Ich habe Homegear aktualisiert und seitdem ist Funkstille (kein Empfang/Senden). Ich weiß leider nicht mehr, welche Version ich zuvor hatte, dürfte aber 0.5.x (x<=10) gewesen sein.
Log mit devLog=true und Level 6:
01/10/15 16:57:40.403 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
01/10/15 16:57:40.404 Info: Not initializing device family INSTEON, because no physical interface was found.
01/10/15 16:57:40.404 Info: Not initializing device family MAX!, because no physical interface was found.
01/10/15 16:57:40.404 Info: Not initializing device family Philips hue, because no physical interface was found.
01/10/15 16:57:40.404 Loading devices...
01/10/15 16:57:40.405 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 1
01/10/15 16:57:40.409 Module HomeMatic BidCoS: Loading peer 2
01/10/15 16:57:40.431 Module HomeMatic BidCoS: Error in file Modules/HomeMaticBidCoS/BidCoSPeer.cpp line 3249 in function virtual std::shared_ptr<BaseLib::RPC::Variable> BidCoS::BidCoSPeer::setInterface(std::string): map::at
01/10/15 16:57:40.432 Module HomeMatic BidCoS: Loading peer 3
01/10/15 16:57:40.449 Module HomeMatic BidCoS: Loading peer 4
01/10/15 16:57:40.466 Module HomeMatic BidCoS: Loading peer 5
01/10/15 16:57:40.490 Module HomeMatic BidCoS: Loading peer 6
01/10/15 16:57:40.508 Module HomeMatic BidCoS: Loading peer 7
01/10/15 16:57:40.525 Module HomeMatic BidCoS: Loading peer 8
01/10/15 16:57:40.542 Module HomeMatic BidCoS: Loading peer 9
01/10/15 16:57:40.570 Module HomeMatic BidCoS: Loading peer 10
01/10/15 16:57:40.599 Module HomeMatic BidCoS: Loading peer 11
01/10/15 16:57:40.627 Module HomeMatic BidCoS: Loading peer 12
01/10/15 16:57:40.656 Module HomeMatic BidCoS: Loading peer 13
01/10/15 16:57:40.756 Module HomeMatic BidCoS: Loading peer 14
01/10/15 16:57:40.773 Module HomeMatic BidCoS: Loading peer 15
01/10/15 16:57:40.796 Module HomeMatic BidCoS: Loading peer 16
01/10/15 16:57:40.814 Module HomeMatic BidCoS: Loading peer 17
01/10/15 16:57:40.839 Module HomeMatic BidCoS: Loading peer 18
01/10/15 16:57:40.866 Module HomeMatic BidCoS: Loading peer 19
01/10/15 16:57:40.960 Module HomeMatic BidCoS: Loading peer 20
01/10/15 16:57:40.977 Module HomeMatic BidCoS: Loading peer 21
01/10/15 16:57:40.994 Module HomeMatic BidCoS: Loading peer 22
01/10/15 16:57:41.011 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 2
01/10/15 16:57:41.016 Start listening for packets...
01/10/15 16:57:41.016 Debug: GPIO path for GPIO with index 1 and device cc1100 set to "/sys/class/gpio/gpio25".
01/10/15 16:57:41.018 Module HomeMatic BidCoS: TI CC110X "SPI": Debug: Sending: 30
01/10/15 16:57:41.019 Module HomeMatic BidCoS: TI CC110X "SPI": Debug: Received: 0F
01/10/15 16:57:41.019 Module HomeMatic BidCoS: TI CC110X "SPI": Debug: Sending: 0046
01/10/15 16:57:41.045 Module HomeMatic BidCoS: TI CC110X "SPI": Debug: Sending: 34
01/10/15 16:57:41.045 Module HomeMatic BidCoS: TI CC110X "SPI": Debug: Received: 0F
01/10/15 16:57:41.046 Initializing RPC client...
01/10/15 16:57:41.046 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
01/10/15 16:57:41.051 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
01/10/15 16:57:41.052 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
01/10/15 16:57:41.069 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentification enabled...
01/10/15 16:57:41.070 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
01/10/15 16:57:41.092 Starting CLI server...
01/10/15 16:57:41.092 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
01/10/15 16:57:41.092 Initializing event handler...
01/10/15 16:57:41.093 Loading events...
01/10/15 16:57:41.094 Startup complete.
01/10/15 16:57:41.094 All physical interfaces are connected now.
Ab dem Moment herrscht Funkstille…
Ich benutze einen CC1101 auf Banana Pi mit Raspbrain 7.
Peer 2 ist ein Rauchmelder, beim zweiten Rauchmelder kommt der Fehler komischerweise nicht. Peer 2 und 8 sind Rauchmelder.
Physical config:
[HomeMaticBidCoS]
id = SPI
deviceType = cc1100
device = /dev/spidev0.0
responseDelay = 100
gpio1 = 25
