versuche gerade den Repeater von Homematic mit Homegear (Raspberry + CUL) zu nutzen!
Komme mit den Einstellung aber nicht ganz klar!
Hat jemaden einen Tipp oder Link!
Das scheinen die entscheidenen Werte zu sein, oder?
Was muss ich hier machen?
ADDRESS_RECEIVER1_HIGH_BYTE => 0
ADDRESS_RECEIVER1_LOW_BYTE => 0
ADDRESS_RECEIVER1_MID_BYTE
ADDRESS_SENDER1_HIGH_BYTE => 0
ADDRESS_SENDER1_LOW_BYTE => 0
ADDRESS_SENDER1_MID_BYTE => 0
BROADCAST_BEHAVIOR1 =>
Hier noch eine Gesamtübersicht
[code]GET ALL VALUES
Array
[0] => Array
[ADDRESS] => XXXXXXX
[CHANNELS] => Array
[0] => Array
[INDEX] => 0
[PARAMSET] => Array
[CENTRAL_ADDRESS_SPOOFED] => Array
[MAX] => 1
[MIN] => 0
[TYPE] => ENUM
[VALUE] => 0
[VALUE_LIST] => Array
[0] => UNSET
[1] => CENTRAL_ADDRESS_SPOOFED
[WRITEABLE] => 1
[CONFIG_PENDING] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[DEVICE_IN_BOOTLOADER] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[DUTYCYCLE] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[LOWBAT] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[RSSI_DEVICE] => Array
[MAX] => 2147483647
[MIN] => -2147483648
[TYPE] => INTEGER
[VALUE] => -60
[WRITEABLE] =>
[RSSI_PEER] => Array
[MAX] => 2147483647
[TYPE] => INTEGER
[VALUE] => 0
[WRITEABLE] =>
[STICKY_UNREACH] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] => 1
[UNREACH] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[UPDATE_PENDING] => Array
[TYPE] => BOOL
[VALUE] =>
[WRITEABLE] =>
[1] => Array
[INDEX] => 1
[PARAMSET] => Array
[FAMILY] => 0
[ID] => 42
[TYPE] =>
GET DEVICE INFO
Array
[ID] => 42
[INTERFACE] => My-CUL
[NAME] => GA_Repeater
[RSSI] => -60
GET ALL METADATA
Array
GET PARAMSET
Array
[0] => Array
[MASTER] => Array
[COMPATIBILITY_MODE] =>
[POLLING] =>
[POLLING_INTERVAL] => 60
[ROAMING] =>
[VALUES] => Array
[CENTRAL_ADDRESS_SPOOFED] => 0
[CONFIG_PENDING] =>
[DUTYCYCLE] =>
[LOWBAT] =>
[RSSI_DEVICE] => -60
[RSSI_PEER] => 0
[STICKY_UNREACH] =>
[UNREACH] =>
[UPDATE_PENDING] =>
[DESC-MASTER] => Array
[COMPATIBILITY_MODE] => Array
[DEFAULT] =>
[FLAGS] => 1
[ID] => COMPATIBILITY_MODE
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 0
[TYPE] => BOOL
[UNIT] =>
[POLLING] => Array
[DEFAULT] =>
[FLAGS] => 2
[ID] => POLLING
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 1
[TYPE] => BOOL
[UNIT] =>
[POLLING_INTERVAL] => Array
[DEFAULT] => 60
[FLAGS] => 2
[ID] => POLLING_INTERVAL
[MAX] => 1440
