Error message with homegear admin
Hi
after login to the homegear admin using: http://lemonpi:2001/admin/
I see the following error message in the “homegear-scriptengine.err” file:
2018-11-11T11:07:20+01:00 [error] Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for “GET /css/bootstrap-colorpicker.min.css” (from "http://lemonpi:2001/admin/“)” at /var/lib/homegear/admin-ui/vendor/symfony/http-kernel/EventListener/RouterListener.php line 144
2018-11-11T11:10:24+01:00 [error] Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for “GET /css/bootstrap-colorpicker.min.css” (from "http://lemonpi:2001/admin/settings/users")" at /var/lib/homegear/admin-ui/vendor/symfony/http-kernel/EventListener/RouterListener.php line 144
2018-11-11T11:10:37+01:00 [error] Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for “GET /css/bootstrap-colorpicker.min.css” (from "http://lemonpi:2001/admin/maintenance/backups")" at /var/lib/homegear/admin-ui/vendor/symfony/http-kernel/EventListener/RouterListener.php line 144
the message appears everytime the main window gets refreshed.
so far I see no effect, but wonder what it means.
cheers
Wolfgang
Hi Wolfgang,
could you please try the UI using the IP-Address instead of the hostname? Just to prove …
Hi
looks the same:
2018-11-13T18:43:22+01:00 [error] Uncaught PHP Exception Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route found for “GET /css/bootstrap-colorpicker.min.css” (from "http://192.168.0.35:2001/admin/“)” at /var/lib/homegear/admin-ui/vendor/symfony/http-kernel/EventListener/RouterListener.php line 144
cheers
Should be fixed now.
thanks a lot
so far running the following versions:
homegear/stretch,now 0.7.30-1900 armhf [installed]
homegear-adminui/stretch,now 0.1.0-36 all [installed]
homegear-homematicbidcos/stretch,now 0.7.30-1900 armhf [installed]
homegear-management/stretch,now 0.7.30-1900 armhf [installed]
homegear-nodes-core/stretch,now 0.7.30-1900 armhf [installed]
libhomegear-base/stretch,now 0.7.30-1900 armhf [installed,automatic]
libhomegear-ipc/stretch,now 0.1.2-15 armhf [installed,automatic]
libhomegear-node/stretch,now 0.1.7-25 armhf [installed,automatic]
when will it be public available?
cheers
Hi
is there any update on this?
cheers
It is available in the nightlies. Since it is alpha currently, I don’t think it will be part of the stable version soon.
