CUL was disconnected
Moin,
ich bin von einem Raspberry-System auf dem homegear direkt installiert war auf eine Docker-Lösung umgestiegen.
ich nutze homegear Version 0.9.1-3672
Ich empfange Daten über die CUL, jedoch erhalte ich eine Fehlermeldung wenn ich Werte schicke, siehe Logfile mit dem Zeitstempel 05/01/25 16:58:20.030
Freue mich über Eure Hinweise
LOGFILE
05/01/25 16:58:17.317 RPC Server (Port 2001): Info: Client number 21 is calling RPC method: listBidcosInterfaces (2) Parameters:
05/01/25 16:58:17.798 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
05/01/25 16:58:17.798 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 4). Retrying…
05/01/25 16:58:17.898 Module HomeMatic BidCoS: CUL “My-CUL”: Info: Sending (My-CUL): 0EEDA011FD028B32469A0203000000
05/01/25 16:58:18.119 Module HomeMatic BidCoS: CUL “My-CUL”: Info: Sending (My-CUL): 0EEDA011FD028B32469A0203000000
05/01/25 16:58:18.319 Module HomeMatic BidCoS: CUL “My-CUL”: Info: Sending (My-CUL): 0EEDA011FD028B32469A0203000000
05/01/25 16:58:20.030 Module HomeMatic BidCoS: CUL “My-CUL”: CUL was disconnected.
05/01/25 16:58:20.030 Module HomeMatic BidCoS: CUL “My-CUL”: Couldn’t read from CUL device, because the file descriptor is not valid: /dev/ttyACM0. Trying to reopen…
05/01/25 16:58:20.904 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
05/01/25 16:58:20.904 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 4). Retrying…
05/01/25 16:58:21.004 Module HomeMatic BidCoS: CUL “My-CUL”: Warning: !!!Not!!! sending packet, because device is not connected or opened: 0EEDA011FD028B32469A0203000000
05/01/25 16:58:24.010 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
05/01/25 16:58:24.010 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 4). Retrying…
05/01/25 16:58:24.110 Module HomeMatic BidCoS: CUL “My-CUL”: Warning: !!!Not!!! sending packet, because device is not connected or opened: 0EEDA011FD028B32469A0203000000
05/01/25 16:58:27.117 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
05/01/25 16:58:27.118 Info: Peer 4 is unreachable.
05/01/25 17:00:48.193 Module HomeMatic BidCoS: Info: 05/01/25 17:00:48.193 Packet received (My-CUL, RSSI: -75 dBm): 0E95841035DF750000000BA8D80A00
05/01/25 17:00:48.194 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 2 of HomeMatic BidCoS peer 2 with serial number LEQ1463879 was set to 0x00D8.
05/01/25 17:00:48.194 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 2 of HomeMatic BidCoS peer 2 with serial number LEQ1463879 was set to 0x0A.
05/01/25 17:00:48.194 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 2 of HomeMatic BidCoS peer 2 with serial number LEQ1463879 was set to 0x00.
Aufruf Docker:
docker run
-d
–name=‘homegear’
–net=‘br0’
–ip=‘xxx.xxx.xxx.xxx’
–pids-limit 2048
–privileged=true
-e TZ=“Europe/Berlin”
-e HOST_OS="?"
-e HOST_HOSTNAME="?"
-e HOST_CONTAINERNAME=“homegear”
-e ‘TZ’=‘Europe/Berlin’
-e ‘HOST_USER_ID’=’$(id -u)’
-e ‘HOST_USER_GID’=’$(id -g)’
-e ‘TCP_PORT_8081’=‘8080’
-e ‘TCP_PORT_8443’=‘8443’
-e ‘TCP_PORT_2001’=‘2001’
-e ‘TCP_PORT_2002’=‘2002’
-e ‘TCP_PORT_2003’=‘2003’
-l net.unraid.docker.managed=dockerman
-v ‘/mnt/user/homegear-data/etc/’:’/etc/homegear’:‘rw’
-v ‘/mnt/user/homegear-data/lib/’:’/var/lib/homegear’:‘rw’
-v ‘/mnt/user/homegear-data/log/’:’/var/log/homegear’:‘rw’
–device=’/dev/ttyACM0’ ‘homegear/homegear:stable’
2ac47f472d499eb75d3a82de6c11821b185ebe0421c08195600edd9aecf96d81
The command finished successfully!
Also aus dem Log oben geht nicht hervor das du Daten über den CUL empfängst.
Problem ist aber:
Sicher das der CUL unter ttyACM0 erreichbar ist?
Servus,
Ich habe die Information die mit dem Zeitstempel “05/01/25 17:00:48.193” und später ausgegeben werden als empfangene Daten interpretieren.
Die Bezeichnungen der Devices entspricht auch denen die ich sehe, wenn ich innerhalb des Dockers “home gear -r” aufrufe und mir die Teilnehmer in die BidCos Gruppe anzeigen lasse.
Falls ich das falsch sehe so würde ich mich über weitere Informationen freuen
Die Daten ank habe ich wie im Doku-Bereich von homegear.eu übertragen