[MIN] => 10
[OPERATIONS] => 3
[TAB_ORDER] => 2
[TYPE] => INTEGER
[UNIT] => min
[ROAMING] => Array
[DEFAULT] =>
[FLAGS] => 2
[ID] => ROAMING
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 3
[TYPE] => BOOL
[UNIT] =>
[DESC-VALUES] => Array
[CONTROL] => NONE
[DEFAULT] => 0
[FLAGS] => 24
[ID] => CENTRAL_ADDRESS_SPOOFED
[MAX] => 1
[MIN] => 0
[OPERATIONS] => 7
[TAB_ORDER] => 9
[TYPE] => ENUM
[UNIT] =>
[0] => UNSET
[FLAGS] => 8
[ID] => CONFIG_PENDING
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 2
[TYPE] => BOOL
[UNIT] =>
[FLAGS] => 8
[ID] => DEVICE_IN_BOOTLOADER
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 7
[TYPE] => BOOL
[UNIT] =>
[FLAGS] => 8
[ID] => DUTYCYCLE
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 4
[TYPE] => BOOL
[UNIT] =>
[LOWBAT] => Array
[FLAGS] => 8
[ID] => LOWBAT
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 3
[TYPE] => BOOL
[UNIT] =>
[FLAGS] => 1
[ID] => RSSI_DEVICE
[MAX] => 2147483647
[OPERATIONS] => 5
[TAB_ORDER] => 5
[TYPE] => INTEGER
[UNIT] =>
[FLAGS] => 1
[ID] => RSSI_PEER
[MAX] => 2147483647
[OPERATIONS] => 5
[TAB_ORDER] => 6
[TYPE] => INTEGER
[UNIT] =>
[FLAGS] => 24
[ID] => STICKY_UNREACH
[MAX] => 1
[MIN] =>
[OPERATIONS] => 7
[TAB_ORDER] => 1
[TYPE] => BOOL
[UNIT] =>
[UNREACH] => Array
[FLAGS] => 8
[ID] => UNREACH
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 0
[TYPE] => BOOL
[UNIT] =>
[FLAGS] => 8
[ID] => UPDATE_PENDING
[MAX] => 1
[MIN] =>
[OPERATIONS] => 5
[TAB_ORDER] => 8
[TYPE] => BOOL
[UNIT] =>
[1] => Array
[MASTER] => Array
[ADDRESS_RECEIVER10_HIGH_BYTE] => 0
[ADDRESS_RECEIVER10_LOW_BYTE] => 0
[ADDRESS_RECEIVER10_MID_BYTE] => 0
[ADDRESS_RECEIVER11_HIGH_BYTE] => 0
[ADDRESS_RECEIVER11_LOW_BYTE] => 0
[ADDRESS_RECEIVER11_MID_BYTE] => 0
[ADDRESS_RECEIVER12_HIGH_BYTE] => 0
[ADDRESS_RECEIVER12_LOW_BYTE] => 0
[ADDRESS_RECEIVER12_MID_BYTE] => 0
[ADDRESS_RECEIVER13_HIGH_BYTE] => 0
[ADDRESS_RECEIVER13_LOW_BYTE] => 0
[ADDRESS_RECEIVER13_MID_BYTE] => 0
[ADDRESS_RECEIVER14_HIGH_BYTE] => 0
[ADDRESS_RECEIVER14_LOW_BYTE] => 0
[ADDRESS_RECEIVER14_MID_BYTE] => 0
[ADDRESS_RECEIVER15_HIGH_BYTE] => 0
[ADDRESS_RECEIVER15_LOW_BYTE] => 0
[ADDRESS_RECEIVER15_MID_BYTE] => 0
[ADDRESS_RECEIVER16_HIGH_BYTE] => 0
[ADDRESS_RECEIVER16_LOW_BYTE] => 0
[ADDRESS_RECEIVER16_MID_BYTE] => 0
[ADDRESS_RECEIVER17_HIGH_BYTE] => 0
[ADDRESS_RECEIVER17_LOW_BYTE] => 0
[ADDRESS_RECEIVER17_MID_BYTE] => 0
