HM-MOD-RPI-PCB + Raspi 3
ich habe ein Problem mit einem Pi 3 und dem HM-MOD-RPI-PCB Funkmodul. Unter RasperryMatic lief es einwandfrei, aber nun habe ich das Openhabian-Image installiert und bekomme es dort nicht zum Laufen.
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Ich habe versucht das Ganze mittels dieser Anleitung ans Laufen zu bekommen https://doc.homegear.eu/data/homegear-homematicbidcos/configuration.html#config-hm-mod-rpi-pcb - leider ohne Erfolg. Es lassen sich keine Geräte paaren.
Was ĂĽbersehe ich? Hier mal meine /boot/config.txt
# For more options and information see
# http://rpf.io/configtxtreadme
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
gpu_mem=16
enable_uart=1
dtparam=spi=on
dtparam=i2c_arm=on
#core_freq=250
#Alternativ kann auch dieser Eintrag gesetzt werden
#force_turbo=1
dtoverlay=pi3-miniuart-bt
Hier meine /boot/cmdline.txt:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
/etc/homegear/families/homematicbidcos.conf :
id = My-HM-MOD-RPI-PCB
## to new peers.
#default = true
deviceType = hm-mod-rpi-pcb
device = /dev/ttyAMA0
#device = /dev/ttyS0
responseDelay = 95
## Default: gpio1 = 0
## "18" for HM-MOD-RPI-PCB
gpio1 = 18
Hier mal ein Auszug aus der homegear.err:
09/24/17 11:42:55.377 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:42:55.377 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:42:56.950 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:05.089 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:05.089 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:06.665 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:14.804 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:14.804 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:16.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:24.518 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:24.518 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:26.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:34.233 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:34.233 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:35.808 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:43.947 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:43.947 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:45.523 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:53.662 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:43:53.662 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:43:56.938 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:43:59.075 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: CRC (B62E) failed on packet received from HM-MOD-RPI-PCB: FD00210301051A6C
09/24/17 11:44:05.077 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:44:05.077 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:44:06.938 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:44:09.076 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: CRC (B62E) failed on packet received from HM-MOD-RPI-PCB: FD002103010514DB
09/24/17 11:44:15.077 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:44:15.077 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:44:16.651 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:44:24.790 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:44:24.790 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
09/24/17 11:44:26.365 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
09/24/17 11:44:34.505 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
09/24/17 11:44:34.506 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
und der homegear.log:
09/24/17 11:42:44.918 Starting Homegear...
09/24/17 11:42:44.918 Homegear version 0.7.9-1375
09/24/17 11:42:44.918 Git commit SHA of libhomegear-base: -
09/24/17 11:42:44.918 Git branch of libhomegear-base:     -
09/24/17 11:42:44.918 Git commit SHA of Homegear:         -
09/24/17 11:42:44.918 Git branch of Homegear:             -
09/24/17 11:42:44.919 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
09/24/17 11:42:44.920 Info: Core file size now is "4294967295".
09/24/17 11:42:44.920 Info: Setting maximum thread priority to "4294967295" for user with id 0 and group with id 0.
09/24/17 11:42:44.920 Info: Maximum thread priority now is "4294967295".
09/24/17 11:42:44.932 Info: Backing up database...
09/24/17 11:42:45.067 Initializing database...
09/24/17 11:42:45.070 Debug: Loading licensing modules
09/24/17 11:42:45.071 Debug: Loading family modules
09/24/17 11:42:45.071 Info: Loading family module mod_homematicwired.so
09/24/17 11:42:45.077 /etc/homegear/families/homematicwired.conf
09/24/17 11:42:45.077 Module HomeMatic Wired: Debug: Loading module...
09/24/17 11:42:45.077 Info: Loading family module mod_homematicbidcos.so
09/24/17 11:42:45.089 /etc/homegear/families/homematicbidcos.conf
09/24/17 11:42:45.089 Debug: Loading section "General"
09/24/17 11:42:45.089 Debug: Family setting rfkey set to 00112233445566778899aabbccddeeff
09/24/17 11:42:45.089 Debug: Family setting currentrfkeyindex set to 1
09/24/17 11:42:45.089 Debug: Family setting processbroadcastwithaesenabled set to false
09/24/17 11:42:45.089 Debug: Loading section "HomeMatic Wireless Module for Raspberry Pi"
09/24/17 11:42:45.089 Debug: id set to My-HM-MOD-RPI-PCB
09/24/17 11:42:45.089 Debug: deviceType set to hm-mod-rpi-pcb
09/24/17 11:42:45.089 Debug: device set to /dev/ttyAMA0
09/24/17 11:42:45.089 Debug: responseDelay set to 95
09/24/17 11:42:45.089 Debug: GPIO1 set to 18
09/24/17 11:42:45.090 Module HomeMatic BidCoS: Debug: Loading module...
