Hey Sathya,
danke für Deine Antwort.
Da hab ich mich wohl in der Tat ein bißchen blöd ausgedrückt.
Hier erstmal das Log:
01/01/70 01:00:22.655 Starting Homegear...
01/01/70 01:00:22.656 Homegear version 0.6.0-1315
01/01/70 01:00:22.656 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:22.656 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:22.657 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/01/70 01:00:22.658 Info: Core file size now is "4294967295".
01/01/70 01:00:22.658 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
01/01/70 01:00:22.658 Info: Maximum thread priority now is "100".
01/01/70 01:00:22.658 Starting Homegear...
01/01/70 01:00:22.659 Homegear version 0.6.0-1315
01/01/70 01:00:22.659 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:22.659 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:22.663 Info: Loading family module mod_max.so
01/01/70 01:00:22.734 /etc/homegear/families/max.conf
01/01/70 01:00:22.741 Info: Loading family module mod_miscellaneous.so
01/01/70 01:00:22.775 /etc/homegear/families/miscellaneous.conf
01/01/70 01:00:22.775 Info: Loading family module mod_sonos.so
01/01/70 01:00:22.810 /etc/homegear/families/sonos.conf
01/01/70 01:00:22.826 Info: Loading family module mod_philipshue.so
01/01/70 01:00:22.860 /etc/homegear/families/philipshue.conf
01/01/70 01:00:22.862 Info: Loading family module mod_homematicwired.so
01/01/70 01:00:22.914 /etc/homegear/families/homematicwired.conf
01/01/70 01:00:22.916 Info: Loading family module mod_insteon.so
01/01/70 01:00:22.972 /etc/homegear/families/insteon.conf
01/01/70 01:00:22.979 Info: Loading family module mod_homematicbidcos.so
01/01/70 01:00:23.048 /etc/homegear/families/homematicbidcos.conf
01/01/70 01:00:23.064 Info: Settings up physical interfaces and GPIOs...
01/01/70 01:00:23.069 Info: Dropping privileges to user homegear (106) and group homegear (111)
01/01/70 01:00:23.070 Info: Homegear is (now) running as user with id 106 and group with id 111.
01/01/70 01:00:23.070 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
01/01/70 01:00:23.070 Info: Core file size now is "4294967295".
01/01/70 01:00:23.070 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
01/01/70 01:00:23.070 Info: Maximum thread priority now is "100".
01/01/70 01:00:23.071 Warning: Time is in the past. Waiting for ntp to set the time...
04/30/16 11:42:23.343 Info: Backing up database...
04/30/16 11:42:28.234 Initializing database...
04/30/16 11:42:28.241 Starting script engine server...
04/30/16 11:42:28.651 Initializing licensing controller...
04/30/16 11:42:28.652 Loading licensing controller data...
04/30/16 11:42:28.652 Loading devices...
04/30/16 11:42:28.652 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
04/30/16 11:42:28.652 Info: Disposing family module mod_homematicbidcos.so
04/30/16 11:42:28.653 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
04/30/16 11:42:28.653 Info: Disposing family module mod_homematicwired.so
04/30/16 11:42:28.659 Info: Not initializing device family Insteon, because no physical interface was found.
04/30/16 11:42:28.659 Info: Disposing family module mod_insteon.so
04/30/16 11:42:28.660 Info: Not initializing device family MAX!, because no physical interface was found.
04/30/16 11:42:28.660 Info: Disposing family module mod_max.so
04/30/16 11:42:28.660 Info: Not initializing device family Philips hue, because no physical interface was found.
04/30/16 11:42:28.660 Info: Disposing family module mod_philipshue.so
04/30/16 11:42:28.661 Loading XML RPC devices...
04/30/16 11:42:28.715 Loading device 1
04/30/16 11:42:28.722 Loading XML RPC devices...
04/30/16 11:42:28.731 Loading device 2
04/30/16 11:42:28.732 Start listening for packets...
04/30/16 11:42:28.734 Initializing RPC client...
04/30/16 11:42:28.734 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/30/16 11:42:28.741 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
04/30/16 11:42:28.747 Module Sonos: Event server "My-Sonos-1234": Info: Started listening on address 192.168.163.28 and port 7373
04/30/16 11:42:28.748 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/30/16 11:42:28.846 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
04/30/16 11:42:28.858 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
04/30/16 11:42:28.916 Starting CLI server...
