Up to now, I was using the [RS485 - Serial (UART) Module] which for some reason I do not manage to get to work anymore with the raspbian/openhab/bullseye setup.
So I bought a new communication module, the HomeMatic Wired LAN Gateway (HMW-LGW).
I followed the configuration instructions, but at first, no luck in searching for devices through the homegear shell. I then set the
responseDelay = 60
and the device discovery started working.
Next step was to make it work with Openhab. My Thing definition file did not change:
Bridge homematic:bridge:homegear [ gatewayAddress="127.0.0.1" ] {
// some thing definitions here
The OH log shows the following:
Thing 'homematic:bridge:homegear' changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: java.net.SocketTimeoutException: Connect Timeout
It seems to be a communication issue between OH and Homegear. Any ideas?
@sathya, would you be able to help me out, maybe? My whole installation is unusable at the moment since I cannot control my homematic devices anymore. Many thanks!
your log shows several problems running homegear one of which most likely contributes to the communication problem. You should fix them one after the other before trying the openhab communication.
→ I am only using homematic wired, so I guess (hope) this does not concern me. I might be wrong.
(3)
Critical: Can't start more threads. Thread limit reached (217 threads)
→ I did not find a solution for this and I have no idea what to do.
My log now looks like this:
05/01/24 17:15:12.359 Starting Homegear...
05/01/24 17:15:12.359 Homegear version: 0.8.1-3519
05/01/24 17:15:12.359 Determining maximum thread count...
05/01/24 17:15:13.505 Maximum thread count is: 217
05/01/24 17:15:13.624 Info: Backing up database...
05/01/24 17:15:13.742 Initializing database...
05/01/24 17:15:14.685 Homegear instance ID: 17BB30FD22B6C279-00000000-0B35-77B8-B1DC-8CE1C16FEEAE
05/01/24 17:15:14.689 Debug: Loading licensing modules
05/01/24 17:15:14.693 Initializing system variable controller...
05/01/24 17:15:14.694 Debug: Loading family modules
05/01/24 17:15:14.694 Info: Loading family module (type 1) mod_miscellaneous.so
05/01/24 17:15:14.712 Info: Loading settings from /etc/homegear/families/miscellaneous.conf
05/01/24 17:15:14.714 Info: Loading translations from /var/lib/homegear/admin-ui/translations/modules/miscellaneous/
05/01/24 17:15:14.729 Info: Loading family module (type 1) mod_homematicbidcos.so
05/01/24 17:15:14.758 Info: Loading settings from /etc/homegear/families/homematicbidcos.conf
05/01/24 17:15:14.759 Info: Loading translations from /var/lib/homegear/admin-ui/translations/modules/homematicbidcos/
05/01/24 17:15:14.779 Info: Loading family module (type 1) mod_homematicwired.so
05/01/24 17:15:14.798 Info: Loading settings from /etc/homegear/families/homematicwired.conf
05/01/24 17:15:14.800 Info: Loading translations from /var/lib/homegear/admin-ui/translations/modules/homematicwired/
05/01/24 17:15:14.804 Info: Loading family module (type 1) mod_max.so
05/01/24 17:15:14.828 Info: Loading settings from /etc/homegear/families/max.conf
05/01/24 17:15:14.830 Info: Loading translations from /var/lib/homegear/admin-ui/translations/modules/max/
05/01/24 17:15:14.836 Info: Homegear is (now) running as user with id 111 and group with id 117.
05/01/24 17:15:14.837 Loading common translations...
05/01/24 17:15:14.859 Error in file Node-BLUE/NodeManager.cpp line 349 in function void Homegear::NodeManager::fillManagerModuleInfo(): Could not open directory "/var/lib/homegear/node-blue/nodes/"
05/01/24 17:15:14.955 Starting script engine server...
05/01/24 17:15:15.028 Initializing licensing controller...
05/01/24 17:15:15.028 Loading licensing controller data...
05/01/24 17:15:15.028 Loading devices...
05/01/24 17:15:15.028 Loading XML RPC devices...
05/01/24 17:15:16.190 Loading device 1
05/01/24 17:15:16.190 Module HomeMatic BidCoS: Info: Central address set to 0xFD7762.
05/01/24 17:15:16.209 Loading XML RPC devices...
