first of all many thanks to the homegear-project. What an amazing work. I use it for HUE and MAX!
Absolutely noncritical software, runs on low hardware, very very fast. I like it!
Here is my problem:
i tried(many times, maybe one week) to reinstall homegear with modules on my raspberrypiw.
Fresh install with raspberry Pi OS buster, updated everything with apt update/update dist-upgrade.
bavaria, are you german?
I don’t have a clue. If you reinstall todays nightly it should run quite nicely.
Could you give us a dpkg -l | grep homegear, just to check?
If you try to install stable on rasbian buster via the apt repository, it installs 0.8.0-3101 and not 0.7.x.
Either this is intended, or somehow the nightly got pushed into the stable apt repository.
yes i am from bavaria.
Now i have installed the nightly and it works fine after the backup via admin-ui.
I do not know the reason why the nightly was pushed into the stable apt repository
The connection with openhab is also working fine, so no reason for me to dig deeper into this.
This issue should be fixed within the next nightly. It was caused by adding a nightly repository.
Andy, wenn dir englisch lieber ist, darfst du natürlich auch im englischen Forum schreiben
