Hi
trying to get the homegear migrated to docker I tried the homegear/homegear images on stable, testing and nightly.
as far as I can see the stable and testing run the same version 0.7. while nightly is based on 0.8.
nightly admin ui is working fine - also asking for creating the ca and successfully creating it.
As I would like to avoid running on the cutting bleeding edge I tried stable and testing. Here I observe that the admin ui is looking different. login is working but there is nothing more than some small settings for the account and a choice between Rooms and Devices on the top.
From the github I see that there are some fixes for the admin ui two days ago. Also the image testing reflect this:
REPOSITORY TAG IMAGE ID CREATED SIZE
homegear/homegear nightly 091a01ac93e8 5 hours ago 852MB
homegear/homegear testing c66d47d29a54 2 days ago 816MB
homegear/homegear stable 1d0c5ad845e1 7 days ago 815MB
So I would expect that stable is not yet working, but testing should - maybe I overseen something here.
or do you recommend to go for nightly?
cheers