[ADDRESS_RECEIVER18_HIGH_BYTE] => 0
[ADDRESS_RECEIVER18_LOW_BYTE] => 0
[ADDRESS_RECEIVER18_MID_BYTE] => 0
[ADDRESS_RECEIVER19_HIGH_BYTE] => 0
[ADDRESS_RECEIVER19_LOW_BYTE] => 0
[ADDRESS_RECEIVER19_MID_BYTE] => 0
[ADDRESS_RECEIVER1_HIGH_BYTE] => 0
[ADDRESS_RECEIVER1_LOW_BYTE] => 0
[ADDRESS_RECEIVER1_MID_BYTE] => 0
[ADDRESS_RECEIVER20_HIGH_BYTE] => 0
[ADDRESS_RECEIVER20_LOW_BYTE] => 0
[ADDRESS_RECEIVER20_MID_BYTE] => 0
[ADDRESS_RECEIVER21_HIGH_BYTE] => 0
[ADDRESS_RECEIVER21_LOW_BYTE] => 0
[ADDRESS_RECEIVER21_MID_BYTE] => 0
[ADDRESS_RECEIVER22_HIGH_BYTE] => 0
[ADDRESS_RECEIVER22_LOW_BYTE] => 0
[ADDRESS_RECEIVER22_MID_BYTE] => 0
[ADDRESS_RECEIVER23_HIGH_BYTE] => 0
[ADDRESS_RECEIVER23_LOW_BYTE] => 0
[ADDRESS_RECEIVER23_MID_BYTE] => 0
[ADDRESS_RECEIVER24_HIGH_BYTE] => 0
[ADDRESS_RECEIVER24_LOW_BYTE] => 0
[ADDRESS_RECEIVER24_MID_BYTE] => 0
[ADDRESS_RECEIVER25_HIGH_BYTE] => 0
[ADDRESS_RECEIVER25_LOW_BYTE] => 0
[ADDRESS_RECEIVER25_MID_BYTE] => 0
[ADDRESS_RECEIVER26_HIGH_BYTE] => 0
[ADDRESS_RECEIVER26_LOW_BYTE] => 0
[ADDRESS_RECEIVER26_MID_BYTE] => 0
[ADDRESS_RECEIVER27_HIGH_BYTE] => 0
[ADDRESS_RECEIVER27_LOW_BYTE] => 0
[ADDRESS_RECEIVER27_MID_BYTE] => 0
[ADDRESS_RECEIVER28_HIGH_BYTE] => 0
[ADDRESS_RECEIVER28_LOW_BYTE] => 0
[ADDRESS_RECEIVER28_MID_BYTE] => 0
[ADDRESS_RECEIVER29_HIGH_BYTE] => 0
[ADDRESS_RECEIVER29_LOW_BYTE] => 0
[ADDRESS_RECEIVER29_MID_BYTE] => 0
[ADDRESS_RECEIVER2_HIGH_BYTE] => 0
[ADDRESS_RECEIVER2_LOW_BYTE] => 0
[ADDRESS_RECEIVER2_MID_BYTE] => 0
[ADDRESS_RECEIVER30_HIGH_BYTE] => 0
[ADDRESS_RECEIVER30_LOW_BYTE] => 0
[ADDRESS_RECEIVER30_MID_BYTE] => 0
[ADDRESS_RECEIVER31_HIGH_BYTE] => 0
[ADDRESS_RECEIVER31_LOW_BYTE] => 0
[ADDRESS_RECEIVER31_MID_BYTE] => 0
[ADDRESS_RECEIVER32_HIGH_BYTE] => 0
[ADDRESS_RECEIVER32_LOW_BYTE] => 0
[ADDRESS_RECEIVER32_MID_BYTE] => 0
[ADDRESS_RECEIVER33_HIGH_BYTE] => 0
[ADDRESS_RECEIVER33_LOW_BYTE] => 0
[ADDRESS_RECEIVER33_MID_BYTE] => 0
[ADDRESS_RECEIVER34_HIGH_BYTE] => 0
[ADDRESS_RECEIVER34_LOW_BYTE] => 0
[ADDRESS_RECEIVER34_MID_BYTE] => 0
[ADDRESS_RECEIVER35_HIGH_BYTE] => 0
[ADDRESS_RECEIVER35_LOW_BYTE] => 0
[ADDRESS_RECEIVER35_MID_BYTE] => 0
[ADDRESS_RECEIVER36_HIGH_BYTE] => 0
[ADDRESS_RECEIVER36_LOW_BYTE] => 0
[ADDRESS_RECEIVER36_MID_BYTE] => 0
[ADDRESS_RECEIVER3_HIGH_BYTE] => 0
[ADDRESS_RECEIVER3_LOW_BYTE] => 0
[ADDRESS_RECEIVER3_MID_BYTE] => 0
[ADDRESS_RECEIVER4_HIGH_BYTE] => 0
[ADDRESS_RECEIVER4_LOW_BYTE] => 0
