sobald ich die Action ausführe um den Jalousieaktor HMW-LC-Bl1-DR während des Verfahrens zu stoppen, erhalte ich folgende Fehlermeldung unter openhab:
2016-05-09 22:04:42.593 [ERROR] [.b.h.i.c.HomematicCommunicator] - -32500 Unknown application error. See error log for more details. (sending BinRpcRequest[methodName=setValue,args={MEQ1132625:3,STOP,true}])
org.openhab.binding.homematic.internal.communicator.client.HomematicClientException: -32500 Unknown application error. See error log for more details. (sending BinRpcRequest[methodName=setValue,args={MEQ1132625:3,STOP,true}])
Laut der Dokumentation muss der Kanaltyp ‘Blind’ mit dem Parameter ‘STOP’ gesetzt werden.
Meine Definition lautet:
Die Argumente scheinen für mich korrekt zu sein die gesendet werden.
Alle weiteren Parameter Working, Direction & Level funktionieren.
Restliche Fehlermeldung:
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:224) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.setDatapointValue(BinRpcClient.java:158) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.client.BaseHomematicClient.setDatapointValue(BaseHomematicClient.java:72) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicPublisher.sendToClient(HomematicPublisher.java:78) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicPublisher.execute(HomematicPublisher.java:65) ~[bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicCommunicator.publishToHomematicServer(HomematicCommunicator.java:317) [bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicCommunicator.receiveType(HomematicCommunicator.java:278) [bundlefile:na]
at org.openhab.binding.homematic.internal.communicator.HomematicCommunicator.receiveCommand(HomematicCommunicator.java:245) [bundlefile:na]
at org.openhab.binding.homematic.internal.bus.HomematicBinding.internalReceiveCommand(HomematicBinding.java:168) [bundlefile:na]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:97) [org.openhab.core_1.8.2.jar:na]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:42) [org.openhab.core_1.8.2.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39) [org.eclipse.equinox.event_1.2.200.v20120522-2049.jar:na]
at org.openhab.core.internal.events.EventPublisherImpl.sendCommand(EventPublisherImpl.java:56) [org.openhab.core_1.8.2.jar:na]
at org.openhab.model.script.actions.BusEvent.sendCommand(BusEvent.java:84) [org.openhab.model.script_1.8.2.jar:na]
at org.openhab.model.script.actions.BusEvent.sendCommand(BusEvent.java:65) [org.openhab.model.script_1.8.2.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) [org.openhab.model.script_1.8.2.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor42.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:333) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) [org.openhab.model.script_1.8.2.jar:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) [org.openhab.core.scriptengine_1.8.2.jar:na]
Caused by: java.io.IOException: -32500 Unknown application error. See error log for more details.
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:210) ~[bundlefile:na]
... 71 common frames omitted