09/24/17 11:42:45.090 Module HomeMatic BidCoS: Debug: Creating physical device. Type defined in homematicbidcos.conf is: hm-mod-rpi-pcb
09/24/17 11:42:45.090 Info: Loading family module mod_miscellaneous.so
09/24/17 11:42:45.093 /etc/homegear/families/miscellaneous.conf
09/24/17 11:42:45.094 Module Miscellaneous: Debug: Loading module...
09/24/17 11:42:45.094 Info: Setting up physical interfaces and GPIOs...
09/24/17 11:42:45.094 Debug: Setting up physical device.
09/24/17 11:42:45.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: HM-MOD_RPI_PCB: Setting device permissions
09/24/17 11:42:45.094 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: HM-MOD_RPI_PCB: Exporting GPIO
09/24/17 11:42:45.094 Debug: GPIO path for GPIO with index 1 and device hm-mod-rpi-pcb set to "/sys/class/gpio/gpio18".
09/24/17 11:42:45.094 Debug: Unexporting GPIO with index 1 and number 18 for device "hm-mod-rpi-pcb".
09/24/17 11:42:45.095 Debug: Exporting GPIO with index 1 and number 18 for device "hm-mod-rpi-pcb".
09/24/17 11:42:45.096 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: HM-MOD_RPI_PCB: Setting GPIO permissions
09/24/17 11:42:45.096 Debug: GPIO path for GPIO with index 1 and device hm-mod-rpi-pcb set to "/sys/class/gpio/gpio18".
09/24/17 11:42:45.097 Info: Dropping privileges to user homegear (110) and group homegear (116)
09/24/17 11:42:45.097 Info: Homegear is (now) running as user with id 110 and group with id 116.
09/24/17 11:42:45.103 Starting script engine server...
09/24/17 11:42:45.106 Script Engine Server: Debug: Waiting for script engine server's client threads to finish.
09/24/17 11:42:45.110 Initializing licensing controller...
09/24/17 11:42:45.111 Loading licensing controller data...
09/24/17 11:42:45.111 Loading devices...
09/24/17 11:42:45.111 Loading XML RPC devices...
09/24/17 11:42:45.112 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd.xml
09/24/17 11:42:45.114 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v1_5.xml
09/24/17 11:42:45.120 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_le_v1_3.xml
09/24/17 11:42:45.121 Loading XML RPC device /etc/homegear/devices/0/rf_rc_19.xml
09/24/17 11:42:45.125 Loading XML RPC device /etc/homegear/devices/0/rf_s_mega168.xml
09/24/17 11:42:45.130 Loading XML RPC device /etc/homegear/devices/0/rf_swi.xml
09/24/17 11:42:45.131 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2pwm.xml
09/24/17 11:42:45.206 Loading XML RPC device /etc/homegear/devices/0/rf_rc-key4-2.xml
09/24/17 11:42:45.209 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_7.xml
09/24/17 11:42:45.219 Loading XML RPC device /etc/homegear/devices/0/rf_oligo_smart_iq.xml
09/24/17 11:42:45.291 Loading XML RPC device /etc/homegear/devices/0/rf_tis.xml
09/24/17 11:42:45.292 Loading XML RPC device /etc/homegear/devices/0/rf_wds40_th_i_2.xml
09/24/17 11:42:45.293 Loading XML RPC device /etc/homegear/devices/0/rf_roto_wdf_solar.xml
09/24/17 11:42:45.310 Loading XML RPC device /etc/homegear/devices/0/rf_scd_v1_0.xml
09/24/17 11:42:45.312 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw_le_v2_4.xml
09/24/17 11:42:45.321 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm_le_v1_0.xml
09/24/17 11:42:45.323 Loading XML RPC device /etc/homegear/devices/0/rf_em_8.xml
09/24/17 11:42:45.326 Loading XML RPC device /etc/homegear/devices/0/rf_sc_le_v1_6.xml
09/24/17 11:42:45.328 Loading XML RPC device /etc/homegear/devices/0/rf_cf.xml
09/24/17 11:42:45.340 Loading XML RPC device /etc/homegear/devices/0/rf_sen_db.xml
09/24/17 11:42:45.341 Loading XML RPC device /etc/homegear/devices/0/rf_bl_644.xml
09/24/17 11:42:45.352 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_2.xml
09/24/17 11:42:45.354 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_v1_5.xml
09/24/17 11:42:45.356 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_0.xml
09/24/17 11:42:45.367 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_dr.xml
09/24/17 11:42:45.393 Loading XML RPC device /etc/homegear/devices/0/rf_keymatic.xml
09/24/17 11:42:45.397 Loading XML RPC device /etc/homegear/devices/0/rf_sen_ep.xml
