is it possible to set the weekly program on a HM-CC-RT-DN or a HM-TC-IT-WM-W-EU with homegear?
Thanks,
Thomas.
Thanks,
Thomas.
This should be what your’re looking for
so yes, it’s possible.
In case the translator is not working (as for mie right now
) :GUIs für die Verwaltung von Homegear - #7 by Micha
But it’s only available within the nightly-package. If you’re using the stable package or docker image, this setting is not available since it’s a older version.
Btw: I’m using the docker/stable distribution and the button is available.
Thanks for the hint! I somehow managed to miss that big fat button several times …
But: It doesn’t quite work. I’ve loaded the configuration from the device, made it a global template via the GUI. When applying that template, it ‘flatlines’ (drops all points and makes a single line). The same happens, when creating configuration directly with the GUI.
I’ve now used the ‘ENDTIME_MONDAY_1’ etc configuration parameters.
