Homegear.service startet nicht
Hi there
I had homegear running on openhab for quite some time now. Including several challenges to get it back up and running whenever there was a new software release. Never change a running system. Well I know that…
Now it happened again. This time looks a bit different. ------->
The unit homegear.service has entered the ‘failed’ state with result ‘exit-code’.
Dec 16 17:59:38 openhabian systemd[1]: Failed to start homegear.service - Homegear.
Subject: A start job for unit homegear.service has failed
Defined-By: systemd
Support: ‘debian’
A start job for unit homegear.service has finished with a failure.
The job identifier is 735 and the job result is failed.
Dec 16 18:08:23 openhabian systemd[1]: Starting homegear.service - Homegear…
Subject: A start job for unit homegear.service has begun execution
Defined-By: systemd
Support: ‘debian’
A start job for unit homegear.service has begun execution.
The job identifier is 883.
Dec 16 18:08:27 openhabian rpi_init[4009]: /usr/local/sbin/rpi_init: line 5: /usr/bin/gpio: No such file or directory
Dec 16 18:08:27 openhabian systemd[1]: homegear.service: Control process exited, code=exited, status=127/n/a
Subject: Unit process exited
Defined-By: systemd
Support: debian
An ExecStartPre= process belonging to unit homegear.service has exited.
The process’ exit code is ‘exited’ and its exit status is 127.
Dec 16 18:08:27 openhabian systemd[1]: homegear.service: Failed with result ‘exit-code’.
Subject: Unit failed
Defined-By: systemd
Support: debian
Dec 16 18:08:27 openhabian systemd[1]: Failed to start homegear.service - Homegear.
Defined-By: systemd
Support: debian
The job identifier is 883 and the job result is failed.
Anyone an idea what’s going on here?
Zusammenfassung
Dieser Text wird ausgeblendet
Hi @Lehmann22 ,
i can only guess, i’m really new to Homegear, it looks to be an issue with your permissions or other services which are using the GPIO.
Did you have checked the Homegear log, during the startup?
sudo tail -f /var/log/homegear/homegear.log
Best regards
Jannis