09/24/17 11:42:45.398 Loading XML RPC device /etc/homegear/devices/0/rf_cfm.xml
09/24/17 11:42:45.410 Loading XML RPC device /etc/homegear/devices/0/rf_cfm_tw.xml
09/24/17 11:42:45.423 Loading XML RPC device /etc/homegear/devices/0/rf_em_8_bit.xml
09/24/17 11:42:45.426 Loading XML RPC device /etc/homegear/devices/0/rf_rc_2_fm.xml
09/24/17 11:42:45.428 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir_v1_5.xml
09/24/17 11:42:45.430 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_1.xml
09/24/17 11:42:45.436 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_fm_lf.xml
09/24/17 11:42:45.449 Loading XML RPC device /etc/homegear/devices/0/rf_ddc.xml
09/24/17 11:42:45.455 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644_le_v2_4.xml
09/24/17 11:42:45.480 Loading XML RPC device /etc/homegear/devices/0/rf_rgbw.xml
09/24/17 11:42:45.490 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644.xml
09/24/17 11:42:45.496 Loading XML RPC device /etc/homegear/devices/0/rf_rd_le_v1_3.xml
09/24/17 11:42:45.498 Loading XML RPC device /etc/homegear/devices/0/rf_ja_conf_644.xml
09/24/17 11:42:45.511 Loading XML RPC device /etc/homegear/devices/0/rf_wds30_ot2.xml
09/24/17 11:42:45.513 Loading XML RPC device /etc/homegear/devices/0/rf_bl.xml
09/24/17 11:42:45.524 Loading XML RPC device /etc/homegear/devices/0/rf_resc_win_pcb_sc.xml
09/24/17 11:42:45.533 Loading XML RPC device /etc/homegear/devices/0/rf_s_8_ba.xml
09/24/17 11:42:45.539 Loading XML RPC device /etc/homegear/devices/0/rf_rhs.xml
09/24/17 11:42:45.541 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t_le_v1_9.xml
09/24/17 11:42:45.552 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_e_v1_7.xml
09/24/17 11:42:45.553 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw.xml
09/24/17 11:42:45.564 Loading XML RPC device /etc/homegear/devices/0/rf_winmatic.xml
09/24/17 11:42:45.570 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2.xml
09/24/17 11:42:45.572 Loading XML RPC device /etc/homegear/devices/0/rf_dw.xml
09/24/17 11:42:45.648 Loading XML RPC device /etc/homegear/devices/0/rf_tis_le_v1_0.xml
09/24/17 11:42:45.649 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644_le_v2_4.xml
09/24/17 11:42:45.674 Loading XML RPC device /etc/homegear/devices/0/rf_s_ba.xml
09/24/17 11:42:45.680 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644.xml
09/24/17 11:42:45.705 Loading XML RPC device /etc/homegear/devices/0/rf_s_2conf_644.xml
09/24/17 11:42:45.711 Loading XML RPC device /etc/homegear/devices/0/rf_rep.xml
09/24/17 11:42:45.721 Loading XML RPC device /etc/homegear/devices/0/rf_hm-wds100-c6-o-2.xml
09/24/17 11:42:45.723 Loading XML RPC device /etc/homegear/devices/0/rf_d.xml
09/24/17 11:42:45.733 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_3.xml
09/24/17 11:42:45.740 Loading XML RPC device /etc/homegear/devices/0/rf_st_6_sh.xml
09/24/17 11:42:45.743 Loading XML RPC device /etc/homegear/devices/0/rf_pbi.xml
09/24/17 11:42:45.744 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644_le_v2_4.xml
09/24/17 11:42:45.770 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644.xml
09/24/17 11:42:45.795 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_ge_v1_4.xml
09/24/17 11:42:45.796 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc_le_v1_9.xml
09/24/17 11:42:45.816 Loading XML RPC device /etc/homegear/devices/0/rf_s_644.xml
09/24/17 11:42:45.823 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644.xml
09/24/17 11:42:45.848 Loading XML RPC device /etc/homegear/devices/0/rf_sen_wa_od.xml
09/24/17 11:42:45.850 Loading XML RPC device /etc/homegear/devices/0/rf_sc_e_v1_7.xml
09/24/17 11:42:45.851 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644.xml
09/24/17 11:42:45.877 Loading XML RPC device /etc/homegear/devices/0/rf_s550ia.xml
09/24/17 11:42:45.877 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644_le_v2_4.xml
09/24/17 11:42:45.902 Loading XML RPC device /etc/homegear/devices/0/rf_sci_3.xml
09/24/17 11:42:45.904 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_9.xml
09/24/17 11:42:45.914 Loading XML RPC device /etc/homegear/devices/0/rf_rc_single_on.xml