04/30/16 11:42:28.917 Initializing event handler...
04/30/16 11:42:28.917 Loading events...
04/30/16 11:42:28.919 Startup complete. Waiting for physical interfaces to connect.
04/30/16 11:42:28.919 All physical interfaces are connected now.
04/30/16 11:42:28.919 Starting UPnP server...
04/30/16 11:42:28.922 Info: UPnP server: Binding to address: 192.168.163.28
04/30/16 11:42:28.922 UPnP Server: Info: Started listening.
04/30/16 11:42:28.923 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
01/01/70 01:00:19.552 Starting Homegear...
01/01/70 01:00:19.553 Homegear version 0.6.0-1315
01/01/70 01:00:19.553 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:19.554 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:19.554 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/01/70 01:00:19.554 Info: Core file size now is "4294967295".
01/01/70 01:00:19.555 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
01/01/70 01:00:19.555 Info: Maximum thread priority now is "100".
01/01/70 01:00:19.555 Starting Homegear...
01/01/70 01:00:19.556 Homegear version 0.6.0-1315
01/01/70 01:00:19.556 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:19.557 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:19.560 Info: Loading family module mod_max.so
01/01/70 01:00:19.631 /etc/homegear/families/max.conf
01/01/70 01:00:19.636 Info: Loading family module mod_miscellaneous.so
01/01/70 01:00:19.660 /etc/homegear/families/miscellaneous.conf
01/01/70 01:00:19.660 Info: Loading family module mod_sonos.so
01/01/70 01:00:19.691 /etc/homegear/families/sonos.conf
01/01/70 01:00:19.707 Info: Loading family module mod_philipshue.so
01/01/70 01:00:19.733 /etc/homegear/families/philipshue.conf
01/01/70 01:00:19.740 Info: Loading family module mod_homematicwired.so
01/01/70 01:00:19.784 /etc/homegear/families/homematicwired.conf
01/01/70 01:00:19.790 Info: Loading family module mod_insteon.so
01/01/70 01:00:19.836 /etc/homegear/families/insteon.conf
01/01/70 01:00:19.842 Info: Loading family module mod_homematicbidcos.so
01/01/70 01:00:19.917 /etc/homegear/families/homematicbidcos.conf
01/01/70 01:00:19.939 Info: Settings up physical interfaces and GPIOs...
01/01/70 01:00:19.947 Info: Dropping privileges to user homegear (106) and group homegear (111)
01/01/70 01:00:19.948 Info: Homegear is (now) running as user with id 106 and group with id 111.
01/01/70 01:00:19.948 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
01/01/70 01:00:19.948 Info: Core file size now is "4294967295".
01/01/70 01:00:19.949 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
01/01/70 01:00:19.949 Info: Maximum thread priority now is "100".
01/01/70 01:00:19.950 Warning: Time is in the past. Waiting for ntp to set the time...
04/30/16 11:52:20.773 Info: Backing up database...
04/30/16 11:52:23.893 Initializing database...
04/30/16 11:52:23.900 Starting script engine server...
04/30/16 11:52:24.284 Initializing licensing controller...
04/30/16 11:52:24.284 Loading licensing controller data...
04/30/16 11:52:24.284 Loading devices...
04/30/16 11:52:24.285 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
04/30/16 11:52:24.285 Info: Disposing family module mod_homematicbidcos.so
04/30/16 11:52:24.286 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
04/30/16 11:52:24.286 Info: Disposing family module mod_homematicwired.so
04/30/16 11:52:24.292 Info: Not initializing device family Insteon, because no physical interface was found.
04/30/16 11:52:24.292 Info: Disposing family module mod_insteon.so
04/30/16 11:52:24.293 Info: Not initializing device family MAX!, because no physical interface was found.
04/30/16 11:52:24.293 Info: Disposing family module mod_max.so
04/30/16 11:52:24.293 Info: Not initializing device family Philips hue, because no physical interface was found.
04/30/16 11:52:24.294 Info: Disposing family module mod_philipshue.so
04/30/16 11:52:24.294 Loading XML RPC devices...
04/30/16 11:52:24.350 Loading device 1
04/30/16 11:52:24.357 Loading XML RPC devices...
