nach einem Stromausfall funktioniert die Verbindung zwischen Homegear und meinem Homematic Funk LAN-Gateway nicht mehr. Ich habe bisher alle Pakete aktualisiert, RaspberryPi und LGW neu gestartet.
Logauszug:
06/21/15 17:39:28.954 Debug: Loading family modules
06/21/15 17:39:28.955 Info: Loading family module mod_homematicwired.so
06/21/15 17:39:29.082 Module HomeMatic Wired: Debug: Loading module...
06/21/15 17:39:29.091 Info: Loading family module mod_insteon.so
06/21/15 17:39:29.179 Module INSTEON: Debug: Loading module...
06/21/15 17:39:29.179 Info: Loading family module mod_max.so
06/21/15 17:39:29.241 Module MAX: Debug: Loading module...
06/21/15 17:39:29.241 Info: Loading family module mod_miscellaneous.so
06/21/15 17:39:29.266 Module Miscellaneous: Debug: Loading module...
06/21/15 17:39:29.266 Info: Loading family module mod_philipshue.so
06/21/15 17:39:29.298 Module Philips hue: Debug: Loading module...
06/21/15 17:39:29.299 Info: Loading family module mod_homematicbidcos.so
06/21/15 17:39:29.350 Module HomeMatic BidCoS: Debug: Loading module...
06/21/15 17:39:29.569 Debug: Reading config for physical device family HomeMatic BidCoS
06/21/15 17:39:29.570 Debug: id of family HomeMatic BidCoS set to My-HM-LGW
06/21/15 17:39:29.570 Debug: default of family HomeMatic BidCoS set to 1
06/21/15 17:39:29.570 Debug: deviceType of family HomeMatic BidCoS set to hmlgw
06/21/15 17:39:29.571 Debug: Host of family HomeMatic BidCoS set to 192.168.4.3
06/21/15 17:39:29.571 Debug: Port of family HomeMatic BidCoS set to 2000
06/21/15 17:39:29.571 Debug: PortKeepAlive of family HomeMatic BidCoS set to 2001
06/21/15 17:39:29.572 Debug: LANKey of family HomeMatic BidCoS set to g5mbAWGA*H
06/21/15 17:39:29.572 Debug: RFKey of family HomeMatic BidCoS set to 411aaeda430967210fcf074cabe35e76
06/21/15 17:39:29.572 Debug: CurrentRFKeyIndex of family HomeMatic BidCoS set to 1
06/21/15 17:39:29.573 Module HomeMatic BidCoS: Debug: Creating physical device. Type defined in physicalinterfaces.conf is: hmlgw
06/21/15 17:39:29.575 Initializing database...
06/21/15 17:39:29.595 Initializing family controller...
06/21/15 17:39:29.596 Module HomeMatic BidCoS: Loading XML RPC devices...
06/21/15 17:39:29.597 Loading XML RPC device /etc/homegear/devices/0/rf_4dis.xml
06/21/15 17:39:29.611 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644.xml
06/21/15 17:39:29.648 Loading XML RPC device /etc/homegear/devices/0/rf_s550ia.xml
06/21/15 17:39:29.653 Loading XML RPC device /etc/homegear/devices/0/rf_sc.xml
06/21/15 17:39:29.662 Loading XML RPC device /etc/homegear/devices/0/rf_tc_it_wm-w-eu.xml
06/21/15 17:39:29.825 Loading XML RPC device /etc/homegear/devices/0/rf_ash550.xml
06/21/15 17:39:29.830 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644.xml
06/21/15 17:39:29.867 Loading XML RPC device /etc/homegear/devices/0/rf_roto_wdf_solar.xml
06/21/15 17:39:29.913 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v1_5.xml
06/21/15 17:39:29.929 Loading XML RPC device /etc/homegear/devices/0/rf_rc-key4-2.xml
06/21/15 17:39:29.940 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644.xml
06/21/15 17:39:29.980 Loading XML RPC device /etc/homegear/devices/0/rf_rc_12.xml
06/21/15 17:39:29.990 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644_le_v2_4.xml
06/21/15 17:39:30.027 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_wm55.xml
06/21/15 17:39:30.042 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm.xml
06/21/15 17:39:30.050 Loading XML RPC device /etc/homegear/devices/0/rf_sc_e_v1_7.xml
06/21/15 17:39:30.059 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_1.xml
06/21/15 17:39:30.089 Loading XML RPC device /etc/homegear/devices/0/rf_cf.xml
06/21/15 17:39:30.120 Loading XML RPC device /etc/homegear/devices/0/rf_rc_single_on.xml
06/21/15 17:39:30.129 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sfa.xml
06/21/15 17:39:30.153 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644_le_v2_4.xml
