I´ve just received my valve drive and an HM-CFG-USB2 adapter. I´ve installed homegear and hmland following the installation steps. I´ve tried to follow the pairing tutorial but it actually failed to find my valve drive. I also tried to do a factory reset.
I´ve attached the USB dongle to a windows pc and run the eq3 config tool. The valve drive was found by no time and I was able to configure it.
Do you got a clue why I can´t pair it to my homegear installation. Maybe I´ve missed some steps, but I am quite sure that I´ve got the whole installation procedure. Maybe it´s an AES problem. I´ve not switched off any AES signing…
Hope you can help,
Patrick
