Hi, habe gerade ein Update mit apt-get upgrade gemacht und bekomme jetzt beim start diesen Fehler
[code]root@odroid-server:~# sudo service homegear start
07/04/15 23:28:10.455 Critical: Could not load any family modules from “/var/lib/homegear/modules/”.
07/04/15 23:28:10.463 Error in physicalinterfaces.conf: No module found for device family: homematicbidcos
07/04/15 23:28:10.465 Info: Waiting for event threads to finish.
Starting Homegear homegear 07/04/15 23:28:10.502 Loading RPC server settings from /etc/homegear/rpcservers.conf
07/04/15 23:28:10.503 Loading RPC client settings from /etc/homegear/rpcclients.conf
07/04/15 23:28:10.504 Info: Waiting for event threads to finish.
[/code]
Irgendwas hat also das Update zerschossen, wie bekomme ich das ohne Neuninstallation wieder hin? Danke im Vorraus!
MM1804
ich habe einen sehr ähnlichen Fehler beim Start von Homegear:
root@bananapi ~ # service homegear start
07/22/15 15:13:21.657 Critical: No family modules found in "/var/lib/homegear/modules/".
07/22/15 15:13:21.658 Critical: No family modules found in "/var/lib/homegear/modules/".
07/22/15 15:13:21.659 Error in physicalinterfaces.conf: No module found for device family: homematicbidcos
07/22/15 15:13:21.660 Error in physicalinterfaces.conf: No module found for device family: homematicbidcos
07/22/15 15:13:21.664 Info: Waiting for event threads to finish.
[....] Starting Homegear: homegear07/22/15 15:13:21.730 Loading RPC server settings from /etc/homegear/rpcservers.conf
07/22/15 15:13:21.732 Loading RPC client settings from /etc/homegear/rpcclients.conf
07/22/15 15:13:21.735 Info: Waiting for event threads to finish.
. ok
Eine Neuinstallation hilft bei mir nicht weiter. Hat jemand eine Idee was da falsch läuft? Vielen Dank
