Hallo zusammen
Nach dem Update von homegear auf die aktuelle Verion 0.6.0-1281 läuft das System jetzt wieder ohne Fehler.
Jedoch kann ich kein Gerät verbinden.
Das Error Log ist leer.
Und im Systemlog steht folgendes
04/15/16 17:39:33.756 RPC Server (Port 2001): Info: Client number 437 is calling RPC method: setInstallMode Parameters:
(Boolean) 1
04/15/16 17:39:33.756 Module HomeMatic BidCoS: Info: Pairing mode enabled.
04/15/16 17:39:33.759 RPC Server (Port 2001): Info: Client number 437 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:33.762 RPC Server (Port 2001): Info: Connection to client number 437 closed (3).
04/15/16 17:39:33.850 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57977 accepted. Client number: 438
04/15/16 17:39:33.850 RPC Server (Port 2001): Info: RPC server client id for client number 438 is: 424
04/15/16 17:39:33.851 RPC Server (Port 2001): Info: Client number 438 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:33.854 RPC Server (Port 2001): Info: Client number 438 is calling RPC method: getKeyMismatchDevice Parameters:
(Boolean) 1
04/15/16 17:39:33.857 RPC Server (Port 2001): Info: Connection to client number 438 closed (3).
04/15/16 17:39:36.868 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57982 accepted. Client number: 439
04/15/16 17:39:36.868 RPC Server (Port 2001): Info: RPC server client id for client number 439 is: 425
04/15/16 17:39:36.869 RPC Server (Port 2001): Info: Client number 439 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:36.879 RPC Server (Port 2001): Info: Connection to client number 439 closed (3).
04/15/16 17:39:36.949 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57988 accepted. Client number: 440
04/15/16 17:39:36.950 RPC Server (Port 2001): Info: RPC server client id for client number 440 is: 426
04/15/16 17:39:36.951 RPC Server (Port 2001): Info: Client number 440 is calling RPC method: getServiceMessages Parameters:
04/15/16 17:39:36.961 RPC Server (Port 2001): Info: Connection to client number 440 closed (3).
04/15/16 17:39:38.524 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57989 accepted. Client number: 441
04/15/16 17:39:38.531 RPC Server (Port 2001): Info: RPC server client id for client number 441 is: 427
04/15/16 17:39:38.533 RPC Server (Port 2001): Info: Client number 441 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:38.536 RPC Server (Port 2001): Info: Connection to client number 441 closed (3).
04/15/16 17:39:38.845 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57993 accepted. Client number: 442
04/15/16 17:39:38.846 RPC Server (Port 2001): Info: RPC server client id for client number 442 is: 428
04/15/16 17:39:38.847 RPC Server (Port 2001): Info: Client number 442 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:38.850 RPC Server (Port 2001): Info: Client number 442 is calling RPC method: getKeyMismatchDevice Parameters:
(Boolean) 1
04/15/16 17:39:38.853 RPC Server (Port 2001): Info: Connection to client number 442 closed (3).
04/15/16 17:39:41.838 RPC Server (Port 2001): Info: Connection from 192.168.1.251:57998 accepted. Client number: 443
04/15/16 17:39:41.839 RPC Server (Port 2001): Info: RPC server client id for client number 443 is: 429
04/15/16 17:39:41.840 RPC Server (Port 2001): Info: Client number 443 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:41.849 RPC Server (Port 2001): Info: Connection to client number 443 closed (3).
04/15/16 17:39:41.918 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58004 accepted. Client number: 444
04/15/16 17:39:41.919 RPC Server (Port 2001): Info: RPC server client id for client number 444 is: 430
04/15/16 17:39:41.920 RPC Server (Port 2001): Info: Client number 444 is calling RPC method: getServiceMessages Parameters:
04/15/16 17:39:41.929 RPC Server (Port 2001): Info: Connection to client number 444 closed (3).
04/15/16 17:39:43.524 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58005 accepted. Client number: 445
04/15/16 17:39:43.530 RPC Server (Port 2001): Info: RPC server client id for client number 445 is: 431
04/15/16 17:39:43.531 RPC Server (Port 2001): Info: Client number 445 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:43.534 RPC Server (Port 2001): Info: Connection to client number 445 closed (3).
04/15/16 17:39:43.850 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58009 accepted. Client number: 446
04/15/16 17:39:43.851 RPC Server (Port 2001): Info: RPC server client id for client number 446 is: 432
04/15/16 17:39:43.852 RPC Server (Port 2001): Info: Client number 446 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:43.854 RPC Server (Port 2001): Info: Client number 446 is calling RPC method: getKeyMismatchDevice Parameters:
(Boolean) 1
04/15/16 17:39:43.857 RPC Server (Port 2001): Info: Connection to client number 446 closed (3).
04/15/16 17:39:46.850 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58016 accepted. Client number: 447
04/15/16 17:39:46.851 RPC Server (Port 2001): Info: RPC server client id for client number 447 is: 433
04/15/16 17:39:46.852 RPC Server (Port 2001): Info: Client number 447 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:46.861 RPC Server (Port 2001): Info: Connection to client number 447 closed (3).
04/15/16 17:39:46.956 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58020 accepted. Client number: 448
04/15/16 17:39:46.957 RPC Server (Port 2001): Info: RPC server client id for client number 448 is: 434
04/15/16 17:39:46.958 RPC Server (Port 2001): Info: Client number 448 is calling RPC method: getServiceMessages Parameters:
04/15/16 17:39:46.967 RPC Server (Port 2001): Info: Connection to client number 448 closed (3).
