Hey there,
I’m trying to connect the Homematic HM-Sen-DB-PCB with openhabian.
Unfortunately, the pairing process within homegear isn’t working properly. And I’m feeling like I’m in over my head.
This is my current system:
homematicbidcos.conf looks like this:
[General]
moduleEnabled = true
centralAddress = 0xFDD394
rfKey = AF1623314455467FE819FABBCC5DFE5F
currentRfKeyIndex = 2
oldRfKey = 00112233445566778899AABBCCDDEEFF
[TI CC1101 Module]
id = My-C1101-Module
deviceType = cc1100
device = /dev/spidev0.0
responseDelay = 100
interruptPin = 0
gpio1 = 25
After trying to pair the device the homegear log looks like this:
02/06/20 07:41:27.364 Starting Homegear...
02/06/20 07:41:27.364 Homegear version 0.7.45-3101
02/06/20 07:41:27.364 Determining maximum thread count...
02/06/20 07:41:28.457 Maximum thread count is: 333
02/06/20 07:41:28.485 Info: Backing up database...
02/06/20 07:41:28.558 Initializing database...
02/06/20 07:41:28.876 Debug: Loading licensing modules
02/06/20 07:41:28.877 Initializing system variable controller...
02/06/20 07:41:28.880 Debug: Loading family modules
02/06/20 07:41:28.880 Info: Loading family module (type 1) mod_miscellaneous.so
02/06/20 07:41:28.894 Info: Loading settings from /etc/homegear/families/miscellaneous.conf
02/06/20 07:41:28.900 Module Miscellaneous: Debug: Loading module...
02/06/20 07:41:28.900 Info: Loading family module (type 1) mod_homematicbidcos.so
02/06/20 07:41:28.931 Info: Loading settings from /etc/homegear/families/homematicbidcos.conf
02/06/20 07:41:28.932 Debug: Loading section "General"
02/06/20 07:41:28.933 Debug: Family setting moduleenabled set to true
02/06/20 07:41:28.933 Debug: Family setting centraladdress set to 0xfdd394
02/06/20 07:41:28.933 Debug: Family setting rfkey set to af1623314455467fe819fabbcc5dfe5f
02/06/20 07:41:28.933 Debug: Family setting currentrfkeyindex set to 2
02/06/20 07:41:28.933 Debug: Family setting oldrfkey set to 00112233445566778899aabbccddeeff
02/06/20 07:41:28.933 Debug: Family setting processbroadcastwithaesenabled set to false
02/06/20 07:41:28.933 Debug: Loading section "TI CC1101 Module"
02/06/20 07:41:28.933 Debug: id set to My-C1101-Module
02/06/20 07:41:28.933 Debug: default set to 1
02/06/20 07:41:28.933 Debug: deviceType set to cc1100
02/06/20 07:41:28.933 Debug: device set to /dev/spidev0.0
02/06/20 07:41:28.933 Debug: responseDelay set to 100
02/06/20 07:41:28.933 Debug: interruptPin set to 0
02/06/20 07:41:28.933 Debug: GPIO1 set to 25
02/06/20 07:41:28.933 Module HomeMatic BidCoS: Debug: Loading module...
02/06/20 07:41:28.937 Module HomeMatic BidCoS: Debug: Creating physical device. Type defined in homematicbidcos.conf is: cc1100
02/06/20 07:41:28.941 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: PATABLE will be set to 0xC0
02/06/20 07:41:28.942 Info: Loading family module (type 1) mod_homematicwired.so
02/06/20 07:41:28.964 Info: Loading settings from /etc/homegear/families/homematicwired.conf
02/06/20 07:41:28.965 Debug: Loading section "General"
02/06/20 07:41:28.965 Debug: Family setting moduleenabled set to true
02/06/20 07:41:28.966 Module HomeMatic Wired: Debug: Loading module...
02/06/20 07:41:28.969 Info: Setting up physical interfaces and GPIOs...
02/06/20 07:41:28.969 Debug: Setting up physical device.
02/06/20 07:41:28.969 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: CC1100: Setting device permissions
02/06/20 07:41:28.969 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: CC1100: Exporting GPIO
02/06/20 07:41:28.969 Debug: Exporting GPIO with index 1 and number 25 for device "cc1100".
