ich verwende nun Homegear mit einem HM-LC-Dim1TPBU-FM.
Jedoch liefert mir Homegear die Werte RSSI_DEVICE und RSSI_PEER nicht zurück.
Habt ihr eine Idee?
code> config print
MASTER
Channel: 3
[LOGIC_COMBINATION]: 00
[STATUSINFO_RANDOM]: 01
[STATUSINFO_MINDELAY]: 04
[POWERUP_ACTION]: 00
[TRANSMIT_TRY_MAX]: 06
Channel: 2
Channel: 1
[LOGIC_COMBINATION]: 01
Channel: 0
[CENTRAL_ADDRESS_BYTE_2]: 00
[CENTRAL_ADDRESS_BYTE_3]: 00
[CENTRAL_ADDRESS_BYTE_1]: 00
[PAIRED_TO_CENTRAL]: 00
[ROAMING]: 00
[POLLING_INTERVAL]: 3c
[POLLING]: 00
[INTERNAL_KEYS_VISIBLE]: 01
VALUES
Channel: 3
[ERROR_OVERHEAT]: 00
[LEVEL]: 00
[OLD_LEVEL]: 00
[LEVEL_REAL]: 00
[RAMP_TIME]: a0
[INSTALL_TEST]: 00
[ON_TIME]: 00
[ERROR_REDUCED]: 00
[RAMP_STOP]: 00
[ERROR_OVERLOAD]: 00
[WORKING]: 03
[INHIBIT]: 00
[DIRECTION]: 00
Channel: 2
[LEVEL]: 00
[OLD_LEVEL]: 00
[LEVEL_REAL]: 00
[RAMP_TIME]: a0
[INSTALL_TEST]: 00
[ON_TIME]: 00
[ERROR_REDUCED]: 00
[RAMP_STOP]: 00
[WORKING]: 03
[INHIBIT]: 00
[DIRECTION]: 00
Channel: 1
[LEVEL]: 00
[OLD_LEVEL]: 00
[LEVEL_REAL]: 00
[RAMP_TIME]: a0
[INSTALL_TEST]: 00
[ON_TIME]: 00
[ERROR_REDUCED]: 00
[RAMP_STOP]: 00
[WORKING]: 00
[INHIBIT]: 00
[DIRECTION]: 00
Channel: 0
[DUTYCYCLE]: 00
[CENTRAL_ADDRESS_SPOOFED]: 00
[CONFIG_PENDING]: 00
[STICKY_UNREACH]: 00
[UNREACH]: 00
LINK
Channel: 3
Address: 0x1aa785
Remote channel: 2
[LONG_ELSE_JT_RAMPON]: 01
[LONG_ELSE_JT_OFF]: 01
[LONG_ELSE_ACTION_TYPE]: 00
[LONG_ELSE_MULTIEXECUTE]: 00
[LONG_ELSE_OFF_TIME_MODE]: 00
[LONG_ELSE_ON_TIME_MODE]: 00
[LONG_OFFDELAY_STEP]: 0a
[LONG_DIM_MIN_LEVEL]: 00
[LONG_RAMPOFF_TIME]: 05
[LONG_RAMPON_TIME]: 05
[LONG_OFF_LEVEL]: 00
[LONG_OFFDELAY_BLINK]: 01
[LONG_ON_LEVEL_PRIO]: 00
[LONG_OFFDELAY_OLDTIME]: 04
[LONG_JT_RAMPON]: 03
[LONG_JT_RAMPOFF]: 02
[LONG_JT_OFFDELAY]: 02
[LONG_JT_OFF]: 01
[LONG_ACTION_TYPE]: 00
[LONG_RAMP_START_STEP]: 0a
[LONG_ON_TIME_MODE]: 00
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: ff
[LONG_ELSE_JT_RAMPOFF]: 01
[LONG_ONDELAY_TIME]: 00
[LONG_COND_VALUE_HI]: 64
[LONG_CT_ON]: 00
[LONG_CT_ONDELAY]: 00
[LONG_CT_OFFDELAY]: 00
[LONG_CT_RAMPOFF]: 00
[LONG_ELSE_JT_ON]: 01
[SHORT_JT_RAMPON]: 03
[LONG_JT_ON]: 02
[SHORT_ON_TIME_MODE]: 00
[SHORT_JT_OFFDELAY]: 02
[LONG_OFF_TIME_MODE]: 00
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 01
[SHORT_OFFDELAY_BLINK]: 01
[LONG_OFFDELAY_NEWTIME]: 04
[LONG_ON_LEVEL]: c8
[SHORT_ACTION_TYPE]: 00
[SHORT_OFF_TIME_MODE]: 00
[SHORT_OFF_TIME]: ff
[LONG_DIM_MAX_LEVEL]: c8
[SHORT_OFFDELAY_OLDTIME]: 04
[SHORT_ELSE_JT_RAMPOFF]: 01
[LONG_ELSE_JT_ONDELAY]: 01
[SHORT_ON_TIME]: ff
[SHORT_ELSE_JT_ON]: 01
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_OFF_LEVEL]: 00
[SHORT_ONDELAY_TIME]: 00
[LONG_COND_VALUE_LO]: 32
[SHORT_ON_LEVEL_PRIO]: 00
[LONG_ELSE_JT_OFFDELAY]: 01
[SHORT_JT_ON]: 02
[SHORT_CT_ONDELAY]: 00
[LONG_DIM_STEP]: 0a
[SHORT_OFFDELAY_TIME]: 00
[SHORT_CT_OFF]: 00
[LONG_ONDELAY_MODE]: 00
[LONG_JT_ONDELAY]: 02
[SHORT_JT_RAMPOFF]: 02
[SHORT_ON_LEVEL]: c8
[SHORT_COND_VALUE_LO]: 32
[LONG_MULTIEXECUTE]: 00
[SHORT_JT_ONDELAY]: 02
[SHORT_CT_RAMPOFF]: 00
[SHORT_COND_VALUE_HI]: 64
