Second question - why when I try to install Homegear from repositories using the main Homegear documentation is it trying (and failing) to install 0.8?
According to the Raspbian image download instructions, the latest stable version is 0.7 or is the Raspbian image slightly behind the current stable version of Homegear?
That is what I’m finding. It worked fine setting up a test system a couple of weeks ago and installed v 0.8.0-3085. Now I’m moving SD cards around and wanted to reinstall from scratch and it cannot find the packages now.
Not sure I want the nightly build. I’d rather have the stable version unless there’s something I need.
Is the stable 0.7.x version available anywhere? Or perhaps I should go Raspbian image