02/06/20 07:41:28.970 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: CC1100: Setting GPIO permissions
02/06/20 07:41:28.970 Debug: GPIO path for GPIO with index 1 and device cc1100 set to "/sys/class/gpio/gpio25".
02/06/20 07:41:28.980 Info: Dropping privileges to user homegear (111) and group homegear (118)
02/06/20 07:41:28.981 Info: Homegear is (now) running as user with id 111 and group with id 118.
02/06/20 07:41:29.035 Starting script engine server...
02/06/20 07:41:29.062 Script Engine Server: Debug: Waiting for script engine server's client threads to finish.
02/06/20 07:41:29.070 Initializing licensing controller...
02/06/20 07:41:29.070 Loading licensing controller data...
02/06/20 07:41:29.070 Loading devices...
02/06/20 07:41:29.070 Loading XML RPC devices...
02/06/20 07:41:29.078 Loading XML RPC device /etc/homegear/devices/0/rf_s_4_ba.xml
02/06/20 07:41:29.087 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644.xml
02/06/20 07:41:29.100 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir.xml
02/06/20 07:41:29.102 Loading XML RPC device /etc/homegear/devices/0/rf_sc_le_v1_6.xml
02/06/20 07:41:29.104 Loading XML RPC device /etc/homegear/devices/0/rf_roto_wdf_solar.xml
02/06/20 07:41:29.114 Loading XML RPC device /etc/homegear/devices/0/rf_bl.xml
02/06/20 07:41:29.120 Loading XML RPC device /etc/homegear/devices/0/rf_rc_2_fm.xml
02/06/20 07:41:29.122 Loading XML RPC device /etc/homegear/devices/0/rf_cf.xml
02/06/20 07:41:29.128 Loading XML RPC device /etc/homegear/devices/0/rf_ash550.xml
02/06/20 07:41:29.129 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644_le_v2_4.xml
02/06/20 07:41:29.141 Loading XML RPC device /etc/homegear/devices/0/rf_dis_ep_wm55_le_v1_0.xml
02/06/20 07:41:29.143 Loading XML RPC device /etc/homegear/devices/0/rf_sen_li.xml
02/06/20 07:41:29.145 Loading XML RPC device /etc/homegear/devices/0/rf_hm-wds100-c6-o-2.xml
02/06/20 07:41:29.148 Loading XML RPC device /etc/homegear/devices/0/rf_scd_v1_0.xml
02/06/20 07:41:29.149 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2.xml
02/06/20 07:41:29.151 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644.xml
02/06/20 07:41:29.164 Loading XML RPC device /etc/homegear/devices/0/rf_ja_conf_644.xml
02/06/20 07:41:29.170 Loading XML RPC device /etc/homegear/devices/0/rf_keymatic.xml
02/06/20 07:41:29.173 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_fm_lf.xml
02/06/20 07:41:29.179 Loading XML RPC device /etc/homegear/devices/0/rf_rc_dis.xml
02/06/20 07:41:29.181 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn_bom.xml
02/06/20 07:41:29.194 Loading XML RPC device /etc/homegear/devices/0/rf_rc-sec4-2.xml
02/06/20 07:41:29.197 Loading XML RPC device /etc/homegear/devices/0/rf_rgbw.xml
02/06/20 07:41:29.202 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644_le_v2_4.xml
02/06/20 07:41:29.215 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644.xml
02/06/20 07:41:29.226 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_dr.xml
02/06/20 07:41:29.238 Loading XML RPC device /etc/homegear/devices/0/rf_s550ia.xml
02/06/20 07:41:29.239 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_9.xml
02/06/20 07:41:29.245 Loading XML RPC device /etc/homegear/devices/0/rf_cfm.xml
02/06/20 07:41:29.251 Loading XML RPC device /etc/homegear/devices/0/rf_s.xml
02/06/20 07:41:29.257 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644_le_v2_4.xml
02/06/20 07:41:29.269 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_2.xml
02/06/20 07:41:29.272 Loading XML RPC device /etc/homegear/devices/0/rf_rhs.xml
02/06/20 07:41:29.276 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_le_v1_3.xml
02/06/20 07:41:29.277 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_schueco.xml
02/06/20 07:41:29.279 Loading XML RPC device /etc/homegear/devices/0/rf_tis.xml
