HM-Sec-SCo
die Homegear Version 0.7.11-1472 läuft mit mehr als 40 Homematic Geräten stabil, nur mit einem neuen Fensterkontakt taucht plötzlich ein Verbindungsproblem auf:
12/20/17 17:19:07.038 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 192CA603564783FD203F336F86246B02358D285979B7A880C831
12/20/17 17:19:07.039 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C2CA641564783FD203F010C00
12/20/17 17:19:07.672 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 112DA002FD203F5647830437A52800B29700
12/20/17 17:19:07.838 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 192DA603564783FD203FBA2278EFBDBAD7C9CC8970EA84920332
12/20/17 17:19:07.838 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C2DA641564783FD203F010C00
12/20/17 17:19:08.756 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 112EA002FD203F56478304C06E2E6709B300
12/20/17 17:19:08.922 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 192EA603564783FD203F7C3AFE9226560A8F5DB120489A310D42
12/20/17 17:19:08.922 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C2EA641564783FD203F010C00
12/20/17 17:19:10.174 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 112FA002FD203F56478304DA501C91DDBC00
12/20/17 17:19:10.341 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 192FA603564783FD203F11BBBD02AFDF5C920C2D6FEE4B9E8206
12/20/17 17:19:10.341 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C2FA641564783FD203F010C00
12/20/17 17:19:11.700 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 1130A002FD203F56478304B889A96B6ED000
12/20/17 17:19:11.866 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 1930A603564783FD203F7C3974C048E5B83BE33619EBE11EAE87
12/20/17 17:19:11.866 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C30A641564783FD203F010C00
12/20/17 17:19:13.721 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 1131A002FD203F564783046F86E15460B000
12/20/17 17:19:13.886 Module HomeMatic BidCoS: CUL "My-CUL": Info: r-Frame is: 1931A603564783FD203F56B0D7894A3BFC2FD661BE3F19816787
12/20/17 17:19:13.887 Module HomeMatic BidCoS: CUL "My-CUL": Error: AES handshake failed for packet: 0C31A641564783FD203F010C00
Dies scheint für alle Kommunikation (ausser dem RSSI Status-Bericht) der Fall zu sein.
Gibt es noch das AES-Problem, welches hier im Forum vor Jahren diskutiert wurde?
Viele Grüsse, Günther
Hallo @gs4711,
nein, AES sollte keine Probleme machen, außer das Gerät befindet sich am Rande der Funkreichweite. Funktioniert der Fensterkontakt denn generell? Poste mal das normale Log vom Öffnen oder Schließen des Kontaktes.
Hallo Sathya,
der Fensterkontakt funktioniert nun nach Ausschalten des AES ohne Probleme. Sobald ich AES anschalte, geht das Gerät in “unreachable”.
So sieht das log bei non-AES aus:
01/07/18 21:26:51.145 HomeMatic BidCoS packet received (My-CUL, RSSI: -50 dBm): 0F4A8610455AF20000000AA8E00C3C00
01/07/18 21:26:52.090 HomeMatic BidCoS packet received (My-CUL, RSSI: -103 dBm): 0C76A641564783FD203F018D00
01/07/18 21:26:54.537 HomeMatic BidCoS packet received (My-CUL, RSSI: -90 dBm): 0C79A641564783FD203F018D00
01/07/18 21:27:03.879 HomeMatic BidCoS packet received (My-CUL, RSSI: -94 dBm): 0FF080023F725DFD203F010409205800
01/07/18 21:27:04.162 HomeMatic BidCoS packet received (My-CUL, RSSI: -59 dBm): 14EE845E3289C600000080027B0000000000091301
01/07/18 21:27:05.100 HomeMatic BidCoS packet received (My-CUL, RSSI: -78 dBm): 0F2F80023F7215FD203F010409004D00
01/07/18 21:08:23.674 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:17:29.732 Module HomeMatic BidCoS: Info: ERROR on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:17:29.732 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:17:29.732 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:17:29.732 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:22:13.367 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:22:13.368 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0xC8.
01/07/18 21:22:17.143 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:22:17.143 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0xC8.
01/07/18 21:26:52.092 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:26:52.092 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:26:54.538 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
01/07/18 21:26:54.539 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 41 with serial number OEQ0203842 was set to 0x00.
Viele Grüsse,
Günther
PS: das Gerät ist Folgendes:
41 │ HM_61_Sensor │ 564783 │ OEQ0203842 │ 00C7 │ HM-Sec-SCo │ 1.0 │ No │ No │ No
Hallo @gs4711,
ich bräuchte das Log vom Anschalten von AES und das anschließende Öffnen und Schließen. Nach dem Einschalten von AES muss der Anlernknopf einmal betätigt werden, damit die Einstellungen korrekt übernommen werden. Generell ist es so, das AES-Kommunikation sich leichter stören lässt, da insgesamt 8 Pakete übertragen werden müssen statt 2 ohne. Wenn etwas schief geht bei der Kommunikation, muss wieder bei Paket 1 gestartet werden.