04/15/16 17:39:48.524 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58021 accepted. Client number: 449
04/15/16 17:39:48.525 RPC Server (Port 2001): Info: RPC server client id for client number 449 is: 435
04/15/16 17:39:48.531 RPC Server (Port 2001): Info: Client number 449 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:48.534 RPC Server (Port 2001): Info: Connection to client number 449 closed (3).
04/15/16 17:39:48.840 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58025 accepted. Client number: 450
04/15/16 17:39:48.841 RPC Server (Port 2001): Info: RPC server client id for client number 450 is: 436
04/15/16 17:39:48.842 RPC Server (Port 2001): Info: Client number 450 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:48.845 RPC Server (Port 2001): Info: Client number 450 is calling RPC method: getKeyMismatchDevice Parameters:
(Boolean) 1
04/15/16 17:39:48.848 RPC Server (Port 2001): Info: Connection to client number 450 closed (3).
04/15/16 17:39:51.888 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58033 accepted. Client number: 451
04/15/16 17:39:51.889 RPC Server (Port 2001): Info: RPC server client id for client number 451 is: 437
04/15/16 17:39:51.890 RPC Server (Port 2001): Info: Client number 451 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:51.899 RPC Server (Port 2001): Info: Connection to client number 451 closed (3).
04/15/16 17:39:51.962 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58037 accepted. Client number: 452
04/15/16 17:39:51.962 RPC Server (Port 2001): Info: RPC server client id for client number 452 is: 438
04/15/16 17:39:51.964 RPC Server (Port 2001): Info: Client number 452 is calling RPC method: getServiceMessages Parameters:
04/15/16 17:39:51.973 RPC Server (Port 2001): Info: Connection to client number 452 closed (3).
04/15/16 17:39:53.524 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58038 accepted. Client number: 453
04/15/16 17:39:53.530 RPC Server (Port 2001): Info: RPC server client id for client number 453 is: 439
04/15/16 17:39:53.531 RPC Server (Port 2001): Info: Client number 453 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:53.534 RPC Server (Port 2001): Info: Connection to client number 453 closed (3).
04/15/16 17:39:53.848 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58042 accepted. Client number: 454
04/15/16 17:39:53.849 RPC Server (Port 2001): Info: RPC server client id for client number 454 is: 440
04/15/16 17:39:53.850 RPC Server (Port 2001): Info: Client number 454 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:53.853 RPC Server (Port 2001): Info: Client number 454 is calling RPC method: getKeyMismatchDevice Parameters:
(Boolean) 1
04/15/16 17:39:53.855 RPC Server (Port 2001): Info: Connection to client number 454 closed (3).
04/15/16 17:39:56.856 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58049 accepted. Client number: 455
04/15/16 17:39:56.857 RPC Server (Port 2001): Info: RPC server client id for client number 455 is: 441
04/15/16 17:39:56.858 RPC Server (Port 2001): Info: Client number 455 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:56.868 RPC Server (Port 2001): Info: Connection to client number 455 closed (3).
04/15/16 17:39:56.933 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58053 accepted. Client number: 456
04/15/16 17:39:56.934 RPC Server (Port 2001): Info: RPC server client id for client number 456 is: 442
04/15/16 17:39:56.935 RPC Server (Port 2001): Info: Client number 456 is calling RPC method: getServiceMessages Parameters:
04/15/16 17:39:56.944 RPC Server (Port 2001): Info: Connection to client number 456 closed (3).
04/15/16 17:39:58.390 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58060 accepted. Client number: 457
04/15/16 17:39:58.391 RPC Server (Port 2001): Info: RPC server client id for client number 457 is: 443
04/15/16 17:39:58.392 RPC Server (Port 2001): Info: Client number 457 is calling RPC method: setInstallMode Parameters:
(Boolean) 0
04/15/16 17:39:58.423 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58061 accepted. Client number: 458
04/15/16 17:39:58.424 RPC Server (Port 2001): Info: RPC server client id for client number 458 is: 444
04/15/16 17:39:58.425 RPC Server (Port 2001): Info: Client number 458 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:58.428 RPC Server (Port 2001): Info: Client number 458 is calling RPC method: listDevices Parameters:
(Boolean) 0
04/15/16 17:39:58.437 RPC Server (Port 2001): Info: Connection to client number 458 closed (3).
04/15/16 17:39:58.515 Module HomeMatic BidCoS: Info: Pairing mode disabled.
04/15/16 17:39:58.518 RPC Server (Port 2001): Info: Client number 457 is calling RPC method: getInstallMode Parameters:
04/15/16 17:39:58.521 RPC Server (Port 2001): Info: Connection to client number 457 closed (3).
04/15/16 17:39:58.525 RPC Server (Port 2001): Info: Connection from 192.168.1.251:58062 accepted. Client number: 459
04/15/16 17:39:58.526 RPC Server (Port 2001): Info: RPC server client id for client number 459 is: 445
04/15/16 17:39:58.527 RPC Server (Port 2001): Info: Client number 459 is calling RPC method: listBidcosInterfaces Parameters:
04/15/16 17:39:58.530 RPC Server (Port 2001): Info: Connection to client number 459 closed (3).
Hat jemand eine Idee?
Beste Grüsse
Silvan
