Homematic Pairing & Using
Hi, I’m too new here and I want to use some homematic devices with opeanhab 2 and raspberry pi 3 model b+.
I installed openhabian to raspberry pi and I installed homematic bindings with homegear (homematic bidcos - homematic wired) to openhabian.
So, I want get help after this. What should I do for pairing with my homematic devices and how do I use them?
And my devices are HM-CFG-LAN, HM-Sec-MDIR-2, HM-Sec-SC-2.
Thanks.
Have a look here:
https://doc.homegear.eu/data/homegear-homematicbidcos/adding_devices.html
It doesn’t pairing. How do I fix?
Hm. Did you configure the homematicbidcos.conf according to the documenation?
https://doc.homegear.eu/data/homegear-homematicbidcos/configuration.html
What communication module are you using?
I changed centralAddress as 0xFDD394, #host as my device ip and #lanKey as my device aes key but I haven’t chanced rfKey. id = My-HM-CFG-LAN
I’m using HomeMatic LAN Configuration Adapter (HM-CFG-LAN) communication module.
Have you checked the logs (/var/log/homegear/homegear.log) at startup of homegear? Is there All physical devices are connected now printed?
Could you show the relevant configuration file parts?
Yes I checked logs and it printed and I sent my config.
(from pm)
[General]
The BidCoS address of Homegear. It is recommended to change this to a random 3 byte hexadecimal
value starting with 0xFD (e. g. 0xFD43AB). Only change this, when no HomeMatic BidCoS devices
are paired to Homegear as existing pairings will not work anymore!
#centralAddress = 0xFDD394
!!! IMPORTANT: It is highly recommended to change this key before pairing the first device.
To remove the key from your devices, you need to factory reset them using Homegear. The factory
reset on the device is not possible!!!
Please make yourself familar on how to edit config files. You have to “comment in” the centralAddress to make homegear recognize it - remove the # in front of the line.
ALSO please read the config. Don’t use the example rfKey as this has security liabilities.
This also applies for the communication module:
#[HM-CFG-LAN]
#id = My-HM-CFG-LAN
to new peers.
#default = true
Options: cul, cc1100, coc, cunx, hmcfglan, hmlgw, hm-mod-rpi-pcb, homegeargateway
#deviceType = hmcfglan
IP address of your HM-CFG-LAN
#host = 192.168.1.222
#port = 1000
#lanKey = A[...]3
Default: responseDelay = 95
#responseDelay = 60
You have to comment in the corresponding lines. Currently you don’t have any device configured.
Don’t forget to comment in the section (#[HM-CFG-LAN]).
After that, restart homegear with sudo service homegear restart and check the logs afterwards.
Hi again, I edited config files as you told.
And these my logs. What’s next :confused:
Hey @Tiffl3r,
could you please post the homematicbidcos.conf after you edited ist? Please only the relevant parts via copy & paste.
[General]
moduleEnabled = true
########## General Settings  ##########
[General]
The BidCoS address of Homegear. It is recommended to change this to a random 3 $
value starting with 0xFD (e. g. 0xFD43AB). Only change this, when no HomeMatic $
rfKey =11447788552233669900QWERTYUIOPAS
## incremented by 1
currentRfKeyIndex = 1
## old and the new one.
## risk.
[HM-CFG-LAN]
id = L...0
## When default is set to “true” Homegear will assign this device
## to new peers.
#default = true
port = 1000
lanKey = A...3
## Should be “95” for CUL or COC, “100” for TI CC1101 and “60” for HM-CFG-LAN or HM-LGW
responseDelay = 60
Looks good, have you tried pair a device again?
Yeah, a couple of times but I don’t know why it doesn’t work.
Hmm… All physicla devcies are connected now is still missing. Could you doublecheck your settings? (IP, etc.)
And maybe change the debuglevel to 4 in main.conf
I checked but it’s look normal. And debuglevel already seem 4.
Maybe device was corrupt, who knows.
Thanks anyway.
Hi @Tiffl3r
should be easy enough to solve. If it’s still relevant, could you post a log of the pairing process? (You can also copy the text content here - it’s easier to read than the screenshots.) Also is the rfKey your real one? Only letters from A to F and numbers from 0 to 9 are allowed (those are hexadecimal numbers). There should have been an error message in the log. I fixed that now.
Cheers,
