Homegear läuft irgendwie nicht richtig
hallo,
seit gestern läuft homegear mit openhab nicht mehr ganz runde.
ich hab solche Fehlermeldungen in der homgear.err
[quote]12/05/14 09:32:00.317 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E66A011FD21761BB0E40201C80000
[/quote]
und das aus der homegear.log
[quote]12/05/14 09:51:47.641 RPC Server (Port 2001): Info: Connection from 192.168.200.20:49889 accepted. Client number: 60
12/05/14 09:51:47.642 RPC Server (Port 2001): Info: Client number 60 is calling RPC method: getAllValues Parameters:
(Boolean) 1
12/05/14 09:51:47.805 RPC Server (Port 2001): Info: Connection to client number 60 closed (3).
12/05/14 09:51:50.096 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:52:05.100 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:52:20.104 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:52:35.108 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:52:36.868 RPC Server (Port 2001): Info: Connection from 192.168.200.20:49895 accepted. Client number: 81
12/05/14 09:52:36.868 RPC Server (Port 2001): Info: Client number 81 is calling RPC method: setValue Parameters:
(String) JEQ0118765:1
(String) STATE
(Boolean) 1
12/05/14 09:52:36.872 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E72A011FD21761BB0E40201C80000
12/05/14 09:52:36.873 Info: Calling XML RPC method system.multicall on server binary://192.168.200.20 and port 9123.
12/05/14 09:52:36.873 Info: Connecting to host 192.168.200.20 on port 9123…
12/05/14 09:52:36.875 RPC Server (Port 2001): Info: Connection to client number 81 closed (3).
12/05/14 09:52:36.875 Info: Connected to host 192.168.200.20 on port 9123. Client number is: 82
12/05/14 09:52:50.124 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:53:05.128 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:53:20.132 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:53:22.151 RPC Server (Port 2001): Info: Connection from 192.168.200.20:49903 accepted. Client number: 101
12/05/14 09:53:22.151 RPC Server (Port 2001): Info: Client number 101 is calling RPC method: setValue Parameters:
(String) STATE
(Boolean) 0
12/05/14 09:53:22.152 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E73A011FD21761BB0E40201000000
12/05/14 09:53:22.152 Info: Calling XML RPC method system.multicall on server binary://192.168.200.20 and port 9123.
12/05/14 09:53:22.152 Info: Connecting to host 192.168.200.20 on port 9123…
12/05/14 09:53:22.154 Info: Connected to host 192.168.200.20 on port 9123. Client number is: 102
12/05/14 09:53:22.156 RPC Server (Port 2001): Info: Connection to client number 101 closed (3).
12/05/14 09:53:35.137 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:53:50.141 Info: Connecting to host 192.168.200.3 on port 1000…
12/05/14 09:54:05.145 Info: Connecting to host 192.168.200.3 on port 1000…
[/quote]
und hier noch die debug Meldung aus openhab
[quote]09:52:36.896 INFO runtime.busevents[:22] - Licht_WZ_Eingang received command ON
09:52:36.896 DEBUG o.o.b.h.i.c.HomematicCommunicator[:229] - Received command ON for item Licht_WZ_Eingang
09:52:36.896 DEBUG o.o.b.h.i.c.s.AbstractTypeConverter[:66] - Converting type OnOffType with value ‘ON’ to (Boolean) value with OnOffTypeConverter for HmDatapoint[address=JEQ0118765,channel=1,parameter=STATE]
09:52:36.912 DEBUG o.o.b.h.i.c.HomematicCommunicator[:164] - Received new (Boolean) value ‘true’ for DatapointConfig[address=JEQ0118765,channel=1,parameter=STATE]
09:52:36.912 DEBUG o.o.b.h.i.c.s.AbstractTypeConverter[:105] - Converting (Boolean) value ‘true’ with OnOffTypeConverter for HmDatapoint[address=JEQ0118765,channel=1,parameter=STATE]
09:52:36.912 INFO runtime.busevents[:26] - Licht_WZ_Eingang state updated to ON
09:53:22.180 INFO runtime.busevents[:22] - Licht_WZ_Eingang received command OFF
09:53:22.180 DEBUG o.o.b.h.i.c.HomematicCommunicator[:229] - Received command OFF for item Licht_WZ_Eingang
09:53:22.181 DEBUG o.o.b.h.i.c.s.AbstractTypeConverter[:66] - Converting type OnOffType with value ‘OFF’ to (Boolean) value with OnOffTypeConverter for HmDatapoint[address=JEQ0118765,channel=1,parameter=STATE]
09:53:22.191 DEBUG o.o.b.h.i.c.HomematicCommunicator[:164] - Received new (Boolean) value ‘false’ for DatapointConfig[address=JEQ0118765,channel=1,parameter=STATE]
09:53:22.192 DEBUG o.o.b.h.i.c.s.AbstractTypeConverter[:105] - Converting (Boolean) value ‘false’ with OnOffTypeConverter for HmDatapoint[address=JEQ0118765,channel=1,parameter=STATE]
[/quote]
aber die sehen nicht verdächtig aus
und die Aktoren lassen sich nicht schalten.
was bedeute diese Fehlermeldung?
und wie kann ich sie beheben
danke stefan
Hallo Stefan,
die Meldungen
besagen, dass Homegear versucht, eine Verbindung zu deinem HM-CFG-LAN aufzubauen. Es kommt aber niemals eine Verbindung zustande (dann würde da “conntected to” stehen und du würdest auch empfangene Pakete sehen).
Überprüf noch einmal, ob die IP-Adresse des HM-CFG-LAN stimmt und ob du ihn mit
anpingen kannst. Stell außerdem sicher, dass kein zweites Gerät sich versucht, sich mit dem HM-CFG-LAN zu verbinden. Dieser unterstützt nämlich nur eine einzige TCP-Verbindung.
Um zu testen, ob hinter der IP-Adresse 192.168.200.3 wirklich ein HM-CFG-LAN steckt und ob dieser noch TCP-Verbindungen zulässt, kannst du “nmap” verwenden (mit “apt-get install nmap” installieren).
Die Ausgabe sollte so aussehen:
sathya@eiklas: ~ $ nmap 192.168.200.3
Starting Nmap 6.00 ( http://nmap.org ) at 2014-12-05 10:24 CET
Nmap scan report for 192.168.200.3
Host is up (0.00084s latency).
Not shown: 999 closed ports
PORT     STATE SERVICE
1000/tcp open  cadlock <-- Port 1000 geöffnet und erreichbar
MAC Address: 00:1A:22:01:61:91 (eQ-3 Entwicklung GmbH)
Nmap done: 1 IP address (1 host up) scanned in 1.88 seconds
Liebe Grüße
ok,
danke!
lag irgendwie an den mehrfach verbindungen, hab nen neuen server :wink:
bye stefan
