means that the ack seems not to be received as desired
Positive:
The Eco-button press is only recognized once instead of 3 times. This means, I can use that button now for triggering actions. Previously it was received multiple times based on one button press.
So overall: this helps a lot. Thanks so much. I will check later on if I can easily move to USB mode, but as I am running on a docker host, it might not be easily possible due to its capabities (QNAP TS-653B).
Best regards,
Bigcookie
P.S: Let me know if I can help with more testing.
