Hi
Running the stable release on an raspberry pi.
Every time I run an update or do an initial install of homegear-homematicbidcos I get the following errors at the end:
chown: cannot access ‘/usr/share/homegear/firmware/.fw’: No such file or directory
chown: cannot access '/usr/share/homegear/firmware/.version’: No such file or directory
chmod: cannot access ‘/usr/share/homegear/firmware/.fw’: No such file or directory
chmod: cannot access '/usr/share/homegear/firmware/.version’: No such file or directory
I get the same errors when executing the GetFirmwareUpdatesHomeMaticBidCoS.sh manually and also the permissions are not set correct for *fw and *.version inside /usr/share/homegear/firmware.
I think this is because of the last line of the GetFirmwareUpdatesHomeMaticBidCoS.sh script:
chown homegear:homegear “$SCRIPTDIR/.fw"
chown homegear:homegear "$SCRIPTDIR/.version”
chmod 444 “$SCRIPTDIR/.fw"
chmod 444 "$SCRIPTDIR/.version”
removing the quotes removes the error messages and also the permissions will be set correct.
chown homegear:homegear $SCRIPTDIR/.fw
chown homegear:homegear $SCRIPTDIR/.version
chmod 444 $SCRIPTDIR/.fw
chmod 444 $SCRIPTDIR/.version
cheers