02/06/20 07:41:29.281 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sfa.xml
02/06/20 07:41:29.285 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_0.xml
02/06/20 07:41:29.291 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644.xml
02/06/20 07:41:29.304 Loading XML RPC device /etc/homegear/devices/0/rf_tis_le_v1_0.xml
02/06/20 07:41:29.305 Loading XML RPC device /etc/homegear/devices/0/rf_sc_e_v1_7.xml
02/06/20 07:41:29.307 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd.xml
02/06/20 07:41:29.309 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir_v1_5.xml
02/06/20 07:41:29.310 Loading XML RPC device /etc/homegear/devices/0/rf_oligo_smart_iq.xml
02/06/20 07:41:29.346 Loading XML RPC device /etc/homegear/devices/0/rf_rc-key4-2.xml
02/06/20 07:41:29.349 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_e_v1_7.xml
02/06/20 07:41:29.353 Loading XML RPC device /etc/homegear/devices/0/rf_s_2conf_644.xml
02/06/20 07:41:29.359 Loading XML RPC device /etc/homegear/devices/0/rf_cc_vd.xml
02/06/20 07:41:29.360 Loading XML RPC device /etc/homegear/devices/0/rf_dis_wm55.xml
02/06/20 07:41:29.362 Loading XML RPC device /etc/homegear/devices/0/rf_pbi.xml
02/06/20 07:41:29.364 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc_le_v1_9.xml
02/06/20 07:41:29.378 Loading XML RPC device /etc/homegear/devices/0/rf_ao.xml
02/06/20 07:41:29.390 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir.xml
02/06/20 07:41:29.391 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm_le_v1_0.xml
02/06/20 07:41:29.394 Loading XML RPC device /etc/homegear/devices/0/rf_em_8.xml
02/06/20 07:41:29.397 Loading XML RPC device /etc/homegear/devices/0/rf_rc_12.xml
02/06/20 07:41:29.399 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm.xml
02/06/20 07:41:29.402 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644_le_v2_4.xml
02/06/20 07:41:29.413 Loading XML RPC device /etc/homegear/devices/0/rf_bl_le_v2_3.xml
02/06/20 07:41:29.420 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_0.xml
02/06/20 07:41:29.422 Loading XML RPC device /etc/homegear/devices/0/rf_bl_644.xml
02/06/20 07:41:29.427 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_ge_v1_1.xml
02/06/20 07:41:29.432 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t_le_v1_9.xml
02/06/20 07:41:29.437 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644.xml
02/06/20 07:41:29.450 Loading XML RPC device /etc/homegear/devices/0/rf_swi.xml
02/06/20 07:41:29.451 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v1_5.xml
02/06/20 07:41:29.455 Loading XML RPC device /etc/homegear/devices/0/rf_4dis.xml
02/06/20 07:41:29.457 Loading XML RPC device /etc/homegear/devices/0/rf_cfm_tw.xml
02/06/20 07:41:29.464 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v2_3.xml
02/06/20 07:41:29.468 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw_le_v2_4.xml
02/06/20 07:41:29.477 Loading XML RPC device /etc/homegear/devices/0/rf_rc.xml
02/06/20 07:41:29.479 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644.xml
02/06/20 07:41:29.486 Loading XML RPC device /etc/homegear/devices/0/rf_cm.xml
02/06/20 07:41:29.490 Loading XML RPC device /etc/homegear/devices/0/rf_s_mega168.xml
02/06/20 07:41:29.494 Loading XML RPC device /etc/homegear/devices/0/rf_d.xml
02/06/20 07:41:29.503 Loading XML RPC device /etc/homegear/devices/0/rf_sc.xml
02/06/20 07:41:29.505 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-2.xml
02/06/20 07:41:29.509 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sco.xml
02/06/20 07:41:29.512 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644.xml
02/06/20 07:41:29.517 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_3.xml
02/06/20 07:41:29.524 Loading XML RPC device /etc/homegear/devices/0/rf_dis_ep_wm55.xml