06/21/15 17:39:30.189 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_1.xml
06/21/15 17:39:30.198 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644.xml
06/21/15 17:39:30.237 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-2.xml
06/21/15 17:39:30.247 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_0.xml
06/21/15 17:39:30.276 Loading XML RPC device /etc/homegear/devices/0/rf_cc_vd.xml
06/21/15 17:39:30.281 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644_le_v2_4.xml
06/21/15 17:39:30.319 Loading XML RPC device /etc/homegear/devices/0/rf_bl_le_v2_3.xml
06/21/15 17:39:30.348 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc_le_v1_9.xml
06/21/15 17:39:30.438 Loading XML RPC device /etc/homegear/devices/0/rf_cm.xml
06/21/15 17:39:30.458 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644_le_v2_4.xml
06/21/15 17:39:30.496 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_e_v1_7.xml
06/21/15 17:39:30.506 Loading XML RPC device /etc/homegear/devices/0/rf_bl.xml
06/21/15 17:39:30.536 Loading XML RPC device /etc/homegear/devices/0/rf_rd_le_v1_3.xml
06/21/15 17:39:30.547 Loading XML RPC device /etc/homegear/devices/0/rf_bl_644.xml
06/21/15 17:39:30.577 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v2_3.xml
06/21/15 17:39:30.599 Loading XML RPC device /etc/homegear/devices/0/rf_swi.xml
06/21/15 17:39:30.606 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_v1_5.xml
06/21/15 17:39:30.615 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir_v1_5.xml
06/21/15 17:39:30.625 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_le_v1_6.xml
06/21/15 17:39:30.635 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t.xml
06/21/15 17:39:30.666 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_1.xml
06/21/15 17:39:30.686 Loading XML RPC device /etc/homegear/devices/0/rf_s_4_ba.xml
06/21/15 17:39:30.705 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_7.xml
06/21/15 17:39:30.733 Loading XML RPC device /etc/homegear/devices/0/rf_central.xml
06/21/15 17:39:30.738 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_9.xml
06/21/15 17:39:30.768 Loading XML RPC device /etc/homegear/devices/0/rf_rc.xml
06/21/15 17:39:30.778 Loading XML RPC device /etc/homegear/devices/0/rf_resc_win_pcb_sc.xml
06/21/15 17:39:30.817 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd.xml
06/21/15 17:39:30.825 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn_bom.xml
06/21/15 17:39:30.901 Loading XML RPC device /etc/homegear/devices/0/rf_em_8.xml
06/21/15 17:39:30.920 Loading XML RPC device /etc/homegear/devices/0/rf_ks550.xml
06/21/15 17:39:30.929 Loading XML RPC device /etc/homegear/devices/0/rf_cfm.xml
06/21/15 17:39:30.963 Loading XML RPC device /etc/homegear/devices/0/rf_rd.xml
06/21/15 17:39:30.975 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_schueco.xml
06/21/15 17:39:30.982 Loading XML RPC device /etc/homegear/devices/0/rf_pbi.xml
06/21/15 17:39:30.991 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw.xml
06/21/15 17:39:31.026 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644.xml
06/21/15 17:39:31.063 Loading XML RPC device /etc/homegear/devices/0/rf_ddc.xml
06/21/15 17:39:31.084 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644_le_v2_4.xml
06/21/15 17:39:31.120 Loading XML RPC device /etc/homegear/devices/0/rf_wds30_ot2.xml
06/21/15 17:39:31.128 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir.xml
06/21/15 17:39:31.138 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t_le_v1_9.xml
06/21/15 17:39:31.169 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_3.xml
06/21/15 17:39:31.190 Loading XML RPC device /etc/homegear/devices/0/rf_rhs.xml
06/21/15 17:39:31.229 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_le_v1_0.xml
06/21/15 17:39:31.238 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sco.xml
06/21/15 17:39:31.247 Loading XML RPC device /etc/homegear/devices/0/rf_s_mega168.xml