04/30/16 11:52:24.366 Loading device 2
04/30/16 11:52:24.367 Start listening for packets...
04/30/16 11:52:24.369 Initializing RPC client...
04/30/16 11:52:24.369 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/30/16 11:52:24.376 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
04/30/16 11:52:24.382 Module Sonos: Event server "My-Sonos-1234": Info: Started listening on address 192.168.163.28 and port 7373
04/30/16 11:52:24.383 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/30/16 11:52:24.481 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
04/30/16 11:52:24.497 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
04/30/16 11:52:24.551 Starting CLI server...
04/30/16 11:52:24.551 Initializing event handler...
04/30/16 11:52:24.552 Loading events...
04/30/16 11:52:24.554 Startup complete. Waiting for physical interfaces to connect.
04/30/16 11:52:24.554 All physical interfaces are connected now.
04/30/16 11:52:24.554 Starting UPnP server...
04/30/16 11:52:24.557 Info: UPnP server: Binding to address: 192.168.163.28
04/30/16 11:52:24.557 UPnP Server: Info: Started listening.
04/30/16 11:52:24.558 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
04/30/16 12:03:56.718 Info: CLI connection accepted. Client number: 34
04/30/16 12:13:28.543 Info: CLI connection accepted. Client number: 60
01/01/70 01:00:19.253 Starting Homegear...
01/01/70 01:00:19.254 Homegear version 0.6.0-1315
01/01/70 01:00:19.254 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:19.254 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:19.255 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/01/70 01:00:19.255 Info: Core file size now is "4294967295".
01/01/70 01:00:19.255 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
01/01/70 01:00:19.255 Info: Maximum thread priority now is "100".
01/01/70 01:00:19.255 Starting Homegear...
01/01/70 01:00:19.256 Homegear version 0.6.0-1315
01/01/70 01:00:19.256 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:19.256 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:19.261 Info: Loading family module mod_max.so
01/01/70 01:00:19.333 /etc/homegear/families/max.conf
01/01/70 01:00:19.338 Info: Loading family module mod_miscellaneous.so
01/01/70 01:00:19.371 /etc/homegear/families/miscellaneous.conf
01/01/70 01:00:19.372 Info: Loading family module mod_sonos.so
01/01/70 01:00:19.400 /etc/homegear/families/sonos.conf
01/01/70 01:00:19.403 Info: Loading family module mod_philipshue.so
01/01/70 01:00:19.431 /etc/homegear/families/philipshue.conf
01/01/70 01:00:19.433 Info: Loading family module mod_homematicwired.so
01/01/70 01:00:19.491 /etc/homegear/families/homematicwired.conf
01/01/70 01:00:19.500 Info: Loading family module mod_insteon.so
01/01/70 01:00:19.552 /etc/homegear/families/insteon.conf
01/01/70 01:00:19.560 Info: Loading family module mod_homematicbidcos.so
01/01/70 01:00:19.634 /etc/homegear/families/homematicbidcos.conf
01/01/70 01:00:19.653 Info: Settings up physical interfaces and GPIOs...
01/01/70 01:00:19.657 Info: Dropping privileges to user homegear (106) and group homegear (111)
01/01/70 01:00:19.658 Info: Homegear is (now) running as user with id 106 and group with id 111.
01/01/70 01:00:19.658 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
01/01/70 01:00:19.658 Info: Core file size now is "4294967295".
01/01/70 01:00:19.658 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
01/01/70 01:00:19.659 Info: Maximum thread priority now is "100".
01/01/70 01:00:19.659 Warning: Time is in the past. Waiting for ntp to set the time...
04/30/16 12:14:42.950 Info: Backing up database...
04/30/16 12:14:46.005 Initializing database...
04/30/16 12:14:46.013 Starting script engine server...
04/30/16 12:14:46.382 Initializing licensing controller...
04/30/16 12:14:46.382 Loading licensing controller data...
04/30/16 12:14:46.382 Loading devices...
04/30/16 12:14:46.383 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
04/30/16 12:14:46.383 Info: Disposing family module mod_homematicbidcos.so
04/30/16 12:14:46.384 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
04/30/16 12:14:46.384 Info: Disposing family module mod_homematicwired.so
04/30/16 12:14:46.390 Info: Not initializing device family Insteon, because no physical interface was found.
04/30/16 12:14:46.390 Info: Disposing family module mod_insteon.so
04/30/16 12:14:46.391 Info: Not initializing device family MAX!, because no physical interface was found.
04/30/16 12:14:46.391 Info: Disposing family module mod_max.so
04/30/16 12:14:46.391 Info: Not initializing device family Philips hue, because no physical interface was found.
04/30/16 12:14:46.391 Info: Disposing family module mod_philipshue.so
04/30/16 12:14:46.392 Info: Not initializing device family Sonos, because no physical interface was found.
04/30/16 12:14:46.392 Info: Disposing family module mod_sonos.so
04/30/16 12:14:46.399 Loading XML RPC devices...
04/30/16 12:14:46.425 Loading device 2
04/30/16 12:14:46.426 Start listening for packets...
04/30/16 12:14:46.427 Initializing RPC client...
04/30/16 12:14:46.427 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/30/16 12:14:46.434 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
04/30/16 12:14:46.441 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/30/16 12:14:46.538 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
04/30/16 12:14:46.550 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
04/30/16 12:14:46.608 Starting CLI server...
04/30/16 12:14:46.609 Initializing event handler...
04/30/16 12:14:46.610 Loading events...
04/30/16 12:14:46.611 Startup complete. Waiting for physical interfaces to connect.
04/30/16 12:14:46.611 All physical interfaces are connected now.
04/30/16 12:14:46.611 Starting UPnP server...
04/30/16 12:14:46.614 Info: UPnP server: Binding to address: 192.168.163.28
04/30/16 12:14:46.615 UPnP Server: Info: Started listening.
04/30/16 12:14:46.616 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
04/30/16 12:23:28.274 RPC Server (Port 2001): Info: Connection from 192.168.163.31:56853 accepted. Client number: 6
04/30/16 12:23:28.275 RPC Server (Port 2001): Info: RPC server client id for client number 6 is: 0
04/30/16 12:23:28.299 RPC Server (Port 2001): Info: Connection to client number 6 closed.
04/30/16 12:26:38.194 Info: CLI connection accepted. Client number: 7
04/30/16 12:31:38.175 (Shutdown) => Stopping Homegear (Signal: 15)
04/30/16 12:31:38.175 (Shutdown) => Stopping CLI server
04/30/16 12:31:38.527 Stopping UPnP server...
01/01/70 01:00:14.440 Starting Homegear...
01/01/70 01:00:14.441 Homegear version 0.6.0-1315
01/01/70 01:00:14.441 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:14.442 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:14.442 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/01/70 01:00:14.442 Info: Core file size now is "4294967295".
01/01/70 01:00:14.442 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
01/01/70 01:00:14.443 Info: Maximum thread priority now is "100".
01/01/70 01:00:14.443 Starting Homegear...
01/01/70 01:00:14.444 Homegear version 0.6.0-1315
01/01/70 01:00:14.444 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:14.444 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:14.447 Info: Loading family module mod_max.so
01/01/70 01:00:14.541 /etc/homegear/families/max.conf
01/01/70 01:00:14.545 Info: Loading family module mod_miscellaneous.so
01/01/70 01:00:14.571 /etc/homegear/families/miscellaneous.conf
01/01/70 01:00:14.572 Info: Loading family module mod_sonos.so
01/01/70 01:00:14.613 /etc/homegear/families/sonos.conf
01/01/70 01:00:14.617 Info: Loading family module mod_philipshue.so
01/01/70 01:00:14.648 /etc/homegear/families/philipshue.conf
01/01/70 01:00:14.650 Info: Loading family module mod_homematicwired.so
01/01/70 01:00:14.693 /etc/homegear/families/homematicwired.conf
01/01/70 01:00:14.698 Info: Loading family module mod_insteon.so
01/01/70 01:00:14.759 /etc/homegear/families/insteon.conf
01/01/70 01:00:14.765 Info: Loading family module mod_homematicbidcos.so
01/01/70 01:00:14.848 /etc/homegear/families/homematicbidcos.conf
01/01/70 01:00:14.864 Info: Settings up physical interfaces and GPIOs...
01/01/70 01:00:14.868 Info: Dropping privileges to user homegear (106) and group homegear (111)
01/01/70 01:00:14.869 Info: Homegear is (now) running as user with id 106 and group with id 111.
01/01/70 01:00:14.869 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
01/01/70 01:00:14.869 Info: Core file size now is "4294967295".
01/01/70 01:00:14.869 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
01/01/70 01:00:14.869 Info: Maximum thread priority now is "100".
01/01/70 01:00:14.870 Warning: Time is in the past. Waiting for ntp to set the time...
04/30/16 12:32:21.875 Info: Backing up database...
04/30/16 12:32:25.011 Initializing database...
04/30/16 12:32:25.019 Starting script engine server...
04/30/16 12:32:25.417 Initializing licensing controller...
04/30/16 12:32:25.417 Loading licensing controller data...
04/30/16 12:32:25.417 Loading devices...
04/30/16 12:32:25.418 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
04/30/16 12:32:25.418 Info: Disposing family module mod_homematicbidcos.so
04/30/16 12:32:25.419 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
04/30/16 12:32:25.419 Info: Disposing family module mod_homematicwired.so
04/30/16 12:32:25.425 Info: Not initializing device family Insteon, because no physical interface was found.
04/30/16 12:32:25.425 Info: Disposing family module mod_insteon.so
04/30/16 12:32:25.426 Info: Not initializing device family MAX!, because no physical interface was found.
04/30/16 12:32:25.426 Info: Disposing family module mod_max.so
04/30/16 12:32:25.427 Info: Not initializing device family Philips hue, because no physical interface was found.
04/30/16 12:32:25.427 Info: Disposing family module mod_philipshue.so
04/30/16 12:32:25.427 Info: Not initializing device family Sonos, because no physical interface was found.
04/30/16 12:32:25.427 Info: Disposing family module mod_sonos.so
04/30/16 12:32:25.434 Loading XML RPC devices...
04/30/16 12:32:25.465 Loading device 2
04/30/16 12:32:25.467 Start listening for packets...
04/30/16 12:32:25.467 Initializing RPC client...
04/30/16 12:32:25.467 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/30/16 12:32:25.474 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
04/30/16 12:32:25.481 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/30/16 12:32:25.581 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
04/30/16 12:32:25.597 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
04/30/16 12:32:25.651 Starting CLI server...
04/30/16 12:32:25.651 Initializing event handler...
04/30/16 12:32:25.652 Loading events...
04/30/16 12:32:25.654 Startup complete. Waiting for physical interfaces to connect.
04/30/16 12:32:25.654 All physical interfaces are connected now.
04/30/16 12:32:25.654 Starting UPnP server...
04/30/16 12:32:25.657 Info: UPnP server: Binding to address: 192.168.163.28
04/30/16 12:32:25.657 UPnP Server: Info: Started listening.
04/30/16 12:32:25.658 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
04/30/16 12:37:13.162 RPC Server (Port 2001): Info: Connection from 192.168.163.31:58835 accepted. Client number: 6
04/30/16 12:37:13.163 RPC Server (Port 2001): Info: RPC server client id for client number 6 is: 0
04/30/16 12:37:13.187 RPC Server (Port 2001): Info: Connection to client number 6 closed.
04/30/16 12:45:33.496 RPC Server (Port 2001): Info: Connection from 192.168.163.31:59994 accepted. Client number: 7
04/30/16 12:45:33.497 RPC Server (Port 2001): Info: RPC server client id for client number 7 is: 1
04/30/16 12:45:33.521 RPC Server (Port 2001): Info: Connection to client number 7 closed.
04/30/16 13:28:40.543 Info: CLI connection accepted. Client number: 8
04/30/16 13:28:48.805 (Shutdown) => Stopping Homegear (Signal: 15)
04/30/16 13:28:48.805 (Shutdown) => Stopping CLI server
01/01/70 01:00:15.201 Starting Homegear...
01/01/70 01:00:15.202 Homegear version 0.6.0-1315
01/01/70 01:00:15.203 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:15.203 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:15.204 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/01/70 01:00:15.204 Info: Core file size now is "4294967295".
01/01/70 01:00:15.204 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
01/01/70 01:00:15.204 Info: Maximum thread priority now is "100".
01/01/70 01:00:15.204 Starting Homegear...