09/24/17 11:42:45.915 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_le_v1_0.xml
09/24/17 11:42:45.916 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sfa.xml
09/24/17 11:42:45.923 Loading XML RPC device /etc/homegear/devices/0/rf_dis_ep_wm55.xml
09/24/17 11:42:45.925 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t.xml
09/24/17 11:42:45.936 Loading XML RPC device /etc/homegear/devices/0/rf_ash550.xml
09/24/17 11:42:45.936 Loading XML RPC device /etc/homegear/devices/0/rf_tc_it_wm-w-eu.xml
09/24/17 11:42:45.975 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644.xml
09/24/17 11:42:45.999 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-2.xml
09/24/17 11:42:46.001 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644.xml
09/24/17 11:42:46.013 Loading XML RPC device /etc/homegear/devices/0/rf_ao.xml
09/24/17 11:42:46.037 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir.xml
09/24/17 11:42:46.039 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_ge_v1_1.xml
09/24/17 11:42:46.041 Loading XML RPC device /etc/homegear/devices/0/rf_rc_dis.xml
09/24/17 11:42:46.042 Loading XML RPC device /etc/homegear/devices/0/rf_dis_ep_wm55_le_v1_0.xml
09/24/17 11:42:46.044 Loading XML RPC device /etc/homegear/devices/0/rf_cm.xml
09/24/17 11:42:46.051 Loading XML RPC device /etc/homegear/devices/0/rf_s.xml
09/24/17 11:42:46.057 Loading XML RPC device /etc/homegear/devices/0/rf_dis_wm55.xml
09/24/17 11:42:46.059 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn_bom.xml
09/24/17 11:42:46.077 Loading XML RPC device /etc/homegear/devices/0/rf_ws550.xml
09/24/17 11:42:46.078 Loading XML RPC device /etc/homegear/devices/0/rf_rc.xml
09/24/17 11:42:46.080 Loading XML RPC device /etc/homegear/devices/0/rf_ks550.xml
09/24/17 11:42:46.081 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644_le_v2_4.xml
09/24/17 11:42:46.106 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_1.xml
09/24/17 11:42:46.108 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644_le_v2_4.xml
09/24/17 11:42:46.133 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sir_wm.xml
09/24/17 11:42:46.151 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir.xml
09/24/17 11:42:46.153 Loading XML RPC device /etc/homegear/devices/0/rf_fs_ba.xml
09/24/17 11:42:46.159 Loading XML RPC device /etc/homegear/devices/0/rf_rc-sec4-2.xml
09/24/17 11:42:46.162 Loading XML RPC device /etc/homegear/devices/0/rf_s_4_ba.xml
09/24/17 11:42:46.168 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm.xml
09/24/17 11:42:46.171 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_wm55.xml
09/24/17 11:42:46.173 Loading XML RPC device /etc/homegear/devices/0/rf_rd.xml
09/24/17 11:42:46.175 Loading XML RPC device /etc/homegear/devices/0/rf_bl_le_v2_3.xml
09/24/17 11:42:46.187 Loading XML RPC device /etc/homegear/devices/0/rf_4dis.xml
09/24/17 11:42:46.188 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v2_3.xml
09/24/17 11:42:46.194 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc.xml
09/24/17 11:42:46.215 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_le_v1_6.xml
09/24/17 11:42:46.217 Loading XML RPC device /etc/homegear/devices/0/rf_sc.xml
09/24/17 11:42:46.219 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_1.xml
09/24/17 11:42:46.230 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn.xml
09/24/17 11:42:46.247 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_0.xml
09/24/17 11:42:46.248 Loading XML RPC device /etc/homegear/devices/0/rf_sen_li.xml
09/24/17 11:42:46.249 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-3_single_on.xml
09/24/17 11:42:46.251 Loading XML RPC device /etc/homegear/devices/0/rf_rc_12.xml
09/24/17 11:42:46.252 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sco.xml
09/24/17 11:42:46.254 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644.xml
09/24/17 11:42:46.279 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_schueco.xml
09/24/17 11:42:46.280 Loading XML RPC device /etc/homegear/devices/0/rf_cc_vd.xml
09/24/17 11:42:46.282 Loading device 2
09/24/17 11:42:46.282 Module HomeMatic BidCoS: Info: Central address set to 0xFD494A.
