Hallo Forum,
habe mir heute das aktuelle Image herunter geladen und auf eine SD Karte geschoben.
Ich nutze CC1101 unter Raspberry 3 und erhalte folgende Fehlermeldungen
root@homegearpi:~#
root@homegearpi:~# homegear
07/11/16 16:37:25.545 Loading RPC server settings from /etc/homegear/rpcservers.conf
07/11/16 16:37:25.547 Loading RPC client settings from /etc/homegear/rpcclients.conf
07/11/16 16:37:25.551 Starting Homegear…
07/11/16 16:37:25.551 Homegear version 0.6.2-1396
07/11/16 16:37:25.552 Git commit SHA of libhomegear-base: -
07/11/16 16:37:25.552 Git branch of libhomegear-base: -
07/11/16 16:37:25.552 Git commit SHA of Homegear: -
07/11/16 16:37:25.553 Git branch of Homegear: -
07/11/16 16:37:25.555 Info: Loading family module mod_homematicbidcos.so
07/11/16 16:37:25.578 /etc/homegear/families/homematicbidcos.conf
07/11/16 16:37:25.580 Info: Loading family module mod_insteon.so
07/11/16 16:37:25.593 /etc/homegear/families/insteon.conf
07/11/16 16:37:25.594 Info: Loading family module mod_homematicwired.so
07/11/16 16:37:25.604 /etc/homegear/families/homematicwired.conf
07/11/16 16:37:25.605 Info: Loading family module mod_beckhoff_bk90x0.so
07/11/16 16:37:25.613 /etc/homegear/families/beckhoffbk90x0.conf
07/11/16 16:37:25.614 Info: Loading family module mod_max.so
07/11/16 16:37:25.628 /etc/homegear/families/max.conf
07/11/16 16:37:25.629 Info: Loading family module mod_philipshue.so
07/11/16 16:37:25.637 /etc/homegear/families/philipshue.conf
07/11/16 16:37:25.638 Info: Loading family module mod_kodi.so
07/11/16 16:37:25.645 /etc/homegear/families/kodi.conf
07/11/16 16:37:25.646 Info: Loading family module mod_ipcam.so
07/11/16 16:37:25.652 /etc/homegear/families/ipcam.conf
07/11/16 16:37:25.654 Info: Loading family module mod_miscellaneous.so
07/11/16 16:37:25.660 /etc/homegear/families/miscellaneous.conf
07/11/16 16:37:25.661 Info: Loading family module mod_sonos.so
07/11/16 16:37:25.670 /etc/homegear/families/sonos.conf
07/11/16 16:37:25.672 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
07/11/16 16:37:25.673 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
07/11/16 16:37:25.673 Info: Setting allowed core file size to “4294967295” for user with id 0 and group with id 0.
07/11/16 16:37:25.674 Info: Core file size now is “4294967295”.
07/11/16 16:37:25.674 Info: Setting maximum thread priority to “0” for user with id 0 and group with id 0.
07/11/16 16:37:25.675 Info: Maximum thread priority now is “0”.
07/11/16 16:37:25.691 Info: Backing up database…
07/11/16 16:37:25.812 Initializing database…
07/11/16 16:37:25.817 Starting script engine server…
07/11/16 16:37:25.875 Initializing licensing controller…
07/11/16 16:37:25.875 Loading licensing controller data…
07/11/16 16:37:25.875 Loading devices…
07/11/16 16:37:25.876 Loading XML RPC devices…
07/11/16 16:37:27.699 Loading device 1
07/11/16 16:37:27.700 Module HomeMatic BidCoS: Info: Central address set to 0xFDA09B.
07/11/16 16:37:27.702 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
07/11/16 16:37:27.702 Info: Disposing family module mod_homematicwired.so
07/11/16 16:37:27.703 Info: Not initializing device family Insteon, because no physical interface was found.
07/11/16 16:37:27.703 Info: Disposing family module mod_insteon.so
07/11/16 16:37:27.703 Info: Not initializing device family MAX!, because no physical interface was found.
07/11/16 16:37:27.703 Info: Disposing family module mod_max.so
07/11/16 16:37:27.704 Info: Not initializing device family Philips hue, because no physical interface was found.
07/11/16 16:37:27.704 Info: Disposing family module mod_philipshue.so
07/11/16 16:37:27.705 Loading XML RPC devices…
07/11/16 16:37:27.726 Loading device 2
07/11/16 16:37:27.728 Loading XML RPC devices…
07/11/16 16:37:27.730 Loading device 3
07/11/16 16:37:27.731 Loading XML RPC devices…
07/11/16 16:37:27.734 Loading device 4
07/11/16 16:37:27.735 Info: Not initializing device family Beckhoff BK90x0, because no physical interface was found.
07/11/16 16:37:27.735 Info: Disposing family module mod_beckhoff_bk90x0.so
07/11/16 16:37:27.736 Loading XML RPC devices…
07/11/16 16:37:27.740 Loading device 5
07/11/16 16:37:27.740 Start listening for packets…
07/11/16 16:37:27.745 Failed to open direction file for GPIO with index 1 and device “cc1100”: Unable to retrieve path.
07/11/16 16:37:27.746 Failed to open edge file for GPIO with index 1 and device “cc1100”: Unable to retrieve path.
07/11/16 16:37:27.746 Error in file Systems/IPhysicalInterface.cpp line 330 in function virtual void BaseLib::Systems::IPhysicalInterface::openGPIO(uint32_t, bool): Failed to open value file for GPIO with index 1 and device “cc1100”: Unable to retrieve path.
07/11/16 16:37:27.746 Module HomeMatic BidCoS: TI CC110X “My-CC1101”: Error: Couldn’t listen to rf device, because the GPIO descriptor is not valid: /dev/spidev0.0
07/11/16 16:37:27.747 Module HomeMatic BidCoS: TI CC110X “My-CC1101”: Connection to TI CC1101 closed unexpectedly… Trying to reconnect…
usw. . . . ( [color=#FF0000]info: spidev0.0 ist da unter /dev[/color])
starte ich als user Pi kommt :
pi@homegearpi:~$ homegear
07/11/16 18:10:26.735 Loading RPC server settings from /etc/homegear/rpcservers.conf
07/11/16 18:10:26.737 Loading RPC client settings from /etc/homegear/rpcclients.conf
07/11/16 18:10:26.737 Unable to open RPC client config file: /etc/homegear/rpcclients.conf. Permission denied
07/11/16 18:10:26.738 Could not change working directory to /var/lib/homegear/.
pi@homegearpi:~$
ich habe den CC1101 3 x geprüft und ausgetauscht, dieser ist richtig angeschlossen.
What is going wrong ??
. . . gibt es noch einiges zu beachten mit dem image um diesen ans laufen zu bekommen ?
Gruß Achim
[color=#FF0000]Nachtrag[/color]:
Das Problem lag bei den Rechten einzelner Dateien. Ganz nachvollziehen kann ich das zwar nicht, da es ja ein fertiges image File war.
Nun ja, jetzt läuft es ja.
