Fehler bei homegear -r nach Bullseye upgrade
nach dem Upgrade von Openhabian von Buster auf Bullseye habe ich Probleme mit Homegear. Ich nutze einen Busware COC auf einer RPI 4 mit Homegear.
Homegear version 0.8.1-3519
Copyright (c) 2013-2020 Homegear GmbH
Required library versions:
  - libhomegear-base: 0.8.1-3519
  - libhomegear-node: 0.1.8-60
  - libhomegear-ipc:  0.1.2-46
Included open source software:
  - Node.js (license: MIT License, homepage: nodejs.org)
  - PHP (license: PHP License, homepage: www.php.net):
      Copyright (c) 1999-2020 The PHP Group. All rights reserved.
sudo homegear -r
08/07/23 09:47:38.222 Debug: debugLevel set to 5
08/07/23 09:47:38.222 Debug: memoryDebugging set to 1
08/07/23 09:47:38.222 Debug: devLog set to 1
08/07/23 09:47:38.222 Debug: ipcLog set to 0
08/07/23 09:47:38.222 Debug: enableCoreDumps set to 1
08/07/23 09:47:38.222 Debug: setDevicePermissions set to 1
08/07/23 09:47:38.222 Debug: workingDirectory set to /var/lib/homegear/
08/07/23 09:47:38.222 Debug: socketPath set to /var/run/homegear/
08/07/23 09:47:38.222 Debug: dataPath set to /var/lib/homegear/
08/07/23 09:47:38.223 Debug: familyDataPath set to /var/lib/homegear/families/
08/07/23 09:47:38.223 Debug: databaseMemoryJournal set to 0
08/07/23 09:47:38.223 Debug: databaseWALJournal set to 1
08/07/23 09:47:38.223 Debug: databaseSynchronous set to 1
08/07/23 09:47:38.223 Debug: databaseMaxBackups set to 10
08/07/23 09:47:38.223 Debug: logfilePath set to /var/log/homegear/
08/07/23 09:47:38.223 Debug: enableUPnP set to 1
08/07/23 09:47:38.223 Debug: deviceDescriptionPath set to /etc/homegear/devices/
08/07/23 09:47:38.223 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
08/07/23 09:47:38.223 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
08/07/23 09:47:38.223 Debug: mqttSettingsPath set to /etc/homegear/mqtt.conf
08/07/23 09:47:38.223 Debug: cloudUserMapPath set to /etc/homegear/cloudusermap.json
08/07/23 09:47:38.223 Debug: familyConfigPath set to /etc/homegear/families/
08/07/23 09:47:38.223 Debug: phpIniPath set to /etc/homegear/php.ini
08/07/23 09:47:38.223 Debug: gpioPath set to /sys/class/gpio/
08/07/23 09:47:38.223 Debug: scriptPath set to /var/lib/homegear/scripts/
08/07/23 09:47:38.223 Debug: enableNodeBlue set to 1
08/07/23 09:47:38.223 Debug: nodeBluePath set to /var/lib/homegear/node-blue/
08/07/23 09:47:38.223 Debug: nodeBlueDataPath set to /var/lib/homegear/node-blue/data/
08/07/23 09:47:38.223 Debug: nodeBlueDebugOutput set to 1
08/07/23 09:47:38.223 Debug: nodeBlueEventLimit1 set to 100
08/07/23 09:47:38.223 Debug: nodeBlueEventLimit2 set to 300
08/07/23 09:47:38.223 Debug: nodeBlueEventLimit3 set to 400
08/07/23 09:47:38.224 Debug: nodeBlueUriPathsExcludedFromLogin set to /ui/
08/07/23 09:47:38.224 Debug: adminUiPath set to /var/lib/homegear/admin-ui/public/
08/07/23 09:47:38.224 Debug: uiPath set to /var/lib/homegear/ui/
08/07/23 09:47:38.224 Debug: uiTranslationPath set to /var/lib/homegear/admin-ui/translations/modules/
08/07/23 09:47:38.224 Debug: reloadRolesOnStartup set to 1
08/07/23 09:47:38.224 Debug: libraryPath set to /var/lib/homegear/modules/
08/07/23 09:47:38.224 Debug: firmwarePath set to /usr/share/homegear/firmware/
08/07/23 09:47:38.224 Debug: tempPath set to /var/lib/homegear/tmp/
08/07/23 09:47:38.224 Debug: lockFilePath set to /var/run/homegear/