09/24/17 11:42:46.283 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
09/24/17 11:42:46.283 Debug: Disposing central...
09/24/17 11:42:46.283 Info: Disposing family module mod_homematicwired.so
09/24/17 11:42:46.283 Debug: Deleting factory pointer of module mod_homematicwired.so
09/24/17 11:42:46.283 Debug: Closing dynamic library module mod_homematicwired.so
09/24/17 11:42:46.283 Debug: Dynamic library mod_homematicwired.so disposed
09/24/17 11:42:46.283 Loading XML RPC devices...
09/24/17 11:42:46.283 Loading XML RPC device /etc/homegear/devices/254/Template.xml
09/24/17 11:42:46.285 Loading device 1
09/24/17 11:42:46.286 Initializing RPC client...
09/24/17 11:42:46.286 Starting XML RPC server RPCServer1 listening on :::2001...
09/24/17 11:42:46.289 Starting XML RPC server RPCServer2 listening on :::2002, SSL enabled...
09/24/17 11:42:46.289 RPC Server (Port 2001): Info: RPC Server started listening on address :: and port 2001
09/24/17 11:42:46.322 Starting XML RPC server RPCServer3 listening on :::2003, SSL enabled, authentication enabled...
09/24/17 11:42:46.322 RPC Server (Port 2002): Info: RPC Server started listening on address :: and port 2002
09/24/17 11:42:46.354 Starting CLI server...
09/24/17 11:42:46.354 Debug: Waiting for CLI client threads to finish.
09/24/17 11:42:46.354 RPC Server (Port 2003): Info: RPC Server started listening on address :: and port 2003
09/24/17 11:42:46.354 Initializing event handler...
09/24/17 11:42:46.354 Loading events...
09/24/17 11:42:46.355 Starting flows server...
09/24/17 11:42:46.355 Flows Engine Server: Debug: Waiting for flows engine server's client threads to finish.
09/24/17 11:42:46.360 Starting IPC server...
09/24/17 11:42:46.360 IPC Server: Debug: Waiting for IPC server's client threads to finish.
09/24/17 11:42:46.365 Start listening for packets...
09/24/17 11:42:48.366 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
09/24/17 11:42:48.366 Debug: GPIO 18 set to 0.
09/24/17 11:42:48.367 Startup complete. Waiting for physical interfaces to connect.
09/24/17 11:42:48.367 All physical interfaces are connected now.
09/24/17 11:42:48.367 Starting UPnP server...
09/24/17 11:42:48.369 Info: UPnP server: Binding to address: 192.168.178.30
09/24/17 11:42:48.369 UPnP Server: Info: Started listening.
09/24/17 11:42:48.467 Debug: GPIO 18 set to 1.
09/24/17 11:42:49.366 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F5F4350555F424C7251
09/24/17 11:42:49.366 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C7251
09/24/17 11:42:50.367 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A
09/24/17 11:42:50.467 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/24/17 11:42:50.487 Debug: Sleeping 1946ms before sending response.
