ich habe Homegear zusammen mit Openhab auf einem Raspi2 laufen. Angeschlossen habe ich einen HMW-LGW und ein HM-LGW.
Am Wired Bus hängen aktuell ca. 40 Geräte. Nun bekomme ich ziemlich oft solceh Meldungen:
Error occured in Homegear (Level: 3): Module HomeMatic Wired: Error: Error sending packet to peer 39. Peer did not respond.
Error occured in Homegear (Level: 3): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Warning: !!!Not!!! sending (Port 1000), because the init sequence is not completed: FD000110CF1E000000010673000000FA8A
Error occured in Homegear (Level: 3): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Warning: Connection closed. Trying to reconnect…
Error occured in Homegear (Level: 2): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Error in file PhysicalInterfaces/HMW-LGW.cpp line 365 in function void HMWired::HMW_LGW::reconnect(): Could not connect to server 192.168.179.111 on port 1000. Poll failed with error code: 1.
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 1, Variable Name: “TEMPERATURE”, Value: 22,4
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 1, Variable Name: “HUMIDITY”, Value: 56
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 0, Variable Name: “RSSI_DEVICE”, Value: -59
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 0, Variable Name: “LAST_PACKET_RECEIVED”, Value: 1463157096
Error occured in Homegear (Level: 2): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Error in file PhysicalInterfaces/HMW-LGW.cpp line 365 in function void HMWired::HMW_LGW::reconnect(): Connecting to server 192.168.179.111 on port 1000 timed out.
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 0, Variable Name: “RSSI_DEVICE”, Value: -60
Variable updated: Device type: “HM-TC-IT-WM-W-EU”, ID: 40, Channel: 0, Variable Name: “LAST_PACKET_RECEIVED”, Value: 1463157205
Variable updated: Device type: “HM-WDS10-TH-O”, ID: 42, Channel: 1, Variable Name: “TEMPERATURE”, Value: 14,7
Variable updated: Device type: “HM-WDS10-TH-O”, ID: 42, Channel: 1, Variable Name: “HUMIDITY”, Value: 87
Variable updated: Device type: “HM-WDS10-TH-O”, ID: 42, Channel: 0, Variable Name: “RSSI_DEVICE”, Value: -74
Variable updated: Device type: “HM-WDS10-TH-O”, ID: 42, Channel: 0, Variable Name: “LAST_PACKET_RECEIVED”, Value: 1463157196
Variable updated: Device type: “HMW-IO-12-Sw14-DR”, ID: 35, Channel: 15, Variable Name: “FREQUENCY”, Value: 19607
Variable updated: Device type: “HMW-IO-12-Sw14-DR”, ID: 35, Channel: 14, Variable Name: “STATE”, Value: True
Variable updated: Device type: “HMW-IO-12-Sw14-DR”, ID: 35, Channel: 15, Variable Name: “FREQUENCY”, Value: 19801
Variable updated: Device type: “HMW-IO-12-Sw14-DR”, ID: 35, Channel: 15, Variable Name: “FREQUENCY”, Value: 17543
Variable updated: Device type: “HMW-IO-12-Sw14-DR”, ID: 35, Channel: 15, Variable Name: “FREQUENCY”, Value: 15763
Auch gibt es Probleme wenn ich die Config eines Kanales ändern will. Zb bei einem HMW-IO-12-FM kommt diese Meldung:
Error occured in Homegear (Level: 2): Module HomeMatic Wired: Error: Could not write config to device’s eeprom.
Error occured in Homegear (Level: 3): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Warning: !!!Not!!! sending (Port 1000), because the init sequence is not completed: FD00003FD11A000000011657000010FF1400000001FFFF05FF0AFFFFFFFFFFB3F2
Error calling RPC method “putParamset”. faultCode: -32500 faultString: Could not write config to device’s eeprom.
Setting variable “BEHAVIOUR” of device 43 and channel 11 to: 1
oder bei einem HMW-IO-12-Sw14-DR kommt:
Error occured in Homegear (Level: 3): Module HomeMatic Wired: HMW-LGW “My-HMW-LGW”: Warning: !!!Not!!! sending (Port 1000), because the init sequence is not completed: FD0000DB841C000000011657000010FF1400000001FC7EFFE0C0FFFFFFFFFFFF081A
Setting variable “BEHAVIOUR” of device 35 and channel 26 to: 1
Wenn ich mit der CCU die Config ändere geht es.
Muss ich bei Homegear da noch was einstellen?
Danke und Gruß
