I have a raspberry pi 2 with an HM-CFG-USB-2 stick. I already installed hmcfgusb and it seems like it’s working ok:
[code]USB < 0x0000: 4b 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 K…
USB < 0x0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB < 0x0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB < 0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
USB > 0x0000: 48 09 48 4d 2d 55 53 42 2d 49 46 03 c7 0a 4c 45 H.HM-USB-IF…LE
USB > 0x0010: 51 31 31 39 37 37 30 38 30 84 b2 00 00 00 00 56 Q11977080…V
USB > 0x0020: 3e ea 00 00 00 00 ff ff 00 00 00 00 00 00 00 00 >…
USB > 0x0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
2015-03-12 20:21:02.139049: LAN < HHM-USB-IF,03C7,LEQ1197708,3084B2,000000,00563EEA,0000
usb-transfer took 49ms![/code]
I configured Homegear to use the hmland interface:
[code]# The device family this interface is for
[HomeMaticBidCoS]
id = hmland
to new peers.
deviceType = hmcfglan
IP address of your HM-CFG-LAN
host = localhost
port = 1234
lanKey = 00112233445566778899AABBCCDDEEFF
currentRFKeyIndex = 1
the new one.
Default: responseDelay = 95
responseDelay = 60[/code]
But I am not able to pair any devices.
When I start homegear on the command line I get the following output:
03/12/15 20:45:11.068 Loading RPC server settings from /etc/homegear/rpcservers.conf
03/12/15 20:45:11.070 Loading RPC client settings from /etc/homegear/rpcclients.conf
03/12/15 20:45:11.079 Info: Loading family module mod_homematicwired.so
03/12/15 20:45:11.096 Info: Loading family module mod_insteon.so
03/12/15 20:45:11.116 Info: Loading family module mod_max.so
03/12/15 20:45:11.134 Info: Loading family module mod_miscellaneous.so
03/12/15 20:45:11.147 Info: Loading family module mod_philipshue.so
03/12/15 20:45:11.163 Info: Loading family module mod_homematicbidcos.so
03/12/15 20:45:11.214 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "hmland": Info: Enabling AES encryption for communication with HM-CFG-LAN.
03/12/15 20:45:11.214 Initializing database...
03/12/15 20:45:11.222 Initializing family controller...
03/12/15 20:45:11.222 Module HomeMatic BidCoS: Loading XML RPC devices...
03/12/15 20:45:12.051 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
03/12/15 20:45:12.052 Info: Not initializing device family INSTEON, because no physical interface was found.
03/12/15 20:45:12.052 Info: Not initializing device family MAX!, because no physical interface was found.
03/12/15 20:45:12.053 Info: Not initializing device family Philips hue, because no physical interface was found.
03/12/15 20:45:12.053 Module Miscellaneous: Loading XML RPC devices...
03/12/15 20:45:12.055 Loading devices...
03/12/15 20:45:12.056 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 1
03/12/15 20:45:12.059 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 2
03/12/15 20:45:12.062 Module Miscellaneous: Loading Miscellaneous device 3
03/12/15 20:45:12.063 Start listening for packets...
03/12/15 20:45:12.064 Initializing RPC client...
03/12/15 20:45:12.064 Info: Connecting to host localhost on port 1234...
03/12/15 20:45:12.065 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
03/12/15 20:45:12.071 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
03/12/15 20:45:12.071 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
03/12/15 20:45:12.074 Info: Connected to host localhost on port 1234. Client number is: 1
03/12/15 20:45:12.086 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentification enabled...
03/12/15 20:45:12.087 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
03/12/15 20:45:12.099 Starting CLI server...
03/12/15 20:45:12.099 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
03/12/15 20:45:12.099 Initializing event handler...
03/12/15 20:45:12.099 Loading events...
03/12/15 20:45:12.100 Startup complete.
03/12/15 20:45:13.070 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "hmland": Error: Error communicating with HM-CFG-LAN. AES is enabled but no IV was send from HM-CFG-LAN. Please use the HomeMatic LAN Interface Configurator to re-enable AES.
03/12/15 20:45:13.071 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "hmland": Error: Error communicating with HM-CFG-LAN. AES is enabled but no IV was send from HM-CFG-LAN. Please use the HomeMatic LAN Interface Configurator to re-enable AES.
As I understand, it is not possible to use AES with the HM-CFG-USB-2. But how do I disable AES in Homegear? When I comment out the AES key lines, I get an error at startup.