09/24/17 11:42:50.904 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040000040199
09/24/17 11:42:50.904 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 3D
09/24/17 11:42:50.904 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400000401993D
09/24/17 11:42:50.942 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0010FE01004475
09/24/17 11:42:50.944 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 616C436F50726F5F
09/24/17 11:42:50.944 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 417070B736
09/24/17 11:42:50.945 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010FE01004475616C436F50726F5F417070B736
09/24/17 11:42:52.434 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/24/17 11:42:52.534 UPnP Server: Debug: Sending notify packets.
09/24/17 11:42:52.534 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/24/17 11:42:52.546 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.59:48652 accepted. Client number: 13
09/24/17 11:42:52.547 RPC Server (Port 2001): Info: RPC server client id for client number 13 is: 0
09/24/17 11:42:52.547 RPC Server (Port 2001): Listening for incoming packets from client number 13.
09/24/17 11:42:52.548 RPC Server (Port 2001): Debug: Packet received: 474554202F6465736372697074696F6E2E786D6C20485454502F312E310D0A4163636570743A202A2F2A0D0A486F73743A203139322E3136382E3137382E33303A323030310D0A557365722D4167656E743A2054776F6E6B792D4E4D432F382E3220284C696E757820332E342E363B207838365F36342920444C4E41444F432F312E35300D0A436F6E6E656374696F6E3A20636C6F73650D0A0D0A
09/24/17 11:42:52.555 Debug: Sleeping 1269ms before sending response.
09/24/17 11:42:52.570 RPC Server (Port 2001): Debug: Connection to client number 13 closed.
09/24/17 11:42:53.824 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/24/17 11:42:53.924 UPnP Server: Debug: Sending notify packets.
09/24/17 11:42:53.936 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.59:48653 accepted. Client number: 14
09/24/17 11:42:53.936 RPC Server (Port 2001): Info: RPC server client id for client number 14 is: 1
09/24/17 11:42:53.937 RPC Server (Port 2001): Listening for incoming packets from client number 14.
09/24/17 11:42:53.937 RPC Server (Port 2001): Debug: Packet received: 474554202F6465736372697074696F6E2E786D6C20485454502F312E310D0A4163636570743A202A2F2A0D0A486F73743A203139322E3136382E3137382E33303A323030310D0A557365722D4167656E743A2054776F6E6B792D4E4D432F382E3220284C696E757820332E342E363B207838365F36342920444C4E41444F432F312E35300D0A436F6E6E656374696F6E3A20636C6F73650D0A0D0A
09/24/17 11:42:53.960 RPC Server (Port 2001): Debug: Connection to client number 14 closed.
09/24/17 11:42:55.374 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A
09/24/17 11:42:55.377 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...
09/24/17 11:42:56.950 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
09/24/17 11:42:56.950 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
09/24/17 11:42:57.711 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/24/17 11:42:57.731 Debug: Sleeping 3684ms before sending response.
09/24/17 11:42:58.951 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
09/24/17 11:42:58.951 Debug: GPIO 18 set to 0.
09/24/17 11:42:59.052 Debug: GPIO 18 set to 1.
09/24/17 11:42:59.087 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F
09/24/17 11:42:59.088 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5F4350555F424C72
09/24/17 11:42:59.088 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 51
09/24/17 11:42:59.088 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C7251
09/24/17 11:43:00.089 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A
09/24/17 11:43:00.619 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040000040199
09/24/17 11:43:00.619 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 3D
09/24/17 11:43:00.619 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400000401993D
09/24/17 11:43:00.657 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0010FE01004475
09/24/17 11:43:00.658 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 616C436F50726F5F
09/24/17 11:43:00.659 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 417070B736
09/24/17 11:43:00.659 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010FE01004475616C436F50726F5F417070B736
09/24/17 11:43:01.416 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/24/17 11:43:01.428 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.59:48657 accepted. Client number: 17
09/24/17 11:43:01.428 RPC Server (Port 2001): Info: RPC server client id for client number 17 is: 2
09/24/17 11:43:01.429 RPC Server (Port 2001): Listening for incoming packets from client number 17.
09/24/17 11:43:01.429 RPC Server (Port 2001): Debug: Packet received: 474554202F6465736372697074696F6E2E786D6C20485454502F312E310D0A4163636570743A202A2F2A0D0A486F73743A203139322E3136382E3137382E33303A323030310D0A557365722D4167656E743A2054776F6E6B792D4E4D432F382E3220284C696E757820332E342E363B207838365F36342920444C4E41444F432F312E35300D0A436F6E6E656374696F6E3A20636C6F73650D0A0D0A
09/24/17 11:43:01.452 RPC Server (Port 2001): Debug: Connection to client number 17 closed.
