the final goal is to be able to be notified by openHAB whenever a window is being opened…
What does work so far? Close to nothing
I have an HM-CFG-USB2:
[code]# lsusb
Bus 001 Device 005: ID 1b1f:c00f
dmesg
usb 1-1.5: new full-speed USB device number 5 using dwc_otg
usb 1-1.5: New USB device found, idVendor=1b1f, idProduct=c00f
usb 1-1.5: New USB device strings: Mfr=4, Product=14, SerialNumber=36
usb 1-1.5: Product: HM-CFG-USB
usb 1-1.5: Manufacturer: eQ-3
usb 1-1.5: SerialNumber: MEQ012345678[/code]
I’ve installed the latest (.102) hmland and the latest homegear 0.6 (Valentine’s Day Edition g).
hmland seems to be able to talk to the device:
[code]# hmland -p 21234 -D -I -i
USB < 0x0000: 4b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 K…
USB < 0x0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB < 0x0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB < 0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
usb-transfer took 43ms!
USB > 0x0000: 48 09 48 4d 2d 55 53 42 2d 49 46 03 c4 0a 4d 45 H.HM-USB-IF…ME
USB > 0x0010: 51 30 32 33 31 35 31 32 37 32 3e 00 00 00 00 60 Q012345678>…`
USB > 0x0020: 00 c3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB > 0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
Rebooting in 86400 seconds due to old firmware (0.964)
2016-02-15 12:15:51.955997: LAN < HHM-LAN-IF,03C4,MEQ0123456,78323E,000000,006000C3,0000
HHM-LAN-IF,03C4,MEQ0123456,78323E,000000,006000C3,0000[/code]
Now let’s have a look at the next layer - homegear:
[code]# nano /etc/homegear/families/homematicbidcos.conf
[General]
currentRFKeyIndex = 1
[HM-CFG-USB]
id = hmland
deviceType = hmcfglan
host = localhost
port = 21234
responseDelay = 60[/code]
And fire up homegear interactively:
# homegear
02/15/16 12:20:43.193 Loading RPC server settings from /etc/homegear/rpcservers.conf
02/15/16 12:20:43.195 Loading RPC client settings from /etc/homegear/rpcclients.conf
02/15/16 12:20:43.199 Starting Homegear...
02/15/16 12:20:43.200 Homegear version 0.6.0-1213
02/15/16 12:20:43.200 Git commit SHA of libhomegear-base: b371e5dc71949665db5ad1da6892ec6f9bad41b1
02/15/16 12:20:43.201 Git commit SHA of Homegear: 8f5b128c3c36dba40e4a6800871c94e4974e9a3a
02/15/16 12:20:43.203 Info: Loading family module mod_miscellaneous.so
02/15/16 12:20:43.207 /etc/homegear/families/miscellaneous.conf
02/15/16 12:20:43.207 Info: Loading family module mod_homematicbidcos.so
02/15/16 12:20:43.220 /etc/homegear/families/homematicbidcos.conf
02/15/16 12:20:43.222 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "hmland": Info: Disabling AES encryption for communication with HM-CFG-LAN.
02/15/16 12:20:43.222 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
02/15/16 12:20:43.223 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
02/15/16 12:20:43.223 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
02/15/16 12:20:43.223 Info: Core file size now is "4294967295".
02/15/16 12:20:43.223 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
02/15/16 12:20:43.223 Info: Maximum thread priority now is "0".
pure virtual method called
02/15/16 12:20:43.225 Critical: Signal 6 received. Stopping Homegear...
Abgebrochen (Speicherabzug geschrieben)
What’s going wrong here?
The old 0.5.2 version of homegear crashes, as well…
