Crosspost from Github
Since the last docker pull (latest) (Homegear 0.9.0-3672) I ran (Oct. 3rd) homegear connects to my HM-LGW but is being disconnected ~3 seconds later. While being connected it revceives and sends Bidcos Messages.
10/04/24 10:16:31.751 HM-LGW "LanGateway_NEQ0382244": Info: Firmware version: 1.4.1
10/04/24 10:16:31.776 HM-LGW "LanGateway_NEQ0382244": Info: Init queue completed. Sending peers...
10/04/24 10:16:32.680 HM-LGW "LanGateway_NEQ0382244": Info: Peer sending completed.
10/04/24 10:16:38.762 HM-LGW "LanGateway_NEQ0382244": Warning: Connection closed (2).
10/04/24 10:16:38.776 HM-LGW "LanGateway_NEQ0382244": Warning: Connection closed (2).
10/04/24 10:16:49.762 HM-LGW "LanGateway_NEQ0382244": Warning: Connection closed. Trying to reconnect...
10/04/24 10:16:49.765 HM-LGW "LanGateway_NEQ0382244": Connected to HM-LGW with hostname 192.168.42.42 on port 2000.
10/04/24 10:16:57.695 HM-LGW "LanGateway_NEQ0382244": Info: Firmware version: 1.4.1
10/04/24 10:16:57.721 HM-LGW "LanGateway_NEQ0382244": Info: Init queue completed. Sending peers...
10/04/24 10:16:58.619 HM-LGW "LanGateway_NEQ0382244": Info: Peer sending completed.
10/04/24 10:17:01.237 Module HomeMatic BidCoS: Info: 10/04/24 10:17:01.237 Packet received (LanGateway_NEQ0382244, RSSI: -48 dBm): 0F7A86103C42F40000000AB8FB094F00
10/04/24 10:17:01.237 Info: Peer 4 is reachable again.
10/04/24 10:17:01.250 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x00FB.
10/04/24 10:17:01.250 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x09.
10/04/24 10:17:01.250 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x00.
10/04/24 10:17:01.250 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x00.
10/04/24 10:17:01.250 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x00.
10/04/24 10:17:01.253 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x00.
10/04/24 10:17:01.253 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x2E.
10/04/24 10:17:01.253 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 4 with serial number MEQ0787003 was set to 0x4F.
10/04/24 10:17:04.762 HM-LGW "LanGateway_NEQ0382244": Warning: Connection closed (2).
10/04/24 10:17:04.776 HM-LGW "LanGateway_NEQ0382244": Warning: Connection closed (2).
The behavior is reproduceable from 2 different machines (Ubuntu/Debian).
Is there any chance to pull an older version of the homegear image, as the docker hub only lists the 4 most recent ones (latest, stable, testing, nightly)?
Regards