[ADDRESS_RECEIVER4_MID_BYTE] => 0
[ADDRESS_RECEIVER5_HIGH_BYTE] => 0
[ADDRESS_RECEIVER5_LOW_BYTE] => 0
[ADDRESS_RECEIVER5_MID_BYTE] => 0
[ADDRESS_RECEIVER6_HIGH_BYTE] => 0
[ADDRESS_RECEIVER6_LOW_BYTE] => 0
[ADDRESS_RECEIVER6_MID_BYTE] => 0
[ADDRESS_RECEIVER7_HIGH_BYTE] => 0
[ADDRESS_RECEIVER7_LOW_BYTE] => 0
[ADDRESS_RECEIVER7_MID_BYTE] => 0
[ADDRESS_RECEIVER8_HIGH_BYTE] => 0
[ADDRESS_RECEIVER8_LOW_BYTE] => 0
[ADDRESS_RECEIVER8_MID_BYTE] => 0
[ADDRESS_RECEIVER9_HIGH_BYTE] => 0
[ADDRESS_RECEIVER9_LOW_BYTE] => 0
[ADDRESS_RECEIVER9_MID_BYTE] => 0
[ADDRESS_SENDER10_HIGH_BYTE] => 0
[ADDRESS_SENDER10_LOW_BYTE] => 0
[ADDRESS_SENDER10_MID_BYTE] => 0
[ADDRESS_SENDER11_HIGH_BYTE] => 0
[ADDRESS_SENDER11_LOW_BYTE] => 0
[ADDRESS_SENDER11_MID_BYTE] => 0
[ADDRESS_SENDER12_HIGH_BYTE] => 0
[ADDRESS_SENDER12_LOW_BYTE] => 0
[ADDRESS_SENDER12_MID_BYTE] => 0
[ADDRESS_SENDER13_HIGH_BYTE] => 0
[ADDRESS_SENDER13_LOW_BYTE] => 0
[ADDRESS_SENDER13_MID_BYTE] => 0
[ADDRESS_SENDER14_HIGH_BYTE] => 0
[ADDRESS_SENDER14_LOW_BYTE] => 0
[ADDRESS_SENDER14_MID_BYTE] => 0
[ADDRESS_SENDER15_HIGH_BYTE] => 0
[ADDRESS_SENDER15_LOW_BYTE] => 0
[ADDRESS_SENDER15_MID_BYTE] => 0
[ADDRESS_SENDER16_HIGH_BYTE] => 0
[ADDRESS_SENDER16_LOW_BYTE] => 0
[ADDRESS_SENDER16_MID_BYTE] => 0
[ADDRESS_SENDER17_HIGH_BYTE] => 0
[ADDRESS_SENDER17_LOW_BYTE] => 0
[ADDRESS_SENDER17_MID_BYTE] => 0
[ADDRESS_SENDER18_HIGH_BYTE] => 0
[ADDRESS_SENDER18_LOW_BYTE] => 0
[ADDRESS_SENDER18_MID_BYTE] => 0
[ADDRESS_SENDER19_HIGH_BYTE] => 0
[ADDRESS_SENDER19_LOW_BYTE] => 0
[ADDRESS_SENDER19_MID_BYTE] => 0
[ADDRESS_SENDER1_HIGH_BYTE] => 0
[ADDRESS_SENDER1_LOW_BYTE] => 0
[ADDRESS_SENDER1_MID_BYTE] => 0
[ADDRESS_SENDER20_HIGH_BYTE] => 0
[ADDRESS_SENDER20_LOW_BYTE] => 0
[ADDRESS_SENDER20_MID_BYTE] => 0
[ADDRESS_SENDER21_HIGH_BYTE] => 0
[ADDRESS_SENDER21_LOW_BYTE] => 0
[ADDRESS_SENDER21_MID_BYTE] => 0
[ADDRESS_SENDER22_HIGH_BYTE] => 0
[ADDRESS_SENDER22_LOW_BYTE] => 0
[ADDRESS_SENDER22_MID_BYTE] => 0
[ADDRESS_SENDER23_HIGH_BYTE] => 0
[ADDRESS_SENDER23_LOW_BYTE] => 0
[ADDRESS_SENDER23_MID_BYTE] => 0
[ADDRESS_SENDER24_HIGH_BYTE] => 0
[ADDRESS_SENDER24_LOW_BYTE] => 0
[ADDRESS_SENDER24_MID_BYTE] => 0
[ADDRESS_SENDER25_HIGH_BYTE] => 0
[ADDRESS_SENDER25_LOW_BYTE] => 0
[ADDRESS_SENDER25_MID_BYTE] => 0
[ADDRESS_SENDER26_HIGH_BYTE] => 0
[ADDRESS_SENDER26_LOW_BYTE] => 0
[ADDRESS_SENDER26_MID_BYTE] => 0
[ADDRESS_SENDER27_HIGH_BYTE] => 0