09/24/17 11:43:01.516 UPnP Server: Debug: Sending notify packets.
09/24/17 11:43:01.527 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.59:48658 accepted. Client number: 18
09/24/17 11:43:01.528 RPC Server (Port 2001): Info: RPC server client id for client number 18 is: 3
09/24/17 11:43:01.528 RPC Server (Port 2001): Listening for incoming packets from client number 18.
09/24/17 11:43:01.529 RPC Server (Port 2001): Debug: Packet received: 474554202F6465736372697074696F6E2E786D6C20485454502F312E310D0A4163636570743A202A2F2A0D0A486F73743A203139322E3136382E3137382E33303A323030310D0A557365722D4167656E743A2054776F6E6B792D4E4D432F382E3220284C696E757820332E342E363B207838365F36342920444C4E41444F432F312E35300D0A436F6E6E656374696F6E3A20636C6F73650D0A0D0A
09/24/17 11:43:01.551 RPC Server (Port 2001): Debug: Connection to client number 18 closed.
09/24/17 11:43:05.089 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A
09/24/17 11:43:05.089 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...
09/24/17 11:43:06.664 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
09/24/17 11:43:06.665 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
09/24/17 11:43:07.711 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/24/17 11:43:07.731 Debug: Sleeping 2881ms before sending response.
09/24/17 11:43:08.666 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
09/24/17 11:43:08.666 Debug: GPIO 18 set to 0.
09/24/17 11:43:08.766 Debug: GPIO 18 set to 1.
09/24/17 11:43:08.802 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F
09/24/17 11:43:08.802 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5F4350555F424C72
09/24/17 11:43:08.803 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 51
09/24/17 11:43:08.803 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C7251
09/24/17 11:43:09.803 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A
09/24/17 11:43:10.333 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040000040199
09/24/17 11:43:10.334 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 3D
Der Versuch einen Adapter zu paaren verläuft immer erfolglos… Was übersehe ich? Ich habe auch schon gelesen, dass es evtl an der Firmware des Moduls liegen kann - aber wie kann ich die ermitteln und ggf. updaten?
Ich hoffe ihr könnt mir helfen.
VG
Sascha
Hey @Ronin-Jay,
@KraxelHuber hat hier mal beschreiben, was du bei openhabian tun musst um die serielle Schnittstelle frei zu räumen: EnOcean Pi 868 GPIO
Da ich kein HM-MOD-RPI-PCB habe, kann ich zum Firmwareupdate leider nichts sagen. Hier wurde es aber schon mal erfolgreich durchgefĂĽrt: HM-MOD-RPI-PCB Firmwareupdate
Viellecht kann da @fanavity was zu sagen?
so long,
Danke für den schnell Tipp @pmayer. Das hatte ich vorher aber auch schon ohne Erfolg durchgeführt…
Die Datei /etc/udev/rules.d/99-com.rules ist auch gelöscht. Aber den Tipp mit Raspian Noob zum Flashen werde ich jetzt noch mal verfolgen.
Edit: Wie kann ich die Firmware-Version des Moduls abfragen?
Das kann ich dir leider nicht sagen, wie erwähnt habe ich kein HM-MOD-RPI-PCB.
Hilft dir das FHEM Wiki weiter? https://wiki.fhem.de/wiki/HM-MOD-RPI-PCB_HomeMatic_Funkmodul_fĂĽr_Raspberry_Pi
Danke für Deine Mühe, aber die Seite kenne ich. Nach der Anleitung hatte ich versucht die Firmware zu flashen, aber unter Openhabian klappt es nicht. Hab’s gerade mal unter Raspian mit der erwähnten Firmware geflasht, aber ich würde gerne wissen, welche Version jetzt auf dem Modul ist.
Naja, schauen wir mal, wie es sich jetzt mit Openhabian verhält, welches ich gerade wieder auf die SD-Karte spiele…
Edit: So, mittels Raspian konnte ich die Firmware problemlos flashen. Die anschlieĂźende Installation von Openhabian verlief auch problemlos, so dass jetzt ein Paaren auf Anhieb funktionierte
Schau mal hier. @rfkd kann dir vielleicht helfen :thumbsup:
