Hi
I just have installed homegear-management.
homegear-management will start before homegear. If not existing already it will create the folder /var/run/homegear with below permissions:
ls -al /var/run/homegear/
total 4
drwxrwx--- 2 root root 60 Jul 4 13:45 . <<<<<<<<<<<<<<<<<<<<
drwxr-xr-x 24 root root 820 Jul 4 13:52 ..
-rw-r--r-- 1 root root 3 Jul 4 13:45 homegear-management.pid
this will prevent homegear to store data inside. from an older installation I see that the persmissions look like:
total 8
drwxrwx--- 2 homegear homegear 160 Jul 4 10:56 . <<<<<<<<<<<<<<<<<<<<
drwxr-xr-x 25 root root 800 Jul 4 11:52 ..
srwxrwx--- 1 homegear homegear 0 Jul 4 10:56 homegearFE.sock
srwxrwx--- 1 homegear homegear 0 Jul 4 10:56 homegearIPC.sock
-rw-r--r-- 1 root root 3 Jul 4 10:55 homegear-management.pid
-rw-r--r-- 1 homegear homegear 3 Jul 4 10:55 homegear.pid
srwxrwx--- 1 homegear homegear 0 Jul 4 10:55 homegearSE.sock
srwxrwx--- 1 homegear homegear 0 Jul 4 10:56 homegear.sock
as a result homegear will not start. after changing the permissions it start without any problems
cheers