01/01/70 01:00:15.205 Homegear version 0.6.0-1315
01/01/70 01:00:15.205 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
01/01/70 01:00:15.205 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
01/01/70 01:00:15.209 Info: Loading family module mod_max.so
01/01/70 01:00:15.279 /etc/homegear/families/max.conf
01/01/70 01:00:15.283 Info: Loading family module mod_miscellaneous.so
01/01/70 01:00:15.312 /etc/homegear/families/miscellaneous.conf
01/01/70 01:00:15.313 Info: Loading family module mod_sonos.so
01/01/70 01:00:15.348 /etc/homegear/families/sonos.conf
01/01/70 01:00:15.350 Info: Loading family module mod_philipshue.so
01/01/70 01:00:15.373 /etc/homegear/families/philipshue.conf
01/01/70 01:00:15.378 Info: Loading family module mod_homematicwired.so
01/01/70 01:00:15.427 /etc/homegear/families/homematicwired.conf
01/01/70 01:00:15.430 Info: Loading family module mod_insteon.so
01/01/70 01:00:15.476 /etc/homegear/families/insteon.conf
01/01/70 01:00:15.483 Info: Loading family module mod_homematicbidcos.so
01/01/70 01:00:15.567 /etc/homegear/families/homematicbidcos.conf
01/01/70 01:00:15.584 Info: Settings up physical interfaces and GPIOs...
01/01/70 01:00:15.588 Info: Dropping privileges to user homegear (106) and group homegear (111)
01/01/70 01:00:15.589 Info: Homegear is (now) running as user with id 106 and group with id 111.
01/01/70 01:00:15.589 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
01/01/70 01:00:15.589 Info: Core file size now is "4294967295".
01/01/70 01:00:15.589 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
01/01/70 01:00:15.590 Info: Maximum thread priority now is "100".
01/01/70 01:00:15.590 Warning: Time is in the past. Waiting for ntp to set the time...
04/30/16 13:29:30.997 Info: Backing up database...
04/30/16 13:29:34.029 Initializing database...
04/30/16 13:29:34.037 Starting script engine server...
04/30/16 13:29:34.405 Initializing licensing controller...
04/30/16 13:29:34.405 Loading licensing controller data...
04/30/16 13:29:34.405 Loading devices...
04/30/16 13:29:34.405 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
04/30/16 13:29:34.405 Info: Disposing family module mod_homematicbidcos.so
04/30/16 13:29:34.406 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
04/30/16 13:29:34.406 Info: Disposing family module mod_homematicwired.so
04/30/16 13:29:34.412 Info: Not initializing device family Insteon, because no physical interface was found.
04/30/16 13:29:34.413 Info: Disposing family module mod_insteon.so
04/30/16 13:29:34.413 Info: Not initializing device family MAX!, because no physical interface was found.
04/30/16 13:29:34.413 Info: Disposing family module mod_max.so
04/30/16 13:29:34.414 Info: Not initializing device family Philips hue, because no physical interface was found.
04/30/16 13:29:34.414 Info: Disposing family module mod_philipshue.so
04/30/16 13:29:34.414 Info: Not initializing device family Sonos, because no physical interface was found.
04/30/16 13:29:34.414 Info: Disposing family module mod_sonos.so
04/30/16 13:29:34.422 Loading XML RPC devices...
04/30/16 13:29:34.448 Loading device 2
04/30/16 13:29:34.449 Start listening for packets...
04/30/16 13:29:34.449 Initializing RPC client...
04/30/16 13:29:34.450 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
04/30/16 13:29:34.457 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
04/30/16 13:29:34.463 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
04/30/16 13:29:34.561 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
04/30/16 13:29:34.577 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
04/30/16 13:29:34.631 Starting CLI server...
04/30/16 13:29:34.631 Initializing event handler...
04/30/16 13:29:34.632 Loading events...
04/30/16 13:29:34.634 Startup complete. Waiting for physical interfaces to connect.
04/30/16 13:29:34.634 All physical interfaces are connected now.
04/30/16 13:29:34.634 Starting UPnP server...
04/30/16 13:29:34.637 Info: UPnP server: Binding to address: 192.168.163.28
04/30/16 13:29:34.637 UPnP Server: Info: Started listening.
