ich habe die Hardware von HM-MOD-RPI-PCB zu CC1101 CUL-Stick gewechselt und leider kann ich jetzt kein Device mehr erreichen.
Gleichzeitig habe ich von Raspbian auf Debian 9 (64-Bit) gewechselt.
Ich sehe im Log allerdings nichts was auf ein Problem hinweist:
06/01/19 22:17:08.650 HomeMatic BidCoS packet received (CUL, RSSI: -96 dBm): 0F4E86103157920000000A80E60C0000
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00E6.
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x0C.
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:17:08.650 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:17:08.651 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x20.
06/01/19 22:17:08.651 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:18:01.391 HomeMatic BidCoS packet received (CUL, RSSI: -99 dBm): 0F0886103157A30000000A80CF0B0040
06/01/19 22:18:01.391 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00CF.
06/01/19 22:18:01.391 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x0B.
06/01/19 22:18:01.391 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:18:01.391 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x01.
06/01/19 22:18:01.391 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:18:01.392 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:18:01.392 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x20.
06/01/19 22:18:01.392 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:18:33.419 HomeMatic BidCoS packet received (CUL, RSSI: -97 dBm): 0F2C861051A08D0000000A80DB0B0040
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00DB.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x0B.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x01.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x20.
06/01/19 22:18:33.420 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:19:20.902 HomeMatic BidCoS packet received (CUL, RSSI: -96 dBm): 0F4F86103157920000000A80E60C0000
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00E6.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x0C.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x20.
06/01/19 22:19:20.903 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 37 with serial number LEQ1199148 was set to 0x00.
06/01/19 22:20:12.634 HomeMatic BidCoS packet received (CUL, RSSI: -99 dBm): 0F0986103157A30000000A80D00B0040
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00D0.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x0B.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x01.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x20.
06/01/19 22:20:12.635 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 31 with serial number LEQ1199191 was set to 0x00.
06/01/19 22:20:59.174 HomeMatic BidCoS packet received (CUL, RSSI: -98 dBm): 0F2D861051A08D0000000A80DB0B0040
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00DB.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x0B.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x01.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x20.
06/01/19 22:20:59.175 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 16 with serial number NEQ1489832 was set to 0x00.
Im Admin-Center sehe ich “Gerätekommunikation derzeit gestört”.