02/06/20 07:41:29.527 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644.xml
02/06/20 07:41:29.541 Loading XML RPC device /etc/homegear/devices/0/rf_winmatic.xml
02/06/20 07:41:29.549 Loading XML RPC device /etc/homegear/devices/0/rf_rc_19.xml
02/06/20 07:41:29.553 Loading XML RPC device /etc/homegear/devices/0/rf_rc_single_on.xml
02/06/20 07:41:29.554 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_le_v1_0.xml
02/06/20 07:41:29.556 Loading XML RPC device /etc/homegear/devices/0/rf_wds40_th_i_2.xml
02/06/20 07:41:29.557 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_1.xml
02/06/20 07:41:29.561 Loading XML RPC device /etc/homegear/devices/0/rf_st_6_sh.xml
02/06/20 07:41:29.564 Loading XML RPC device /etc/homegear/devices/0/rf_resc_win_pcb_sc.xml
02/06/20 07:41:29.570 Loading XML RPC device /etc/homegear/devices/0/rf_ws550.xml
02/06/20 07:41:29.572 Loading XML RPC device /etc/homegear/devices/0/rf_em_8_bit.xml
02/06/20 07:41:29.585 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_1.xml
02/06/20 07:41:29.589 Loading XML RPC device /etc/homegear/devices/0/rf_s_8_ba.xml
02/06/20 07:41:29.594 Loading XML RPC device /etc/homegear/devices/0/rf_rd_le_v1_3.xml
02/06/20 07:41:29.596 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw.xml
02/06/20 07:41:29.604 Loading XML RPC device /etc/homegear/devices/0/rf_fs_ba.xml
02/06/20 07:41:29.608 Loading XML RPC device /etc/homegear/devices/0/rf_rep.xml
02/06/20 07:41:29.617 Loading XML RPC device /etc/homegear/devices/0/rf_sen_wa_od.xml
02/06/20 07:41:29.620 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_wm55.xml
02/06/20 07:41:29.623 Loading XML RPC device /etc/homegear/devices/0/rf_sen_ep.xml
02/06/20 07:41:29.625 Loading XML RPC device /etc/homegear/devices/0/rf_ddc.xml
02/06/20 07:41:29.629 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2pwm.xml
02/06/20 07:41:29.669 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644_le_v2_4.xml
02/06/20 07:41:29.683 Loading XML RPC device /etc/homegear/devices/0/rf_dw.xml
02/06/20 07:41:29.719 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sir_wm.xml
02/06/20 07:41:29.730 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_le_v1_6.xml
02/06/20 07:41:29.732 Loading XML RPC device /etc/homegear/devices/0/rf_sci_3.xml
02/06/20 07:41:29.735 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn.xml
02/06/20 07:41:29.747 Loading XML RPC device /etc/homegear/devices/0/rf_s_644.xml
02/06/20 07:41:29.751 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_1.xml
02/06/20 07:41:29.760 Loading XML RPC device /etc/homegear/devices/0/rf_tc_it_wm-w-eu.xml
02/06/20 07:41:29.788 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_ge_v1_4.xml
02/06/20 07:41:29.792 Loading XML RPC device /etc/homegear/devices/0/rf_s_ba.xml
02/06/20 07:41:29.796 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644_le_v2_4.xml
02/06/20 07:41:29.809 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_7.xml
02/06/20 07:41:29.814 Loading XML RPC device /etc/homegear/devices/0/rf_wds30_ot2.xml
02/06/20 07:41:29.816 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t.xml
02/06/20 07:41:29.823 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_v1_5.xml
02/06/20 07:41:29.826 Loading XML RPC device /etc/homegear/devices/0/rf_ks550.xml
02/06/20 07:41:29.827 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc.xml
02/06/20 07:41:29.845 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-3_single_on.xml
02/06/20 07:41:29.847 Loading XML RPC device /etc/homegear/devices/0/rf_sen_db.xml
02/06/20 07:41:29.850 Loading XML RPC device /etc/homegear/devices/0/rf_rd.xml
02/06/20 07:41:29.854 Loading device 1
02/06/20 07:41:29.864 Module HomeMatic BidCoS: Info: Central address set to 0xFDD394.
02/06/20 07:41:29.868 Loading XML RPC devices...
