ich habe auf meinem RPI per apt-get upgrade das Homegear auf aktuellen Stand gebracht. Nun funktioniert aber das Senden von Befehlen an Homematic Geräte nicht mehr.
Folgendes Log. Was tun?
01/08/20 22:40:25.583 MQTT Client: Info: Successfully connected to MQTT server using protocol version 4.
01/08/20 22:40:25.583 Info: Subscribing to topic homegear/1234-5678-9abc/rpc/#
01/08/20 22:40:25.590 Info: Subscribing to topic homegear/1234-5678-9abc/set/#
01/08/20 22:40:25.595 Info: Subscribing to topic homegear/1234-5678-9abc/value/#
01/08/20 22:40:25.600 Info: Subscribing to topic homegear/1234-5678-9abc/config/#
01/08/20 22:40:25.822 Startup complete. Waiting for physical interfaces to connect.
01/08/20 22:40:25.822 Info: Waiting for physical interfaces to connect (0 of 180s).
01/08/20 22:40:25.823 All physical interfaces are connected now.
01/08/20 22:40:25.823 Starting UPnP server…
01/08/20 22:40:30.826 UPnP Server: Info: UPnP server: Binding to address: 192.168.0.188
01/08/20 22:41:40.134 Info: MQTT RPC call received. Method: setValue
01/08/20 22:41:40.136 RPC Server (Port 2001): Info: RPC Method called: setValue Parameters:
(Integer) 1
(Integer) 1
(String) STATE
(Boolean) 0
01/08/20 22:41:40.173 Warning: !!!Not!!! sending packet, because init sequence is not complete: 1025B001FAB00162122201025D1B480200
01/08/20 22:41:43.186 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/08/20 22:41:43.188 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 1). Retrying…
01/08/20 22:41:43.287 Warning: !!!Not!!! sending packet, because init sequence is not complete: 1025B001FAB00162122201025D1B480200
01/08/20 22:41:46.300 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/08/20 22:41:46.302 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 1). Retrying…
01/08/20 22:41:46.401 Warning: !!!Not!!! sending packet, because init sequence is not complete: 1025B001FAB00162122201025D1B480200
01/08/20 22:41:49.414 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/08/20 22:41:49.416 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 1). Retrying…
01/08/20 22:41:49.515 Warning: !!!Not!!! sending packet, because init sequence is not complete: 1025B001FAB00162122201025D1B480200
01/08/20 22:41:52.528 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/08/20 22:41:52.532 Info: Peer 1 is unreachable.
01/08/20 22:41:52.535 MQTT Client Info: Publishing topic homegear/1234-5678-9abc/plain/1/0/UNREACH
01/08/20 22:41:52.538 Info: Peer 1 is reachable again.
01/08/20 22:41:52.542 MQTT Client Info: Publishing topic homegear/1234-5678-9abc/plain/1/0/UNREACH
01/08/20 22:41:52.550 MQTT Client Info: Publishing topic homegear/1234-5678-9abc/plain/1/0/STICKY_UNREACH