04/30/16 13:29:34.639 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
04/30/16 13:38:06.654 RPC Server (Port 2001): Info: Connection from 192.168.163.31:1575 accepted. Client number: 6
04/30/16 13:38:06.655 RPC Server (Port 2001): Info: RPC server client id for client number 6 is: 0
04/30/16 13:38:06.679 RPC Server (Port 2001): Info: Connection to client number 6 closed.
04/30/16 13:38:12.045 RPC Server (Port 2001): Info: Connection from 192.168.163.31:1603 accepted. Client number: 7
04/30/16 13:38:12.045 RPC Server (Port 2001): Info: RPC server client id for client number 7 is: 1
04/30/16 13:38:12.069 RPC Server (Port 2001): Info: Connection to client number 7 closed.
04/30/16 13:42:48.529 Info: CLI connection accepted. Client number: 8
04/30/16 13:54:57.330 (Shutdown) => Stopping Homegear (Signal: 15)
04/30/16 13:54:57.330 (Shutdown) => Stopping CLI server
04/30/16 13:54:57.430 Info: Shutdown detected. Suspending monitoring.
04/30/16 13:54:58.315 Stopping UPnP server...
04/30/16 13:54:58.354 (Shutdown) => Stopping RPC servers
04/30/16 13:54:59.015 RPC Server (Port 2001): Info: Waiting for threads to finish.
04/30/16 13:54:59.115 RPC Server (Port 2002): Info: Waiting for threads to finish.
04/30/16 13:54:59.216 RPC Server (Port 2003): Info: Waiting for threads to finish.
04/30/16 13:54:59.221 (Shutdown) => Stopping Event handler
04/30/16 13:54:59.222 (Shutdown) => Stopping RPC client
04/30/16 13:54:59.222 (Shutdown) => Closing physical interfaces
04/30/16 13:54:59.222 (Shutdown) => Stopping script engine server...
04/30/16 13:55:00.817 (Shutdown) => Saving device families
04/30/16 13:55:00.817 (Shutdown) => Saving devices
04/30/16 13:55:00.817 (Shutdown) => Saving Miscellaneous central...
04/30/16 13:55:00.817 (Shutdown) => Disposing device families
04/30/16 13:55:00.817 (Shutdown) => Disposing database
04/30/16 13:55:00.822 Closing database...
04/30/16 13:55:02.911 (Shutdown) => Disposing family modules
04/30/16 13:55:02.911 Info: Disposing family module mod_miscellaneous.so
04/30/16 13:55:02.912 (Shutdown) => Disposing licensing modules
04/30/16 13:55:02.925 (Shutdown) => Shutdown complete.
04/30/16 13:55:02.943 Info: Process with id 727 ended.
04/30/16 13:55:02.943 Info: Homegear exited with exit code 0. Stopping monitor process.
05/02/16 15:50:32.066 Starting Homegear...
05/02/16 15:50:32.068 Homegear version 0.6.0-1315
05/02/16 15:50:32.069 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
05/02/16 15:50:32.069 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
05/02/16 15:50:32.069 Starting Homegear...
05/02/16 15:50:32.069 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
05/02/16 15:50:32.070 Homegear version 0.6.0-1315
05/02/16 15:50:32.070 Git commit SHA of libhomegear-base: db0249b662d4c8d39093329af1001506f142f080
05/02/16 15:50:32.070 Info: Core file size now is "4294967295".
05/02/16 15:50:32.070 Git commit SHA of Homegear: e9fd7b8dd473dde3f4053e834a0077ac1c57bc16
05/02/16 15:50:32.070 Info: Setting maximum thread priority to "100" for user with id 0 and group with id 0.
05/02/16 15:50:32.070 Info: Maximum thread priority now is "100".
05/02/16 15:50:32.079 Info: Loading family module mod_max.so
05/02/16 15:50:32.099 /etc/homegear/families/max.conf
05/02/16 15:50:32.100 Info: Loading family module mod_miscellaneous.so
05/02/16 15:50:32.108 /etc/homegear/families/miscellaneous.conf
05/02/16 15:50:32.108 Info: Loading family module mod_sonos.so
05/02/16 15:50:32.120 /etc/homegear/families/sonos.conf
05/02/16 15:50:32.120 Info: Loading family module mod_philipshue.so
05/02/16 15:50:32.130 /etc/homegear/families/philipshue.conf
05/02/16 15:50:32.131 Info: Loading family module mod_homematicwired.so
05/02/16 15:50:32.145 /etc/homegear/families/homematicwired.conf
05/02/16 15:50:32.146 Info: Loading family module mod_insteon.so
05/02/16 15:50:32.161 /etc/homegear/families/insteon.conf
05/02/16 15:50:32.162 Info: Loading family module mod_homematicbidcos.so
05/02/16 15:50:32.189 /etc/homegear/families/homematicbidcos.conf
05/02/16 15:50:32.193 Info: Settings up physical interfaces and GPIOs...
