Moin Moin,
habe mir wie folgt einen Dockercontainer in meinem System angelegt:
docker-compose:
homegear:
container_name: Homegear
image: homegear/homegear:stable
restart: always
ports:
- 2001-2003:2001-2003
volumes:
- ./Homegear/etc:/etc/homegear:Z
- ./Homegear/lib:/var/lib/homegear:Z
- ./Homegear/log:/var/log/homegear:Z
environment:
- HOST_USER_ID=1000
- HOST_USER_GID=1000
- TZ=Europe/Berlin
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
networks:
- dd-network
Der Container läuft auch soweit. Die Einstellungen in der “homematicbidcos.conf” sind folgende:
[CUL]
id = My-CUL
deviceType = cul
device = /dev/ttyUSB0
responseDelay = 95
Wenn ich jetzt in die console gehe und homegear -r / fs 0 / pon aktiviere wird irgendwie nix über den CUL gesendet oder empfangen ?!
08/27/20 18:24:10.368 IPC Server: Debug: CLI client 4 is executing family command: pon
08/27/20 18:24:10.372 IPC Server: Response:
(String) Pairing mode enabled for 60 seconds.
08/27/20 18:24:10.523 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
08/27/20 18:24:10.625 UPnP Server: Debug: Sending notify packets.
08/27/20 18:24:10.625 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
08/27/20 18:24:10.646 UPnP Server: Debug: Sleeping 1298ms before sending response.
08/27/20 18:24:11.944 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
08/27/20 18:24:12.045 UPnP Server: Debug: Sending notify packets.
08/27/20 18:24:12.046 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
08/27/20 18:24:12.066 UPnP Server: Debug: Sleeping 22ms before sending response.
08/27/20 18:24:12.088 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
08/27/20 18:24:12.189 UPnP Server: Debug: Sending notify packets.
08/27/20 18:24:12.190 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
08/27/20 18:24:12.210 UPnP Server: Debug: Sleeping 312ms before sending response.
08/27/20 18:24:12.523 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
08/27/20 18:24:12.623 UPnP Server: Debug: Sending notify packets.
08/27/20 18:24:16.516 Debug: SSDP server: Binding to address: 172.18.0.3
08/27/20 18:24:16.516 Debug: Searching for SSDP devices ...
Welches Problem könnte es sein ? und wie debugge ich das ganze am Ende ?
vielen Dank schonmal für eure Hilfe !!