[ADDRESS_SENDER27_LOW_BYTE] => 0
[ADDRESS_SENDER27_MID_BYTE] => 0
[ADDRESS_SENDER28_HIGH_BYTE] => 0
[ADDRESS_SENDER28_LOW_BYTE] => 0
[ADDRESS_SENDER28_MID_BYTE] => 0
[ADDRESS_SENDER29_HIGH_BYTE] => 0
[ADDRESS_SENDER29_LOW_BYTE] => 0
[ADDRESS_SENDER29_MID_BYTE] => 0
[ADDRESS_SENDER2_HIGH_BYTE] => 0
[ADDRESS_SENDER2_LOW_BYTE] => 0
[ADDRESS_SENDER2_MID_BYTE] => 0
[ADDRESS_SENDER30_HIGH_BYTE] => 0
[ADDRESS_SENDER30_LOW_BYTE] => 0
[ADDRESS_SENDER30_MID_BYTE] => 0
[ADDRESS_SENDER31_HIGH_BYTE] => 0
[ADDRESS_SENDER31_LOW_BYTE] => 0
[ADDRESS_SENDER31_MID_BYTE] => 0
[ADDRESS_SENDER32_HIGH_BYTE] => 0
[ADDRESS_SENDER32_LOW_BYTE] => 0
[ADDRESS_SENDER32_MID_BYTE] => 0
[ADDRESS_SENDER33_HIGH_BYTE] => 0
[ADDRESS_SENDER33_LOW_BYTE] => 0
[ADDRESS_SENDER33_MID_BYTE] => 0
[ADDRESS_SENDER34_HIGH_BYTE] => 0
[ADDRESS_SENDER34_LOW_BYTE] => 0
[ADDRESS_SENDER34_MID_BYTE] => 0
[ADDRESS_SENDER35_HIGH_BYTE] => 0
[ADDRESS_SENDER35_LOW_BYTE] => 0
[ADDRESS_SENDER35_MID_BYTE] => 0
[ADDRESS_SENDER36_HIGH_BYTE] => 0
[ADDRESS_SENDER36_LOW_BYTE] => 0
[ADDRESS_SENDER36_MID_BYTE] => 0
[ADDRESS_SENDER3_HIGH_BYTE] => 0
[ADDRESS_SENDER3_LOW_BYTE] => 0
[ADDRESS_SENDER3_MID_BYTE] => 0
[ADDRESS_SENDER4_HIGH_BYTE] => 0
[ADDRESS_SENDER4_LOW_BYTE] => 0
[ADDRESS_SENDER4_MID_BYTE] => 0
[ADDRESS_SENDER5_HIGH_BYTE] => 0
[ADDRESS_SENDER5_LOW_BYTE] => 0
[ADDRESS_SENDER5_MID_BYTE] => 0
[ADDRESS_SENDER6_HIGH_BYTE] => 0
[ADDRESS_SENDER6_LOW_BYTE] => 0
[ADDRESS_SENDER6_MID_BYTE] => 0
[ADDRESS_SENDER7_HIGH_BYTE] => 0
[ADDRESS_SENDER7_LOW_BYTE] => 0
[ADDRESS_SENDER7_MID_BYTE] => 0
[ADDRESS_SENDER8_HIGH_BYTE] => 0
[ADDRESS_SENDER8_LOW_BYTE] => 0
[ADDRESS_SENDER8_MID_BYTE] => 0
[ADDRESS_SENDER9_HIGH_BYTE] => 0
[ADDRESS_SENDER9_LOW_BYTE] => 0
[ADDRESS_SENDER9_MID_BYTE] => 0
[AES_ACTIVE] =>
[BROADCAST_BEHAVIOR1] =>
[BROADCAST_BEHAVIOR10] =>
[BROADCAST_BEHAVIOR11] =>
[BROADCAST_BEHAVIOR12] =>
[BROADCAST_BEHAVIOR13] =>
[BROADCAST_BEHAVIOR14] =>
[BROADCAST_BEHAVIOR15] =>
[BROADCAST_BEHAVIOR16] =>
[BROADCAST_BEHAVIOR17] =>
[BROADCAST_BEHAVIOR18] =>
[BROADCAST_BEHAVIOR19] =>
[BROADCAST_BEHAVIOR2] =>
[BROADCAST_BEHAVIOR20] =>
[BROADCAST_BEHAVIOR21] =>
[BROADCAST_BEHAVIOR22] =>
[BROADCAST_BEHAVIOR23] =>
[BROADCAST_BEHAVIOR24] =>
[BROADCAST_BEHAVIOR25] =>
[BROADCAST_BEHAVIOR26] =>
[BROADCAST_BEHAVIOR27] =>
[BROADCAST_BEHAVIOR28] =>
[BROADCAST_BEHAVIOR29] =>
[BROADCAST_BEHAVIOR3] =>
[BROADCAST_BEHAVIOR30] =>