05/02/16 15:50:32.194 Info: Dropping privileges to user homegear (106) and group homegear (111)
05/02/16 15:50:32.195 Info: Homegear is (now) running as user with id 106 and group with id 111.
05/02/16 15:50:32.195 Info: Setting allowed core file size to "4294967295" for user with id 106 and group with id 111.
05/02/16 15:50:32.195 Info: Core file size now is "4294967295".
05/02/16 15:50:32.195 Info: Setting maximum thread priority to "100" for user with id 106 and group with id 111.
05/02/16 15:50:32.195 Info: Maximum thread priority now is "100".
05/02/16 15:50:32.207 Info: Backing up database...
05/02/16 15:50:35.304 Initializing database...
05/02/16 15:50:35.311 Starting script engine server...
05/02/16 15:50:35.391 Initializing licensing controller...
05/02/16 15:50:35.391 Loading licensing controller data...
05/02/16 15:50:35.391 Loading devices...
05/02/16 15:50:35.392 Info: Not initializing device family HomeMatic BidCoS, because no physical interface was found.
05/02/16 15:50:35.392 Info: Disposing family module mod_homematicbidcos.so
05/02/16 15:50:35.393 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
05/02/16 15:50:35.393 Info: Disposing family module mod_homematicwired.so
05/02/16 15:50:35.393 Info: Not initializing device family Insteon, because no physical interface was found.
05/02/16 15:50:35.393 Info: Disposing family module mod_insteon.so
05/02/16 15:50:35.394 Info: Not initializing device family MAX!, because no physical interface was found.
05/02/16 15:50:35.394 Info: Disposing family module mod_max.so
05/02/16 15:50:35.394 Info: Not initializing device family Philips hue, because no physical interface was found.
05/02/16 15:50:35.394 Info: Disposing family module mod_philipshue.so
05/02/16 15:50:35.395 Info: Not initializing device family Sonos, because no physical interface was found.
05/02/16 15:50:35.395 Info: Disposing family module mod_sonos.so
05/02/16 15:50:35.395 Loading XML RPC devices...
05/02/16 15:50:35.402 Loading device 2
05/02/16 15:50:35.403 Start listening for packets...
05/02/16 15:50:35.403 Initializing RPC client...
05/02/16 15:50:35.403 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
05/02/16 15:50:35.410 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
05/02/16 15:50:35.417 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
05/02/16 15:50:35.496 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
05/02/16 15:50:35.517 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
05/02/16 15:50:35.565 Starting CLI server...
05/02/16 15:50:35.565 Initializing event handler...
05/02/16 15:50:35.566 Loading events...
05/02/16 15:50:35.568 Startup complete. Waiting for physical interfaces to connect.
05/02/16 15:50:35.568 All physical interfaces are connected now.
05/02/16 15:50:35.568 Starting UPnP server...
05/02/16 15:50:35.571 Info: UPnP server: Binding to address: 192.168.163.28
05/02/16 15:50:35.571 UPnP Server: Info: Started listening.
05/02/16 15:50:35.572 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
05/02/16 15:51:38.043 RPC Server (Port 2001): Info: Connection from 192.168.163.31:18693 accepted. Client number: 6
05/02/16 15:51:38.044 RPC Server (Port 2001): Info: RPC server client id for client number 6 is: 0
05/02/16 15:51:38.068 RPC Server (Port 2001): Info: Connection to client number 6 closed.
OpenHab lass ich erstmal beiseite;
Homegear hat leider Probleme mit den Devices, obwohl ich db.sql der alten Installation brav aufgehoben habe…
Ich hätte so gern mal, dass alle Installationen (Homegear und Openhab) freundlich miteinander reden…