06/21/15 17:39:31.263 Loading XML RPC device /etc/homegear/devices/0/rf_rep.xml
06/21/15 17:39:31.312 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644.xml
06/21/15 17:39:31.342 Loading XML RPC device /etc/homegear/devices/0/rf_dis_wm55.xml
06/21/15 17:39:31.351 Loading XML RPC device /etc/homegear/devices/0/rf_sc_le_v1_6.xml
06/21/15 17:39:31.360 Loading XML RPC device /etc/homegear/devices/0/rf_sen_wa_od.xml
06/21/15 17:39:31.370 Loading XML RPC device /etc/homegear/devices/0/rf_d.xml
06/21/15 17:39:31.400 Loading XML RPC device /etc/homegear/devices/0/rf_s_ba.xml
06/21/15 17:39:31.420 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_le_v1_3.xml
06/21/15 17:39:31.429 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc.xml
06/21/15 17:39:31.523 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_ge_v1_1.xml
06/21/15 17:39:31.532 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644.xml
06/21/15 17:39:31.553 Loading XML RPC device /etc/homegear/devices/0/rf_rc_19.xml
06/21/15 17:39:31.577 Loading XML RPC device /etc/homegear/devices/0/rf_sen_ep.xml
06/21/15 17:39:31.585 Loading XML RPC device /etc/homegear/devices/0/rf_fs_ba.xml
06/21/15 17:39:31.604 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_0.xml
06/21/15 17:39:31.612 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2.xml
06/21/15 17:39:31.621 Loading XML RPC device /etc/homegear/devices/0/rf_scd_v1_0.xml
06/21/15 17:39:31.629 Loading XML RPC device /etc/homegear/devices/0/rf_keymatic.xml
06/21/15 17:39:31.645 Loading XML RPC device /etc/homegear/devices/0/rf_rc-sec4-2.xml
06/21/15 17:39:31.656 Loading XML RPC device /etc/homegear/devices/0/rf_ws550.xml
06/21/15 17:39:31.663 Loading XML RPC device /etc/homegear/devices/0/rf_s.xml
06/21/15 17:39:31.686 Loading XML RPC device /etc/homegear/devices/0/rf_tis_le_v1_0.xml
06/21/15 17:39:31.694 Loading XML RPC device /etc/homegear/devices/0/rf_s_644.xml
06/21/15 17:39:31.717 Loading XML RPC device /etc/homegear/devices/0/rf_sen_db.xml
06/21/15 17:39:31.726 Loading XML RPC device /etc/homegear/devices/0/rf_tis.xml
06/21/15 17:39:31.735 Loading XML RPC device /etc/homegear/devices/0/rf_winmatic.xml
06/21/15 17:39:31.756 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_ge_v1_4.xml
06/21/15 17:39:31.766 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn.xml
06/21/15 17:39:31.843 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644.xml
06/21/15 17:39:31.880 Loading XML RPC device /etc/homegear/devices/0/rf_wds40_th_i_2.xml
06/21/15 17:39:31.886 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw_le_v2_4.xml
06/21/15 17:39:31.918 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir.xml
06/21/15 17:39:31.928 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644_le_v2_4.xml
06/21/15 17:39:31.966 Loading XML RPC device /etc/homegear/devices/0/rf_s_8_ba.xml
06/21/15 17:39:31.986 Loading XML RPC device /etc/homegear/devices/0/rf_sci_3.xml
06/21/15 17:39:31.994 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
06/21/15 17:39:31.995 Info: Not initializing device family INSTEON, because no physical interface was found.
06/21/15 17:39:31.995 Info: Not initializing device family MAX!, because no physical interface was found.
06/21/15 17:39:31.995 Info: Not initializing device family Philips hue, because no physical interface was found.
06/21/15 17:39:31.996 Module Miscellaneous: Loading XML RPC devices...
06/21/15 17:39:31.996 Loading XML RPC device /etc/homegear/devices/254/Template.xml
06/21/15 17:39:32.000 Loading devices...
06/21/15 17:39:32.002 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 4
06/21/15 17:39:32.007 Module HomeMatic BidCoS: Loading peer 1
06/21/15 17:39:32.049 Debug: Could not set parameter LOWBAT on channel 0 for peer 1. Parameter does not exist.
06/21/15 17:39:32.050 Module HomeMatic BidCoS: Loading peer 2
06/21/15 17:39:32.092 Debug: Could not set parameter LOWBAT on channel 0 for peer 2. Parameter does not exist.
