habe heute meinen Pi neugestartet. Seit dem Neustart kann ich die Rolladenaktoren (HM-LC-Bl1PBU-FM) nicht mehr steuern. Sobald ich den Command zum Hoch- oder Runterfahren schicke, passiert nicht. Die Fensterkontakte etc. funktionieren ohne Probleme.
Im Homegear.log wird folgendes angezeigt
12/30/18 18:15:40.057 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C13A0110000FD25701D0201C8
12/30/18 18:15:40.257 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C13A0110000FD25701D0201C8
12/30/18 18:15:40.457 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C13A0110000FD25701D0201C8
12/30/18 18:15:40.956 HomeMatic BidCoS packet received (My-CUL, RSSI: -67 dBm): 0D26A41023F3B6FD807A06010000
12/30/18 18:15:40.957 Module HomeMatic BidCoS: Info: DIRECTION on channel 1 of HomeMatic BidCoS peer 1 with serial number KEQ0931506 was set to 0x00.
12/30/18 18:15:40.957 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 1 with serial number KEQ0931506 was set to 0x00.
12/30/18 18:15:42.626 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.19.75:59508 accepted. Client number: 185
12/30/18 18:15:42.627 RPC Server (Port 2001): Info: RPC server client id for client number 185 is: 18
12/30/18 18:15:42.629 RPC Server (Port 2001): Info: Client number 185 is calling RPC method: setValue (2) Parameters:
(String) KEQ1020741:1
(String) LEVEL
(Float) 1
12/30/18 18:15:45.671 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
12/30/18 18:15:45.672 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 7). Retrying...
12/30/18 18:15:45.772 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C14A0110000FD25701D0201C8
12/30/18 18:15:45.972 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C14A0110000FD25701D0201C8
12/30/18 18:15:46.172 Module HomeMatic BidCoS: CUL "My-CUL": Info: Sending (My-CUL): 0C14A0110000FD25701D0201C8
12/30/18 18:15:46.372 RPC Server (Port 2001): Info: Client number 185 is calling RPC method: ping (2) Parameters:
(String) b28a4b6e
12/30/18 18:15:46.378 RPC Server (Port 2001): Info: Client number 185 is calling RPC method: listBidcosInterfaces (2) Parameters:
12/30/18 18:15:47.426 RPC Server (Port 2001): Info: Client number 185 is calling RPC method: setValue (2) Parameters:
Im openhab.log steht folgendes:
2018-12-30 18:15:52.557 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
Habe leider keine Idee, woran es liegen kann. Gibt es das Problem schon?
Grüße
Lars