02/06/20 07:41:29.869 Loading XML RPC device /etc/homegear/devices/1/hmw_lc_bl1_dr_V3_02.xml
02/06/20 07:41:29.873 Loading XML RPC device /etc/homegear/devices/1/hmw_lc_sw2_dr.xml
02/06/20 07:41:29.878 Loading XML RPC device /etc/homegear/devices/1/hmw_lc_bl1_dr.xml
02/06/20 07:41:29.884 Loading XML RPC device /etc/homegear/devices/1/hmw_sen_sc_12_dr.xml
02/06/20 07:41:29.885 Loading XML RPC device /etc/homegear/devices/1/hmw_io12_sw7_dr.xml
02/06/20 07:41:29.889 Loading XML RPC device /etc/homegear/devices/1/hmw_lc_sw2_dr_V3_02.xml
02/06/20 07:41:29.892 Loading XML RPC device /etc/homegear/devices/1/hmw_io_sr_fm.xml
02/06/20 07:41:29.895 Loading XML RPC device /etc/homegear/devices/1/hmw_lc_dim1l_dr.xml
02/06/20 07:41:29.901 Loading XML RPC device /etc/homegear/devices/1/hmw_io_4_fm_V3_02.xml
02/06/20 07:41:29.904 Loading XML RPC device /etc/homegear/devices/1/hmw_io12_sw14_dr.xml
02/06/20 07:41:29.905 Loading XML RPC device /etc/homegear/devices/1/hmw_io12_sw7_dr_V3_02.xml
02/06/20 07:41:29.912 Loading XML RPC device /etc/homegear/devices/1/hmw_io_12_fm.xml
02/06/20 07:41:29.917 Loading XML RPC device /etc/homegear/devices/1/hmw_io_4_fm.xml
02/06/20 07:41:29.921 Loading device 2
02/06/20 07:41:29.924 Loading XML RPC devices...
02/06/20 07:41:29.925 Loading XML RPC device /etc/homegear/devices/254/VirtualWindowContact.xml
02/06/20 07:41:29.926 Warning: configParameters with id "config" does not exist.
02/06/20 07:41:29.929 Loading XML RPC device /etc/homegear/devices/254/VirtualDimmer.xml
02/06/20 07:41:29.931 Loading XML RPC device /etc/homegear/devices/254/VirtualThermostat.xml
02/06/20 07:41:29.932 Loading XML RPC device /etc/homegear/devices/254/OpenWeatherMap.xml
02/06/20 07:41:29.934 Loading XML RPC device /etc/homegear/devices/254/VirtualSwitch.xml
02/06/20 07:41:29.935 Loading XML RPC device /etc/homegear/devices/254/VirtualBlind.xml
02/06/20 07:41:29.936 Loading device 3
02/06/20 07:41:29.938 Initializing RPC client...
02/06/20 07:41:29.938 Starting XML RPC server RPCServer1 listening on :::2001...
02/06/20 07:41:29.963 RPC Server (Port 2001): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unencrypted RPC servers when the connected clients support it.
02/06/20 07:41:29.963 RPC Server (Port 2001): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
02/06/20 07:41:29.963 RPC Server (Port 2001): Info: Enabling no authentication.
02/06/20 07:41:29.963 RPC Server (Port 2001): Info: Enabling session authentication for WebSockets.
02/06/20 07:41:29.964 Starting XML RPC server RPCServer2 listening on :::2002, SSL enabled...
02/06/20 07:41:29.964 RPC Server (Port 2001): Info: RPC Server started listening on address :: and port 2001
02/06/20 07:41:29.995 RPC Server (Port 2002): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
02/06/20 07:41:29.995 RPC Server (Port 2002): Info: Enabling no authentication.
02/06/20 07:41:29.995 RPC Server (Port 2002): Info: Enabling session authentication for WebSockets.
02/06/20 07:41:30.037 Starting XML RPC server RPCServer3 listening on :::2003, SSL enabled, authentication enabled...
02/06/20 07:41:30.037 RPC Server (Port 2002): Info: RPC Server started listening on address :: and port 2002
02/06/20 07:41:30.063 RPC Server (Port 2003): Info: Enabling basic authentication.
02/06/20 07:41:30.063 RPC Server (Port 2003): Info: Enabling client certificate authentication.
02/06/20 07:41:30.063 RPC Server (Port 2003): Info: Enabling session authentication for WebSockets.
02/06/20 07:41:30.084 Initializing event handler...