06/21/15 17:39:32.092 Module HomeMatic BidCoS: Loading peer 3
06/21/15 17:39:32.135 Debug: Could not set parameter LOWBAT on channel 0 for peer 3. Parameter does not exist.
06/21/15 17:39:32.136 Module HomeMatic BidCoS: Loading peer 4
06/21/15 17:39:32.182 Debug: Could not set parameter LOWBAT on channel 0 for peer 4. Parameter does not exist.
06/21/15 17:39:32.182 Module HomeMatic BidCoS: Loading peer 5
06/21/15 17:39:32.231 Debug: Could not set parameter LOWBAT on channel 0 for peer 5. Parameter does not exist.
06/21/15 17:39:32.232 Module HomeMatic BidCoS: Loading peer 6
06/21/15 17:39:32.277 Debug: Could not set parameter LOWBAT on channel 0 for peer 6. Parameter does not exist.
06/21/15 17:39:32.278 Module HomeMatic BidCoS: Loading peer 7
06/21/15 17:39:32.321 Debug: Could not set parameter LOWBAT on channel 0 for peer 7. Parameter does not exist.
06/21/15 17:39:32.321 Module HomeMatic BidCoS: Loading peer 8
06/21/15 17:39:32.365 Debug: Could not set parameter LOWBAT on channel 0 for peer 8. Parameter does not exist.
06/21/15 17:39:32.366 Module HomeMatic BidCoS: Loading peer 9
06/21/15 17:39:32.409 Debug: Could not set parameter LOWBAT on channel 0 for peer 9. Parameter does not exist.
06/21/15 17:39:32.410 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 5
06/21/15 17:39:32.419 Module Miscellaneous: Loading Miscellaneous device 3
06/21/15 17:39:32.421 Start listening for packets...
06/21/15 17:39:32.423 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Connecting to HM-LGW with hostname 192.168.4.3 on port 2000...
06/21/15 17:39:32.425 Initializing RPC client...
06/21/15 17:39:32.426 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
06/21/15 17:39:32.433 Debug: Calling getFileDescriptor...
06/21/15 17:39:32.433 Info: Connecting to host 192.168.4.3 on port 2001...
06/21/15 17:39:32.434 Debug: Calling getFileDescriptor...
06/21/15 17:39:32.435 Info: Connecting to host 192.168.4.3 on port 2000...
06/21/15 17:39:32.438 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
06/21/15 17:39:32.443 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
06/21/15 17:39:32.539 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentification enabled...
06/21/15 17:39:32.544 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
06/21/15 17:39:32.622 Starting CLI server...
06/21/15 17:39:32.623 Initializing event handler...
06/21/15 17:39:32.623 Loading events...
06/21/15 17:39:32.625 Startup complete.
06/21/15 17:39:32.626 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
06/21/15 17:40:02.433 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Error: No init packet received.
06/21/15 17:40:03.469 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Warning: Connection closed. Trying to reconnect...
06/21/15 17:40:03.470 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Connecting to HM-LGW with hostname 192.168.4.3 on port 2000...
06/21/15 17:40:03.471 Debug: Calling getFileDescriptor...
06/21/15 17:40:03.471 Info: Connecting to host 192.168.4.3 on port 2000...
06/21/15 17:40:33.490 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Error in file Modules/HomeMaticBidCoS/PhysicalInterfaces/HM-LGW.cpp line 1574 in function void BidCoS::HM_LGW::reconnect(): Connecting to server 192.168.4.3 on port 2000 timed out.
06/21/15 17:40:34.493 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Warning: Connection closed. Trying to reconnect...
06/21/15 17:40:34.495 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Connecting to HM-LGW with hostname 192.168.4.3 on port 2000...
06/21/15 17:40:34.497 Debug: Calling getFileDescriptor...
06/21/15 17:40:34.498 Info: Connecting to host 192.168.4.3 on port 2000...
Configauszug:
[code]root@raspberrypi:~# grep -v ‘#|Key|^$’ /etc/homegear/physicalinterfaces.conf
[HomeMaticBidCoS]
id = My-HM-LGW
deviceType = hmlgw
host = 192.168.4.3
port = 2000
portKeepAlive = 2001
----------------------------- HomeMatic Wired -----------------------------
--------------------------------- INSTEON ---------------------------------
---------------------------------- MAX! ----------------------------------
------------------------------- Philips hue -------------------------------
root@raspberrypi:~# [/code]
Momentan habe ich keine Ideen mehr. Any suggestions? Schönen Sonntag euch!
