Hi Sathya,
bin gerade dabei via Homegear “init” Methode einen eigenen RPC Server zu registrieren.
Ich habe allerdings so einige Probleme damit.
Hier ein kurzer Auszug aus dem Logfile. Vielleicht hilft das ja bei der Fehlersuche.
08/20/15 21:21:26.806 RPC Server (Port 2001): Info: Client number 6732 is calling RPC method: init Parameters:
(String) http://10.100.200.111:8080/homeautomation/jsonrpc
(String) RpcClient
(Integer) 16
08/20/15 21:21:30.406 HomeMatic BidCoS packet received (My-CC1101, RSSI: 0x48): 0CD08470306FDC00000000DF3E
08/20/15 21:21:30.408 Module HomeMatic BidCoS: Info: HUMIDITY on channel 1 of HomeMatic BidCoS peer 26 with serial number LEQ1214104 was set to 0x3E.
08/20/15 21:21:30.409 Module HomeMatic BidCoS: Info: TEMPERATURE on channel 1 of HomeMatic BidCoS peer 26 with serial number LEQ1214104 was set to 0x00DF.
08/20/15 21:21:36.631 RPC Server (Port 2001): Info: Connection to client number 6732 closed (3).
08/20/15 21:21:36.807 Info: Calling XML RPC method "system.listMethods" on server http://10.100.200.111 and port 8080.
08/20/15 21:21:36.807 Info: Connecting to host 10.100.200.111 on port 8080...
08/20/15 21:21:36.812 Info: Connected to host 10.100.200.111 on port 8080. Client number is: 6733
08/20/15 21:21:36.922 Error in file Modules/Base/Encoding/XMLRPCDecoder.cpp line 161 in function virtual std::shared_ptr<BaseLib::RPC::Variable> BaseLib::RPC::XMLRPCDecoder::decodeResponse(std::vector<char>&): expected <
08/20/15 21:21:36.923 Error in RPC response from 10.100.200.111 on port 8080: faultCode: -32700 faultString: Parse error. Not well formed: expected <
08/20/15 21:21:36.923 Warning: Error calling XML RPC method "system.listMethods" on server http://10.100.200.111 with port 8080. Error struct:
(Struct length=2)
[faultCode]
(Integer) -32700
[faultString]
(String) Parse error. Not well formed: expected <
@JsonRpcService("/jsonrpc")
public class RpcService
{ @JsonRpcMethod(“system.listMethods”)
public List listMethods()
List methodList = new ArrayList();
methodList.add(“system.listMethods”);
methodList.add(“event”);
methodList.add(“error”);
setz mal den Debuglevel auf 5, dann sehen wir die eigentlichen Pakete im Log. Aus irgendeinem Grund parsed Homegear die Pakete als XML. Damit JSONRPC funktioniert, muss folgendes gegeben sein:
[ul]
[li] Es muss in rpcservers.conf aktiviert sein.[/li]
[li] Das Paket muss per HTTP POST übertragen werden.[/li]
[li] “content-type” muss entweder “application/json” sein oder die Nutzlast muss mit “{” anfangen.[/li][/ul]
05/26/16 17:03:12.775 RPC client: Error in file RPC/RpcClient.cpp line 646 in function void RPC::RpcClient::sendRequest(RPC::RemoteRpcServer*, std::vector&, std::vector&, bool, bool&): Could not parse chunk size.
05/26/16 17:03:12.775 RPC client: Removing server. Server has to send “init” again.
[/code]
Und danach kam nichts mehr weil ja der Server removed wurde. Aber warum?
Irgendeine Idee?
EDIT: Mit KeepAlive Flag habe ich auch schon probiert. Klappt aber auch nicht stabil.
ich bin jetzt mal auf die folgende Version umgestiegen 0.6.3-1420
Im Anhang findest Du das aktuelle Log eines kompletten Neustarts von Homegear.
Als der Fehler wieder auftrat habe ich Homegear wieder gestoppt und das Logfile gezippt.
Die Java Sourcen kann ich Dir im Moment nicht zuschicken.
Dazu muesste ich erstmal was einfaches lauffaehiges basteln.
Aber vielleicht hilft Dir das LogFile ja auch..
Das JsonRpcServerLog File enthaelt die Ausgaben meines JsonRpc Servers.
ohne das Programm/den Quelltext ist es natürlich schwieriger . Aber probieren wir es mal. Leider hat Homegear das Antwort-Paket nicht gelogt. Das Logging habe ich jetzt auf Debuglevel 5 eingebaut. Im nächsten Nightly ist es drin. Kannst du mir das Log damit noch einmal schicken? Am besten per E-Mail, dann sehe ich es sofort.
Hi Sathya,
so ich habe jetzt endlich mal eine kleine Beispiel Applikation gebaut ( eclipse Project Java/Maven)
bei der die JsonRpc Kommunikation nach einer unterschiedlichen Anzahl Events immer abbricht.Vielleicht finden wir ja jetzt den Fehler?
Im Source müssen lediglich IP Adressen und Ports angepasst werden.
