Current repository installation fails
Hi all,
Trying to do a fresh repository install on the latest Raspbian Jessie Lite (2016-05-10) it fails for me. Partly I figured out the new CCU2 firmware link in the scripts and the temp directory causing issues, so I amended them to the latest firmware link
HM-CCU2%202.17.16/HM-CCU-2.17.16.tar.gz
and the temp directory to 174024608
This gets me a bit further now, but the install now fails at patching.
Any help would be greatly appreciated. Thanks
Extracting files to: /tmp/HomegearTemp/rootfs/rootfs.ubi/174024608/root patching file hmw_io_12_fm.xml patching file hmw_io12_sw14_dr.xml patching file hmw_io12_sw7_dr_V3_02.xml patching file hmw_io12_sw7_dr.xml patching file hmw_io_4_fm_V3_02.xml patching file hmw_io_4_fm.xml patching file hmw_io_sr_fm.xml patching file hmw_lc_bl1_dr_V3_02.xml patching file hmw_lc_bl1_dr.xml Hunk #2 succeeded at 34 (offset 5 lines). Hunk #3 succeeded at 94 (offset 5 lines). Hunk #4 succeeded at 135 (offset 5 lines). Hunk #5 succeeded at 204 (offset 5 lines). patching file hmw_lc_dim1l_dr.xml patching file hmw_lc_sw2_dr_V3_02.xml patching file hmw_lc_sw2_dr.xml patching file hmw_sen_sc_12_dr.xml patching file rf_4dis.xml patching file rf_ash550.xml patching file rf_bl_644.xml Hunk #1 FAILED at 1. 1 out of 4 hunks FAILED -- saving rejects to file rf_bl_644.xml.rej patching file rf_bl_conf_644_e_v2_0.xml patching file rf_bl_conf_644_e_v2_1.xml patching file rf_bl_conf_644.xml patching file rf_bl_le_v2_3.xml patching file rf_bl.xml patching file rf_cc_rt_dn_bom.xml patching file rf_cc_rt_dn.xml patching file rf_cc_tc_le_v1_9.xml patching file rf_cc_tc.xml patching file rf_cc_vd.xml patching file rf_central.xml patching file rf_cfm.xml patching file rf_cf.xml patching file rf_cm.xml patching file rf_ddc.xml patching file rf_dim_1l_644_le_v2_4.xml Hunk #2 succeeded at 72 with fuzz 2 (offset 16 lines). patching file rf_dim_1l_644.xml Hunk #2 succeeded at 86 with fuzz 2 (offset 8 lines). patching file rf_dim_1pwm_644_le_v2_4.xml Hunk #2 succeeded at 67 with fuzz 2 (offset 16 lines). patching file rf_dim_1pwm_644.xml Hunk #1 succeeded at 29 with fuzz 2 (offset 4 lines). Hunk #2 succeeded at 82 with fuzz 2 (offset 12 lines). patching file rf_dim_1t_644_le_v2_4.xml Hunk #2 succeeded at 77 with fuzz 2 (offset 16 lines). patching file rf_dim_1t_644.xml Hunk #2 succeeded at 94 with fuzz 2 (offset 8 lines). patching file rf_dim_1tconf_644_le_v2_4.xml Hunk #2 succeeded at 66 with fuzz 2 (offset 16 lines). patching file rf_dim_1tconf_644.xml Hunk #2 succeeded at 72 with fuzz 2 (offset 8 lines). patching file rf_dim_2l_644_le_v2_4.xml Hunk #2 succeeded at 67 with fuzz 2 (offset 16 lines). patching file rf_dim_2l_644.xml Hunk #2 succeeded at 78 with fuzz 2 (offset 8 lines). patching file rf_dim_2t_644_le_v2_4.xml Hunk #2 succeeded at 67 with fuzz 2 (offset 16 lines). patching file rf_dim_2t_644.xml Hunk #2 succeeded at 78 with fuzz 2 (offset 8 lines). patching file rf_dim_t_le_v1_9.xml Hunk #2 succeeded at 70 with fuzz 2 (offset 8 lines). patching file rf_dim_t.xml Hunk #2 succeeded at 78 with fuzz 2 (offset 8 lines). patching file rf_dis_wm55.xml patching file rf_d_le_v1_7.xml patching file rf_d_le_v1_9.xml Hunk #2 succeeded at 73 with fuzz 2 (offset 8 lines). patching file rf_d.xml Hunk #2 succeeded at 82 with fuzz 2 (offset 8 lines). patching file rf_em_8.xml patching file rf_es_pmsw_le_v2_4.xml patching file rf_es_pmsw.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 54 (offset 8 lines). Hunk #3 succeeded at 83 (offset 8 lines). Hunk #4 succeeded at 111 (offset 8 lines). Hunk #5 succeeded at 186 (offset 8 lines). Hunk #6 succeeded at 371 (offset 8 lines). 1 out of 6 hunks FAILED -- saving rejects to file rf_es_pmsw.xml.rej patching file rf_es_tx_wm.xml Hunk #1 succeeded at 77 with fuzz 2 (offset 67 lines). Hunk #2 succeeded at 168 with fuzz 1 (offset 97 lines). patching file rf_fs_ba.xml patching file rf_keymatic.xml patching file rf_ks550.xml patching file rf_ou_led16_ge_v1_1.xml patching file rf_ou_led16_le_v1_0.xml patching file rf_pb-2-wm55_ge_v1_4.xml patching file rf_pb-2-wm55_le_v1_3.xml patching file rf_pb-2.xml Hunk #2 succeeded at 66 with fuzz 1. patching file rf_pbi.xml patching file rf_rc_12.xml patching file rf_rc_19.xml patching file rf_rc-4-2.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 19 (offset 3 lines). Hunk #3 succeeded at 64 (offset 3 lines). Hunk #4 succeeded at 150 (offset 3 lines). 1 out of 4 hunks FAILED -- saving rejects to file rf_rc-4-2.xml.rej patching file rf_rc-key4-2.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 13 (offset 3 lines). Hunk #3 succeeded at 58 (offset 3 lines). Hunk #4 succeeded at 128 (offset 3 lines). Hunk #5 succeeded at 163 (offset 3 lines). 1 out of 5 hunks FAILED -- saving rejects to file rf_rc-key4-2.xml.rej patching file rf_rc-sec4-2.xml Hunk #2 succeeded at 14 (offset 3 lines). Hunk #3 succeeded at 59 (offset 3 lines). Hunk #4 succeeded at 129 (offset 3 lines). Hunk #5 succeeded at 164 (offset 3 lines). patching file rf_rc_single_on.xml patching file rf_rc.xml patching file rf_rd_le_v1_3.xml patching file rf_rd.xml patching file rf_rep.xml patching file rf_resc_win_pcb_sc.xml patching file rf_rhs_e_v1_7.xml patching file rf_rhs_le_v1_6.xml patching file rf_rhs.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 33 (offset 4 lines). Hunk #3 succeeded at 86 (offset 4 lines). Hunk #4 succeeded at 130 (offset 4 lines). Hunk #5 succeeded at 144 (offset 4 lines). 1 out of 5 hunks FAILED -- saving rejects to file rf_rhs.xml.rej patching file rf_roto_wdf_solar.xml patching file rf_s_1conf_644_le_v2_1.xml patching file rf_s_1conf_644_le_v2_3.xml patching file rf_s_1conf_644.xml Hunk #1 FAILED at 1. 1 out of 4 hunks FAILED -- saving rejects to file rf_s_1conf_644.xml.rej patching file rf_s_4_ba.xml patching file rf_s550ia.xml patching file rf_s_644.xml Hunk #1 succeeded at 97 (offset 24 lines). Hunk #2 succeeded at 154 (offset 24 lines). patching file rf_s_8_ba.xml patching file rf_s_ba.xml patching file rf_scd_v1_0.xml patching file rf_sc_e_v1_7.xml patching file rf_sci_3.xml patching file rf_sc_le_v1_6.xml patching file rf_sc.xml patching file rf_sec_mdir_v1_5.xml patching file rf_sec_mdir.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 29 (offset 4 lines). Hunk #3 succeeded at 98 (offset 4 lines). Hunk #4 succeeded at 154 (offset 4 lines). 1 out of 4 hunks FAILED -- saving rejects to file rf_sec_mdir.xml.rej patching file rf_sec_sco.xml patching file rf_sec_sd_schueco.xml patching file rf_sec_sd.xml patching file rf_sec_sfa.xml patching file rf_sen_db.xml patching file rf_sen_ep.xml patching file rf_sen_mdir_v1_5.xml patching file rf_sen_mdir_wm55.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 18 with fuzz 2 (offset 4 lines). Hunk #3 succeeded at 105 (offset 4 lines). Hunk #4 succeeded at 298 (offset 4 lines). 1 out of 4 hunks FAILED -- saving rejects to file rf_sen_mdir_wm55.xml.rej patching file rf_sen_mdir.xml patching file rf_sen_wa_od.xml patching file rf_s_le_v1_5.xml patching file rf_s_le_v2_3.xml patching file rf_s_mega168.xml patching file rf_swi.xml patching file rf_s.xml Hunk #1 FAILED at 1. 1 out of 5 hunks FAILED -- saving rejects to file rf_s.xml.rej patching file rf_tc_it_wm-w-eu.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 2897 (offset -5 lines). Hunk #3 succeeded at 2948 (offset -5 lines). Hunk #4 succeeded at 2999 (offset -5 lines). Hunk #5 succeeded at 3059 (offset -5 lines). Hunk #6 succeeded at 3094 (offset -5 lines). Hunk #7 succeeded at 3312 (offset 8 lines). 1 out of 7 hunks FAILED -- saving rejects to file rf_tc_it_wm-w-eu.xml.rej patching file rf_tis_le_v1_0.xml patching file rf_tis.xml patching file rf_wds30_ot2.xml Hunk #1 FAILED at 1. Hunk #2 succeeded at 31 with fuzz 2 (offset 3 lines). Hunk #3 succeeded at 76 with fuzz 2 (offset 11 lines). Hunk #4 succeeded at 91 (offset 11 lines). Hunk #5 succeeded at 120 (offset 11 lines). Hunk #6 succeeded at 140 (offset 11 lines). 1 out of 6 hunks FAILED -- saving rejects to file rf_wds30_ot2.xml.rej patching file rf_wds40_th_i_2.xml patching file rf_wds_v1_0.xml patching file rf_wds_v1_1.xml patching file rf_winmatic.xml patching file rf_ws550.xml dpkg: error processing package homegear (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: homegear E: Sub-process /usr/bin/dpkg returned an error code (1)
Hey,
I will update the repository to 0.6 the next days. Until then, install the 0.6 packages manually.
Cheers,
Thanks Sathya.