02/06/20 07:41:30.085 Loading events...
02/06/20 07:41:30.085 Start listening for packets...
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 30
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 005B
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8000
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 005B
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 012E
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8100
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 002E
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0246
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8200
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0046
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0307
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8300
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0007
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 04E9
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8400
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00E9
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 05CA
02/06/20 07:41:30.087 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8500
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00CA
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 06FF
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8600
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00FF
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 070C
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8700
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 000C
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0845
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8800
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0045
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0900
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8900
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0000
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0A00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8A00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0B06
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8B00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0006
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0C00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8C00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0D21
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8D00
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0021
02/06/20 07:41:30.088 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0E65
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8E00
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0065
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 0F6A
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 8F00
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 006A
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 10C8
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9000
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00C8
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1193
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9100
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0093
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1203
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9200
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0003
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1322
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9300
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0022
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 14F8
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9400
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00F8
02/06/20 07:41:30.089 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1534
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9500
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0034
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1607
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9600
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0007
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1730
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9700
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0030
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1818
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9800
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0018
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1916
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9900
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0016
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1A6C
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9A00
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 006C
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1B03
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9B00
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0003
02/06/20 07:41:30.090 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1C40
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9C00
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0040
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1D91
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9D00
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0091
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1E87
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9E00
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0087
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 1F6B
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 9F00
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 006B
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 20F8
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A000
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00F8
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2156
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A100
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0056
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2210
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A200
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0010
02/06/20 07:41:30.091 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 23E9
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A300
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00E9
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 242A
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A400
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 002A
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2500
02/06/20 07:41:30.092 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A500
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0000
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 261F
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A600
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 001F
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2741
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A700
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0041
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2800
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A800
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2959
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: A900
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0059
02/06/20 07:41:30.096 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2C81
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F0F
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: AC00
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0081
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 2D35
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: AD00
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0035
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 3EC0
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: BE00
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 00C0
02/06/20 07:41:30.097 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 3A
02/06/20 07:41:30.098 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 0F
02/06/20 07:41:30.098 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 34
02/06/20 07:41:30.098 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: CC1100: Setting GPIO direction
02/06/20 07:41:30.098 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: CC1100: Setting GPIO edge
02/06/20 07:41:30.098 Starting IPC server...
02/06/20 07:41:30.098 IPC Server: Debug: Waiting for IPC server's client threads to finish.
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: F300
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 1000
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: BidCoS packet received, but CRC failed.
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 3A
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Received: 1F
02/06/20 07:41:30.099 Module HomeMatic BidCoS: TI CC110X "My-C1101-Module": Debug: Sending: 34
02/06/20 07:41:30.106 Starting Node-BLUE server...
02/06/20 07:41:30.106 Node-BLUE Server: Debug: Waiting for flows engine server's client threads to finish.
02/06/20 07:41:30.119 Startup complete. Waiting for physical interfaces to connect.
02/06/20 07:41:30.119 Info: Waiting for physical interfaces to connect (0 of 180s).
02/06/20 07:41:30.119 All physical interfaces are connected now.
02/06/20 07:41:30.119 Starting UPnP server...
02/06/20 07:41:35.119 UPnP Server: Info: UPnP server: Binding to address: 192.168.178.50
02/06/20 07:41:35.120 UPnP Server: Debug: Sending notify packets.
02/06/20 07:41:35.128 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.24:51531 accepted. Client number: 11
02/06/20 07:41:35.128 RPC Server (Port 2001): Info: RPC server client id for client number 11 is: 0
02/06/20 07:41:35.129 RPC Server (Port 2001): Listening for incoming packets from client number 11.
02/06/20 07:41:35.131 RPC Server (Port 2001): Debug: Packet received: 474554202F6465736372697074696F6E2E786D6C20485454502F312E310D0A486F73743A203139322E3136382E3137382E35303A323030310D0A436F6E74656E742D747970653A206170706C69636174696F6E2F782D7777772D666F726D2D75726C656E636F6465640D0A0D0A
02/06/20 07:41:35.153 RPC Server (Port 2001): Debug: Connection to client number 11 closed.
02/06/20 07:41:35.153 RPC Server (Port 2001): Debug: Connection to client number 11 closed (1).