08/07/23 09:47:38.224 Debug: lockFilePathPermissions set to 504
08/07/23 09:47:38.224 Debug: lockFilePathUser set to homegear
08/07/23 09:47:38.224 Debug: lockFilePathGroup set to homegear
08/07/23 09:47:38.224 Debug: oauthCertPath set to /etc/homegear/homegear.crt
08/07/23 09:47:38.224 Debug: oauthKeyPath set to /etc/homegear/homegear.key
08/07/23 09:47:38.224 Debug: oauthTokenLifetime set to 3600
08/07/23 09:47:38.224 Debug: oauthRefreshTokenLifetime set to 5184000
08/07/23 09:47:38.224 Debug: enableHgdc set to 0
08/07/23 09:47:38.225 Debug: hgdcPort set to 2017
08/07/23 09:47:38.225 Debug: waitForCorrectTime set to 1
08/07/23 09:47:38.225 Debug: prioritizeThreads set to 1
08/07/23 09:47:38.225 Debug: secureMemorySize set to 65536
08/07/23 09:47:38.225 Debug: workerThreadWindow set to 3000
08/07/23 09:47:38.225 Debug: scriptEngineMaxThreadsPerScript set to 4
08/07/23 09:47:38.225 Debug: scriptEngineMaxScriptsPerProcess set to 250
08/07/23 09:47:38.225 Debug: scriptEngineThreadCount set to 50
08/07/23 09:47:38.225 Debug: scriptEngineServerMaxConnections set to 10
08/07/23 09:47:38.225 Debug: scriptEngineWatchdogTimeout set to 60000
08/07/23 09:47:38.225 Debug: scriptEngineManualClientStart set to 0
08/07/23 09:47:38.225 Debug: nodeBlueProcessingThreadCountServer set to 100
08/07/23 09:47:38.225 Debug: nodeBlueProcessingThreadCountNodes set to 10
08/07/23 09:47:38.225 Debug: nodeBlueServerMaxConnections set to 50
08/07/23 09:47:38.225 Debug: maxNodeThreadsPerProcess set to 1000
08/07/23 09:47:38.225 Debug: nodeBlueWatchdogTimeout set to 60000
08/07/23 09:47:38.225 Debug: nodeBlueManualClientStart set to 0
08/07/23 09:47:38.225 Debug: nodeRedPort set to 1999
08/07/23 09:47:38.226 Debug: nodeOptions set to --max_old_space_size=400
08/07/23 09:47:38.226 Debug: ipcThreadCount set to 10
08/07/23 09:47:38.226 Debug: ipsServerMaxConnections set to 50
08/07/23 09:47:38.226 Debug: cliServerMaxConnections set to 50
08/07/23 09:47:38.226 Debug: rpcServerMaxConnections set to 50
08/07/23 09:47:38.226 Debug: rpcServerThreadPriority set to 0
08/07/23 09:47:38.226 Debug: rpcServerThreadPolicy set to 0
08/07/23 09:47:38.226 Debug: rpcClientMaxThreads set to 50
08/07/23 09:47:38.226 Debug: rpcClientThreadPriority set to 0
08/07/23 09:47:38.226 Debug: rpcClientThreadPolicy set to 0
08/07/23 09:47:38.226 Debug: workerThreadPriority set to 0
08/07/23 09:47:38.226 Debug: workerThreadPolicy set to 0
08/07/23 09:47:38.226 Debug: physicalInterfaceThreadPriority set to 45
08/07/23 09:47:38.226 Debug: physicalInterfaceThreadPolicy set to 1
08/07/23 09:47:38.226 Debug: packetReceivedThreadPriority set to 0
08/07/23 09:47:38.226 Debug: packetReceivedThreadPolicy set to 0
08/07/23 09:47:42.232 Could not connect to socket. Error: No such file or directory
08/07/23 09:47:42.233 Could not connect to socket. Error: No such file or directory
homegear.err
08/07/23 09:46:02.077 Module HomeMatic BidCoS: COC "my-coc": Error in file PhysicalInterfaces/COC.cpp line 154 in function virtual void BidCoS::COC::startListening(): Failed to open value file for GPIO with index 1 and device "coc": Unable to retrieve path.
ls -la /dev/ttyAMA0
crw--w---- 1 homegear homegear 204, 64 May 13 12:37 /dev/ttyAMA0
Ich bekomme es leider nicht gelöst. Habt ihr einen Tipp?
Danke.
@sathya Ggf. irgendeine Idee. Danke.
