Dear all,
I’m just trying to pair a HM-CC-RT-DN with Homegear using a Homematic-CUL (Busware). I already paired some HM-Sec-SCo without any problems.
But trying to pair the HM-CC-RT-DN doesn’t work. Even trying to reset of the device doesn’t help.
The log seems to contain a packet from my device:
10/07/17 21:25:39.240 Debug (MyCUL): Packet 1A018400511F070000001400954E45513135313630373759xxxxxx enters raisePacketReceived.
10/07/17 21:25:39.240 Debug (MyCUL): Packet 1A018400511F070000001400954E45513135313630373759xxxxxx is now passed to the EventHandler.
10/07/17 21:25:39.240 HomeMatic BidCoS packet received (MyCUL, RSSI: -50 dBm): 1A018400511F070000001400954E45513135313630373759xxxxxx
10/07/17 21:25:39.240 Debug (MyCUL): Packet processing of packet 1A018400511F070000001400954E45513135313630373759xxxxxx took 0 ms.
The configuration of Homegear is as follows (homematicbidcos.conf):
rfKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
## incremented by 1
currentRfKeyIndex = 1
## old and the new one.
#oldRFKey = 00112233445566778899AABBCCDDEEFF
## risk.
processBroadcastWithAesEnabled = true (I also tried 'false')
[CUL]
id = MyCUL
## to new peers.
deviceType = cul
device = /dev/ttyACM0
responseDelay = 95
(... the rest are comments)
homegear.err doesn’t show any errors.
Does anyone have an idea why pairing isn’t successful? Is there maybe a configuration mistake or something?
For pairing I do the following steps:
- homegear -r
- fs 0
- pon
- Start pairing on the device, which then counts from 30 to 0 without any further information
Thank you in advance!
Best regards
