Homematic rollershutter loses pairing
Hi everybody,
I’m using the HM-MOD-RPI-PCB on my Raspberry to control a couple of Homematic rollershutter actors HM-LC-Bl1PBU-FM. Everything is working fine with out any problems.
One of the actors is loosing the pairing from time to time. I can pair the actor again without any problems. Then it’s working again for a couple of weeks. The actor is the one that is the closest to the HM-MOD-RPI-PCB (about 5 meters) so I don’t think signal strength is an issue.
Is there a way that I could troubleshoot this behaviour? Are there any logs I could check?
Thank for your support.
Martin
Hi @Marfi,
sorry for the late reply. So the device is still in Homegear, but does not respond until it is paired again? This sounds like a bug in the device.
Cheers,
Hi @Sathya, it turned out that one of wires slipped out of the actor. So it was a hardware issue.
Thanks anyway…
Regards
Martin