[LONG_ON_MIN_LEVEL]: 14
[LONG_CT_RAMPON]: 00
[SHORT_ONDELAY_MODE]: 00
[SHORT_CT_RAMPON]: 00
[SHORT_ON_MIN_LEVEL]: 14
[SHORT_RAMP_START_STEP]: 0a
[SHORT_DIM_STEP]: 0a
[SHORT_ELSE_JT_OFFDELAY]: 01
[SHORT_RAMPON_TIME]: 05
[SHORT_DIM_MAX_LEVEL]: c8
[LONG_OFFDELAY_TIME]: 00
[SHORT_OFFDELAY_STEP]: 0a
[SHORT_OFFDELAY_NEWTIME]: 04
[SHORT_ELSE_ACTION_TYPE]: 00
[SHORT_ELSE_OFF_TIME_MODE]: 00
[SHORT_ELSE_JT_OFF]: 01
[SHORT_RAMPOFF_TIME]: 05
[SHORT_ELSE_ON_TIME_MODE]: 00
[SHORT_ELSE_JT_ONDELAY]: 01
[SHORT_CT_OFFDELAY]: 00
[SHORT_DIM_MIN_LEVEL]: 00
[SHORT_ELSE_JT_RAMPON]: 01
Remote channel: 1
[LONG_JT_RAMPON]: 04
[LONG_JT_RAMPOFF]: 06
[LONG_JT_OFFDELAY]: 05
[LONG_JT_OFF]: 04
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: 0a
[LONG_CT_ON]: 00
[SHORT_JT_RAMPON]: 04
[LONG_JT_ON]: 04
[SHORT_JT_OFFDELAY]: 05
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 04
[LONG_ON_LEVEL]: c8
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 04
[LONG_DIM_STEP]: 0a
[SHORT_CT_OFF]: 00
[LONG_JT_ONDELAY]: 04
[SHORT_JT_RAMPOFF]: 06
[SHORT_JT_ONDELAY]: 04
Channel: 2
Address: 0x1aa785
Remote channel: 2
[LONG_JT_OFF]: 01
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: ff
[LONG_CT_ON]: 00
[LONG_JT_ON]: 02
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 01
[LONG_ON_LEVEL]: c8
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 02
[LONG_DIM_STEP]: 0a
[SHORT_CT_OFF]: 00
Remote channel: 1
[LONG_JT_OFF]: 04
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: 0a
[LONG_CT_ON]: 00
[LONG_JT_ON]: 04
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 04
[LONG_ON_LEVEL]: c8
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 04
[LONG_DIM_STEP]: 0a
[SHORT_CT_OFF]: 00
Channel: 1
Address: 0xfd0f37
Remote channel: 1
[LONG_RAMPOFF_TIME]: 00
[LONG_RAMPON_TIME]: 00
[LONG_JT_RAMPON]: 01
[LONG_JT_RAMPOFF]: 01
[LONG_JT_OFFDELAY]: 01
[LONG_JT_OFF]: 01
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: ff
[LONG_CT_ON]: 00
[SHORT_JT_RAMPON]: 01
[LONG_JT_ON]: 01
[SHORT_JT_OFFDELAY]: 01
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 01
[LONG_ON_LEVEL]: c8
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 01
[LONG_DIM_STEP]: 00
[SHORT_CT_OFF]: 00
[LONG_JT_ONDELAY]: 01
[SHORT_JT_RAMPOFF]: 01
[SHORT_JT_ONDELAY]: 01
[SHORT_DIM_STEP]: 00
[SHORT_RAMPON_TIME]: 00
[SHORT_RAMPOFF_TIME]: 00
Address: 0x1aa785
Remote channel: 2
[LONG_JT_OFF]: 01
[LONG_ACTION_TYPE]: 04
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: ff
[LONG_CT_ON]: 00
[LONG_JT_ON]: 02
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 01
[LONG_ON_LEVEL]: c8
[SHORT_ACTION_TYPE]: 01
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 02
[LONG_DIM_STEP]: 0a
[SHORT_CT_OFF]: 00
[LONG_MULTIEXECUTE]: 01
Remote channel: 1
[LONG_JT_OFF]: 04
[LONG_ACTION_TYPE]: 05
[LONG_ON_TIME_MODE]: 01
[LONG_OFF_TIME]: ff
[LONG_ON_TIME]: 0a
[LONG_CT_ON]: 00
[LONG_JT_ON]: 04
[LONG_CT_OFF]: 00
[SHORT_JT_OFF]: 04
[LONG_ON_LEVEL]: c8
[SHORT_ON_TIME]: ff
[UI_HINT]: 00
[SHORT_CT_ON]: 00
[SHORT_JT_ON]: 04
[LONG_DIM_STEP]: 0a
[SHORT_CT_OFF]: 00
[/code]