02/06/20 07:42:05.437 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:05.457 UPnP Server: Debug: Sleeping 879ms before sending response.
02/06/20 07:42:06.336 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:06.437 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:06.437 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:06.457 UPnP Server: Debug: Sleeping 2195ms before sending response.
02/06/20 07:42:08.653 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:08.753 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:08.753 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:08.773 UPnP Server: Debug: Sleeping 1430ms before sending response.
02/06/20 07:42:10.204 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:10.304 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:10.304 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:10.325 UPnP Server: Debug: Sleeping 2399ms before sending response.
02/06/20 07:42:12.724 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:12.825 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:12.825 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:12.845 UPnP Server: Debug: Sleeping 454ms before sending response.
02/06/20 07:42:13.299 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:13.400 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:13.400 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/06/20 07:42:13.421 UPnP Server: Debug: Sleeping 1687ms before sending response.
02/06/20 07:42:15.108 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/06/20 07:42:15.208 UPnP Server: Debug: Sending notify packets.
02/06/20 07:42:30.074 RPC Server (Port 2001): Debug: Joining read thread of client 0
02/06/20 07:42:30.074 RPC Server (Port 2001): Debug: Client 0 removed.
02/06/20 07:42:50.667 IPC Server: Info: Connection accepted. Client number: 0, file descriptor ID: 12
02/06/20 07:42:50.667 IPC Server: Info: Client number 0 is calling RPC method: setPid
(Integer64) 3035
02/06/20 07:42:50.668 IPC Server: Response:
(void)
02/06/20 07:42:50.668 IPC Server: Info: Client number 0 is calling RPC method: registerRpcMethod
(String) cliOutput
(Array length=1)
(Array length=2)
(void)
(String)
02/06/20 07:42:50.669 IPC Server: Info: Client 0 successfully registered RPC method "cliOutput" (this method is registered by 1 client(s)).
02/06/20 07:42:50.669 IPC Server: Response:
(void)
02/06/20 07:42:50.669 IPC Server: Info: Client number 0 is calling RPC method: getClientId
(Integer) 0
02/06/20 07:42:50.670 IPC Server: Info: Client number 0 is calling RPC method: registerRpcMethod
(String) cliOutput-0
(Array length=1)
(Array length=2)
(void)
(String)
02/06/20 07:42:50.670 IPC Server: Info: Client 0 successfully registered RPC method "cliOutput-0" (this method is registered by 1 client(s)).
02/06/20 07:42:50.670 IPC Server: Response:
(void)
02/06/20 07:42:54.137 IPC Server: Info: Client number 0 is calling RPC method: cliGeneralCommand
(String) ls
02/06/20 07:42:54.137 IPC Server: Debug: CLI client 0 is executing command: ls
02/06/20 07:42:54.138 IPC Server: Response:
(String) ID │ Name
0 │ HomeMatic BidCoS
1 │ HomeMatic Wired
254 │ Miscellaneous
02/06/20 07:42:56.914 IPC Server: Info: Client number 0 is calling RPC method: familyExists Parameters:
(Integer64) 0
02/06/20 07:42:56.914 IPC Server: Response:
(Boolean) 1
02/06/20 07:43:00.266 IPC Server: Info: Client number 0 is calling RPC method: cliFamilyCommand
(Integer64) 0
(String) pon
02/06/20 07:43:00.267 IPC Server: Debug: CLI client 0 is executing family command: pon
02/06/20 07:43:00.267 IPC Server: Response:
(String) Pairing mode enabled for 60 seconds.
02/06/20 07:43:15.077 UPnP Server: Debug: Sending notify packets.
02/06/20 07:44:15.099 UPnP Server: Debug: Sending notify packets.
02/06/20 07:45:15.062 UPnP Server: Debug: Sending notify packets.
02/06/20 07:46:11.623 IPC Server: Info: Connection to IPC server's client number 0 closed.
02/06/20 07:46:15.002 UPnP Server: Debug: Sending notify packets.
When testing for SPI config with ls -l /dev/spi* I get these results
crw-rw---- 1 homegear homegear 153, 0 Feb 6 07:41 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Feb 6 07:41 /dev/spidev0.1
And SPI testing looks like this:
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@....▒..................▒.
RX | 10 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF | ................................
Can you point me into a direction where to look for the reason for the issue?
