Could not acquire lock for sending packet
erhalte in letzter Zeit vermehrt folgende Meldung:
“Could not acquire lock for sending packet”
Es werden dann keinerlei Pakete mehr empfangen und nur sporadisch versendet. Ein Neustart von Homegear löst das Problem.
06/27/17 12:13:56.702 Module HomeMatic BidCoS: TI CC110X "CC1101": Warning: Too large packet received: 0FD32F09D7283AEBE677522F0BE7CEF08D94CE8D4B94F1A6CFE71A4E6856FB032E6C12CED2D5F5A924E54E891F72067C7E7B4D0D365F40F0DD345A3D1E8C3CC9E4D32F09D7283AEBE677522F0BE7CEF08D94CE8D4B94F1A6CFE71A4E6856FB032E6C12CED2D5F5A924E54E891F72067C7E7B4D0D365F40F0DD345A3D1E8C3CC9C9E4D32F09D7283AEBE677522F0B
06/27/17 12:13:56.703 Module HomeMatic BidCoS: TI CC110X "CC1101": Connection to TI CC1101 closed unexpectedly... Trying to reconnect...
06/27/17 12:13:59.080 Module HomeMatic BidCoS: TI CC110X "CC1101": Info: Sending (CC1101): 0E13A011FD21B534C29C0201000000 Planned sending time: 06/27/17 12:13:56.255
06/27/17 12:13:59.179 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
06/27/17 12:13:59.179 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 25). Retrying...
06/27/17 12:13:59.380 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
06/27/17 12:13:59.380 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 12). Retrying...
06/27/17 12:14:01.084 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
06/27/17 12:14:01.084 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 24). Retrying...
06/27/17 12:14:09.180 Module HomeMatic BidCoS: TI CC110X "CC1101": Critical: Could not acquire lock for sending packet. This should never happen. Please report this error.
06/27/17 12:14:09.180 Module HomeMatic BidCoS: TI CC110X "CC1101": Warning: Timing problem. Sending took more than 100ms. Do you have enough system resources?
Hat jemand Ideen?
Hallo @vctender,
das zu lange Paket sorgt für ein Neuverbinden. Die Frage ist, warum das nicht klappt. Ich habe das Limit für zu lange Pakete mal erhöht. Schau mal, ob es mit dem nächsten Nightly besser klappt.
der Orange PI macht immer mal Probleme. Mit etwas frickeln bin ich auf den Vanilla-Kernel (4er) umgestiegen, dort scheint der Durchsatz vom SPI besser zu sein. Ich vermute mal, dass er einige Signalwechsel nicht erkannt hat und dann in der SPI-Kommunikation stecken bleibt.
