i’am pretty new to Homeautomation stuff.
I’ve a culfw flashed CUNO v2.5 from Busware. Has anyone already tested if it works with Homegear?
Hey,
no, the CUNO is not supported currently. The implementation is really, really, really easy though, as the CUL driver could be used. Only a TCP wrapper would be necessary. Maybe I will implement it in the beginning of January.
Regards,
Hi Sathya,
sounds really good.
Meanwhile i work with a COC solution and homegear which works like charm.
Regards
Guido
I found a patch in the FHEM forums to improve the timing of the CUNO dramatically: http://forum.fhem.de/index.php/topic,17635.msg158293.html#msg158293
Hey, wow!!!
Thank you so much
- I will try it tomorrow. A working CUNO would be really nice!
Cheers,
