Hallo Sathya,
ich habe bei einem Freund eine ähnliche Konfiguration (Konf.-LAN-Adapter, Homegear und OpenHAB) wie auf meiner eigenen Synology installiert. Generell funktionieren die angeschlossen Komponenten bei Ihm, allerdings tauchen leider ständig Fehler in der LOG- und in der ERROR-Datei auf.
LOG:
10/14/15 19:30:04.054 RPC Server (Port 2001): Info: Connection to client number 32004 closed (3).
10/14/15 19:30:14.048 Info: Calling XML RPC method "system.listMethods" on server binary://192.168.178.100 and port 9123.
10/14/15 19:30:14.049 Info: Connecting to host 192.168.178.100 on port 9123...
10/14/15 19:30:14.049 Info: Connected to host 192.168.178.100 on port 9123. Client number is: 32005
10/14/15 19:30:59.115 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x48): 0C49A6412AE62DFD25560134C8
10/14/15 19:30:59.116 Info: Calling XML RPC method "system.multicall" on server binary://192.168.178.100 and port 9123.
10/14/15 19:30:59.116 Info: Connecting to host 192.168.178.100 on port 9123...
10/14/15 19:30:59.117 Info: Connected to host 192.168.178.100 on port 9123. Client number is: 32006
10/14/15 19:30:59.117 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 5 with serial number LEQ0504543 was set to 0x00.
10/14/15 19:30:59.118 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 5 with serial number LEQ0504543 was set to 0xC8.
10/14/15 19:30:59.176 Info: Calling XML RPC method "system.multicall" on server binary://192.168.178.100 and port 9123.
10/14/15 19:30:59.176 Info: Connecting to host 192.168.178.100 on port 9123...
10/14/15 19:30:59.177 Info: Connected to host 192.168.178.100 on port 9123. Client number is: 32007
10/14/15 19:30:59.240 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: Sending (My-HM-CFG-LAN): 0B03A004FD25562AE62D0100
10/14/15 19:31:00.095 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: No response to packet after 3 tries: 1903A004FD25562AE62DBE5D1CBE6C1369AE830CCBF9C199D317
10/14/15 19:31:05.089 RPC Server (Port 2001): Info: Connection from 192.168.178.100:48950 accepted. Client number: 32008
10/14/15 19:31:05.090 RPC Server (Port 2001): Info: Client number 32008 is calling RPC method: getAllValues Parameters:
(Boolean) 1
10/14/15 19:31:05.240 RPC Server (Port 2001): Info: Connection to client number 32008 closed (3).
10/14/15 19:31:14.115 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x50): 0C4AA6412AE62DFD2556013500
10/14/15 19:31:14.116 Info: Calling XML RPC method "system.multicall" on server binary://192.168.178.100 and port 9123.
10/14/15 19:31:14.116 Info: Connecting to host 192.168.178.100 on port 9123...
10/14/15 19:31:14.116 Info: Connected to host 192.168.178.100 on port 9123. Client number is: 32009
10/14/15 19:31:14.116 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 5 with serial number LEQ0504543 was set to 0x00.
10/14/15 19:31:14.117 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 5 with serial number LEQ0504543 was set to 0x00.
10/14/15 19:31:14.179 Info: Calling XML RPC method "system.multicall" on server binary://192.168.178.100 and port 9123.
10/14/15 19:31:14.179 Info: Connecting to host 192.168.178.100 on port 9123...
10/14/15 19:31:14.179 Info: Connected to host 192.168.178.100 on port 9123. Client number is: 32010
10/14/15 19:31:14.242 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: Sending (My-HM-CFG-LAN): 0B03A004FD25562AE62D0100
10/14/15 19:31:15.088 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: No response to packet after 3 tries: 1903A004FD25562AE62D61082B7247C965048A6EDB1A8778AAB6
Error
10/14/15 19:31:15.089 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: No response to packet after 3 tries: 1903A004FD25562AE62D61082B7247C965048A6EDB1A8778AAB6
10/14/15 19:32:55.595 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: No response to packet after 3 tries: 1903A004FD25562AE62D90F95E6A64559EF75E5E70E6B8EB2149
10/14/15 19:33:02.848 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: No response to packet after 3 tries: 1903A004FD25562AE62D0AAEE3ED3E0D05C7413AEADEAABEB558
Mir ist klar, das hier Homegear immer wieder versucht Pakete zusenden, allerdings ist mir nicht klar was die Ursache hierfür ist. Bitte helfe mir auf die Sprünge.
Danke und viele Grüße
Klaus