Bei Fragen einfach melden.
also, das Projekt verbindet sich erfolgreich mit Homegear. Viel weiter geht es dann aber nicht, weil kein Ereignisserver in der HomegearRpcServer.java gestartet wird? Magst du das schnell korrigieren, dann schaue ich noch einmal rein?
auf Anhieb bekomme ich es in einer Tomcat-Docker-Instanz nicht zum Laufen, obwohl ich soweit keine Fehlermeldung sehe - dazu sei gesagt, dass ich weder viel Erfahrung mit Java(-Entwicklung) noch Tomcat habe:
root@cd003b5d9673:/usr/local/tomcat# catalina.sh run
Using CATALINA_BASE: /usr/local/tomcat
Using CATALINA_HOME: /usr/local/tomcat
Using CATALINA_TMPDIR: /usr/local/tomcat/temp
Using JRE_HOME: /opt/jdk1.8.0_111/jre
Using CLASSPATH: /usr/local/tomcat/bin/bootstrap.jar:/usr/local/tomcat/bin/tomcat-juli.jar
27-Dec-2016 15:49:27.066 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.39
27-Dec-2016 15:49:27.069 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 9 2016 08:48:39 UTC
27-Dec-2016 15:49:27.069 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.39.0
27-Dec-2016 15:49:27.070 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
27-Dec-2016 15:49:27.070 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 4.4.0-36-generic
27-Dec-2016 15:49:27.070 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
27-Dec-2016 15:49:27.070 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/jdk1.8.0_111/jre
27-Dec-2016 15:49:27.071 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_111-b14
27-Dec-2016 15:49:27.071 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
27-Dec-2016 15:49:27.071 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /usr/local/tomcat
27-Dec-2016 15:49:27.071 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /usr/local/tomcat
27-Dec-2016 15:49:27.072 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
27-Dec-2016 15:49:27.073 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
27-Dec-2016 15:49:27.075 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=/usr/local/tomcat/endorsed
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/local/tomcat
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/local/tomcat
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/local/tomcat/temp
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library 1.2.10 using APR version 1.5.1.
27-Dec-2016 15:49:27.077 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
27-Dec-2016 15:49:27.082 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized (OpenSSL 1.1.0c 10 Nov 2016)
27-Dec-2016 15:49:27.186 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-apr-8080"]
27-Dec-2016 15:49:27.195 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-apr-8009"]
27-Dec-2016 15:49:27.196 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 359 ms
27-Dec-2016 15:49:27.213 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
27-Dec-2016 15:49:27.213 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.39
27-Dec-2016 15:49:27.233 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive /usr/local/tomcat/webapps/homeautomation.war
27-Dec-2016 15:49:28.131 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
0 [localhost-startStop-1] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
75 [localhost-startStop-1] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing Root WebApplicationContext: startup date [Tue Dec 27 15:49:28 UTC 2016]; root of context hierarchy
108 [localhost-startStop-1] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/spring/application-context.xml]
292 [localhost-startStop-1] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 291 ms
322 [localhost-startStop-1] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'dispatcher': initialization started
326 [localhost-startStop-1] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing WebApplicationContext for namespace 'dispatcher-servlet': startup date [Tue Dec 27 15:49:28 UTC 2016]; parent: Root WebApplicationContext
327 [localhost-startStop-1] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/spring/dispatcher-servlet.xml]
[localhost-startStop-1] INFO com.googlecode.jsonrpc4j.spring.AutoJsonRpcServiceImplExporter - exporting bean [de.drazil.homegear.controller.HomegearJsonRpcEventControllerImpl#0] ---> [/jsonrpc]
873 [localhost-startStop-1] INFO org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter - Looking for @ControllerAdvice: WebApplicationContext for namespace 'dispatcher-servlet': startup date [Tue Dec 27 15:49:28 UTC 2016]; parent: Root WebApplicationContext
913 [localhost-startStop-1] INFO org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter - Looking for @ControllerAdvice: WebApplicationContext for namespace 'dispatcher-servlet': startup date [Tue Dec 27 15:49:28 UTC 2016]; parent: Root WebApplicationContext
957 [localhost-startStop-1] INFO org.springframework.web.servlet.handler.BeanNameUrlHandlerMapping - Mapped URL path [/jsonrpc] onto handler '/jsonrpc'
967 [localhost-startStop-1] INFO org.springframework.web.servlet.handler.SimpleUrlHandlerMapping - Mapped URL path [/**] onto handler 'org.springframework.web.servlet.resource.DefaultServletHttpRequestHandler#0'
978 [localhost-startStop-1] INFO org.springframework.web.servlet.handler.SimpleUrlHandlerMapping - Mapped URL path [/js/**] onto handler 'org.springframework.web.servlet.resource.ResourceHttpRequestHandler#0'
1022 [localhost-startStop-1] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'dispatcher': initialization completed in 700 ms
27-Dec-2016 15:49:29.234 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive /usr/local/tomcat/webapps/homeautomation.war has finished in 2,002 ms
27-Dec-2016 15:49:29.235 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/local/tomcat/webapps/host-manager
27-Dec-2016 15:49:29.256 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/local/tomcat/webapps/host-manager has finished in 21 ms
27-Dec-2016 15:49:29.256 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/local/tomcat/webapps/examples
27-Dec-2016 15:49:29.363 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/local/tomcat/webapps/examples has finished in 106 ms
27-Dec-2016 15:49:29.363 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/local/tomcat/webapps/docs
27-Dec-2016 15:49:29.376 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/local/tomcat/webapps/docs has finished in 13 ms
27-Dec-2016 15:49:29.377 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/local/tomcat/webapps/ROOT
27-Dec-2016 15:49:29.390 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/local/tomcat/webapps/ROOT has finished in 13 ms
27-Dec-2016 15:49:29.390 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory /usr/local/tomcat/webapps/manager
27-Dec-2016 15:49:29.405 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory /usr/local/tomcat/webapps/manager has finished in 15 ms
27-Dec-2016 15:49:29.407 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-apr-8080"]
27-Dec-2016 15:49:29.413 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-apr-8009"]
27-Dec-2016 15:49:29.414 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 2217 ms
Vielleicht ist es einfacher, wenn du mir noch einmal deine Logausgabe mit einer aktuellen Homegearversion auf Debuglevel 5 sendest. Das sollte eigentlich Aufschluss geben, was schief läuft…
