Hallo Sathya,
im Augenblick kämpfe ich mit “zwei” Problemen.
Das größere ist, dass mein NAS (QNAP TP419P) plötzlich Fehler der folgenden Art produziert:
39029","Error","2015-01-24","21:29:55","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/def_share.info], section = [SHARE_DEF], field = [defVolMP], value = [/share/MD0_DATA]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39028","Error","2015-01-24","21:29:52","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [UPS], field = [Server Mode], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39027","Error","2015-01-24","21:29:50","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [UPS], field = [Server Mode], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39026","Error","2015-01-24","21:29:48","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [UPS], field = [Server Mode], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39025","Error","2015-01-24","21:29:46","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [UPS], field = [Server Mode], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39024","Error","2015-01-24","21:28:45","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/default_config/uLinux.conf], section = [QWEB], field = [PHP_ZEND_SUPPORT], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39023","Error","2015-01-24","21:28:42","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/smb.conf], section = [global], field = [cache directory]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39022","Error","2015-01-24","21:28:41","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/smb.conf], section = [global], field = [state directory]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
"39021","Error","2015-01-24","21:28:38","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/smb.conf], section = [global], field = [lock directory]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
und ich keine Ahnung habe, wo durch das aus gelöst wird.
Das Problem habe ich durch Neustarten des Server versucht zu lösen, was aber bisher nicht wirklich geklappt hat.
Im Augenblick läuft ein Disk Check (dauert wohl noch 3h).
Nebenbei habe ich ein zweites Problem festgestellt, nämlich, dass alle homegar Verzeichnisse und Dateien nach einem Reboot des Server verschwunden sind.
Es scheint so, als ob der Server seine Verzeichnisse von einer Backup Kopie lädt.
Kann das sein?
Wenn ja, wie muss mich meine homegar Verzeichnisse “überlebensfähig” machen?
Axel