[BROADCAST_BEHAVIOR31] =>
[BROADCAST_BEHAVIOR32] =>
[BROADCAST_BEHAVIOR33] =>
[BROADCAST_BEHAVIOR34] =>
[BROADCAST_BEHAVIOR35] =>
[BROADCAST_BEHAVIOR36] =>
[BROADCAST_BEHAVIOR4] =>
[BROADCAST_BEHAVIOR5] =>
[BROADCAST_BEHAVIOR6] =>
[BROADCAST_BEHAVIOR7] =>
[BROADCAST_BEHAVIOR8] =>
[BROADCAST_BEHAVIOR9] =>
[VALUES] => Array
[ADDRESS_RECEIVER10_HIGH_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_RECEIVER10_HIGH_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 67
[TYPE] => INTEGER
[UNIT] =>
[ADDRESS_RECEIVER10_LOW_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_RECEIVER10_LOW_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 69
[TYPE] => INTEGER
[UNIT] =>
[ADDRESS_RECEIVER10_MID_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_RECEIVER10_MID_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 68
[TYPE] => INTEGER
[UNIT] =>
[ADDRESS_SENDER10_HIGH_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_SENDER10_HIGH_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 64
[TYPE] => INTEGER
[UNIT] =>
[ADDRESS_SENDER10_LOW_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_SENDER10_LOW_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 66
[TYPE] => INTEGER
[UNIT] =>
[ADDRESS_SENDER10_MID_BYTE] => Array
[DEFAULT] => 0
[FLAGS] => 1
[ID] => ADDRESS_SENDER10_MID_BYTE
[MAX] => 255
[MIN] => 0
[OPERATIONS] => 3
[TAB_ORDER] => 65
[TYPE] => INTEGER
[UNIT] =>
[AES_ACTIVE] => Array
[DEFAULT] =>
[FLAGS] => 2
[ID] => AES_ACTIVE
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 0
[TYPE] => BOOL
[UNIT] =>
[BROADCAST_BEHAVIOR1] => Array
[DEFAULT] =>
[FLAGS] => 1
[ID] => BROADCAST_BEHAVIOR1
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 7
[TYPE] => BOOL
[UNIT] =>
[BROADCAST_BEHAVIOR10] => Array
[DEFAULT] =>
[FLAGS] => 1
[ID] => BROADCAST_BEHAVIOR10
[MAX] => 1
[MIN] =>
[OPERATIONS] => 3
[TAB_ORDER] => 70
[TYPE] => BOOL
[UNIT] =>
GETSTATE
Array
[ID] => 42
[TYPE] => HM-Sys-sRP-Pl
[ADDRESS] => XXXXXX
[UNREACH] =>
[STICKY_UNREACH] =>
[UPDATE_PENDING] =>
[/code]
Danke schon mal im Voraus!
. Prinzipiell sollte er mit Homegear funktionieren, ich bin aber gespannt auf deine Rückmeldung. Generell würde ich aber eine Reichweitenerhöhung mit LAN-Kommunikationsmodulen (HM-CFG-LAN, LAN-Gateway, CUNX) empfehlen, da diese einfacher zu konfigurieren sind und diese auch keine Verzögerung einbauen (der Repeater verzögert den Paketempfang etwas).