05/01/24 17:15:16.277 Loading device 2
05/01/24 17:15:16.283 Module HomeMatic Wired: Loading HomeMatic Wired peer 1
05/01/24 17:15:16.313 Module HomeMatic Wired: Loading HomeMatic Wired peer 2
05/01/24 17:15:16.327 Module HomeMatic Wired: Loading HomeMatic Wired peer 3
05/01/24 17:15:16.340 Module HomeMatic Wired: Loading HomeMatic Wired peer 4
05/01/24 17:15:16.355 Module HomeMatic Wired: Loading HomeMatic Wired peer 5
05/01/24 17:15:16.371 Module HomeMatic Wired: Loading HomeMatic Wired peer 6
05/01/24 17:15:16.385 Module HomeMatic Wired: Loading HomeMatic Wired peer 7
05/01/24 17:15:16.401 Module HomeMatic Wired: Loading HomeMatic Wired peer 8
05/01/24 17:15:16.416 Module HomeMatic Wired: Loading HomeMatic Wired peer 9
05/01/24 17:15:16.421 Module HomeMatic Wired: Loading HomeMatic Wired peer 10
05/01/24 17:15:16.426 Module HomeMatic Wired: Loading HomeMatic Wired peer 11
05/01/24 17:15:16.432 Module HomeMatic Wired: Loading HomeMatic Wired peer 12
05/01/24 17:15:16.437 Module HomeMatic Wired: Loading HomeMatic Wired peer 13
05/01/24 17:15:16.442 Module HomeMatic Wired: Loading HomeMatic Wired peer 14
05/01/24 17:15:16.447 Module HomeMatic Wired: Loading HomeMatic Wired peer 15
05/01/24 17:15:16.452 Module HomeMatic Wired: Loading HomeMatic Wired peer 16
05/01/24 17:15:16.457 Module HomeMatic Wired: Loading HomeMatic Wired peer 17
05/01/24 17:15:16.462 Module HomeMatic Wired: Loading HomeMatic Wired peer 18
05/01/24 17:15:16.468 Module HomeMatic Wired: Loading HomeMatic Wired peer 19
05/01/24 17:15:16.473 Module HomeMatic Wired: Loading HomeMatic Wired peer 20
05/01/24 17:15:16.486 Module HomeMatic Wired: Loading HomeMatic Wired peer 21
05/01/24 17:15:16.501 Loading XML RPC devices...
05/01/24 17:15:16.624 Loading device 3
05/01/24 17:15:16.624 Module MAX: Info: Central address set to 0xFDE6BD.
05/01/24 17:15:16.628 Loading XML RPC devices...
05/01/24 17:15:16.643 Warning: variables with id "custom_ch7_values" does not exist.
05/01/24 17:15:16.657 Warning: configParameters with id "config" does not exist.
05/01/24 17:15:16.668 Warning: variables with id "custom_ch7_values" does not exist.
05/01/24 17:15:16.671 Warning: configParameters with id "config" does not exist.
05/01/24 17:15:16.683 Loading device 4
05/01/24 17:15:16.687 Initializing RPC client...
05/01/24 17:15:16.687 Initializing RPC server RPCServer1 listening on :::2001...
05/01/24 17:15:16.734 Initializing RPC server RPCServer2 listening on :::2002, SSL enabled...
05/01/24 17:15:16.778 Initializing RPC server RPCServer3 listening on :::2003, SSL enabled, authentication enabled...
05/01/24 17:15:16.822 Initializing RPC server RPCServer4 listening on 127.0.0.1:2004...
05/01/24 17:15:16.867 Initializing RPC server WebServer1 listening on :::9080...
05/01/24 17:15:16.912 Initializing RPC server WebServer2 listening on :::9443, SSL enabled...
05/01/24 17:15:16.958 Start listening for packets...
05/01/24 17:15:16.963 Starting IPC server...
05/01/24 17:15:16.970 Starting Node-BLUE server...
05/01/24 17:15:16.970 Info: Stopping Node-PINK WebSockets.
05/01/24 17:15:16.973 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.974 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.975 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.976 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.978 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.979 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.980 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.981 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.982 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.983 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.984 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.985 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.986 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.987 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.988 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.989 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.989 Starting variable profile manager...
05/01/24 17:15:16.990 RPC Server (Port 2001): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unencrypted RPC servers when the connected clients support it.
05/01/24 17:15:16.990 RPC Server (Port 2001): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
05/01/24 17:15:16.990 RPC Server (Port 2001): Info: Enabling no authentication.
05/01/24 17:15:16.990 RPC Server (Port 2001): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:16.990 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:16.990 RPC Server (Port 2002): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
05/01/24 17:15:16.990 RPC Server (Port 2002): Info: Enabling no authentication.
05/01/24 17:15:16.990 RPC Server (Port 2002): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:17.039 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:17.039 RPC Server (Port 2003): Info: Enabling basic authentication.
05/01/24 17:15:17.039 RPC Server (Port 2003): Info: Enabling client certificate authentication.
05/01/24 17:15:17.039 RPC Server (Port 2003): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:17.077 RPC Server (Port 2004): Info: Enabling no authentication.
05/01/24 17:15:17.077 RPC Server (Port 2004): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:17.078 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:17.078 RPC Server (Port 9080): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unencrypted RPC servers when the connected clients support it.
05/01/24 17:15:17.079 RPC Server (Port 9080): Info: Enabling no authentication.
05/01/24 17:15:17.079 RPC Server (Port 9080): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:17.079 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:17.079 RPC Server (Port 9443): Info: Enabling no authentication.
05/01/24 17:15:17.079 RPC Server (Port 9443): Info: Enabling session authentication for WebSockets.
05/01/24 17:15:17.125 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:17.126 Critical: Can't start more threads. Thread limit reached (217 threads).
05/01/24 17:15:17.126 Startup complete. Waiting for physical interfaces to connect.
05/01/24 17:15:17.126 Info: Waiting for physical interfaces to connect (0 of 180s).
05/01/24 17:15:17.126 All physical interfaces are connected now.
05/01/24 17:15:17.126 Starting UPnP server...
05/01/24 17:15:17.127 Critical: Can't start more threads. Thread limit reached (217 threads).
It looks like I am not the only one who struggles to make the combo OH4 + HG work here. All help is appreciated! My house installation is “down” and I am a bit losing faith here.
By the way: homgear -r works and I can search and find all HG modules.
