Hello Homegear Team/Developers,
I have got a spontaneous coredump received today morning.
I do not have anything special what could be the reason since I am using it since long time and no any previous dump is observed earlier.
This the last few messages prior to the coredump event is observed:
10/20/21 06:36:09.639 MAX packet received (nanoCUL, RSSI: 0x4C): 0E960202140EF5FD294200011B002A
10/20/21 06:36:09.646 Module MAX: Info: LOCKED on channel 1 of peer 8 with serial number MEQ1459638 was set to 0x00.
10/20/21 06:36:09.646 Module MAX: Info: SET_TEMPERATURE on channel 1 of peer 8 with serial number MEQ1459638 was set to 0x2A.
10/20/21 06:36:09.646 Module MAX: Info: VALVE_STATE on channel 1 of peer 8 with serial number MEQ1459638 was set to 0x00.
10/20/21 06:36:09.646 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/7/1/SET_TEMPERATURE
10/20/21 06:36:09.647 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/7/1/VALVE_STATE
10/20/21 06:36:09.647 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/0/RSSI_DEVICE
10/20/21 06:36:09.648 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/0/LOWBAT
10/20/21 06:36:09.678 Module MAX: CUL "nanoCUL": Info: Sending (nanoCUL, WOR: no): 0B960002FD2942140EF50000
10/20/21 06:36:09.679 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/1/LOCKED
10/20/21 06:36:09.680 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/1/SET_TEMPERATURE
10/20/21 06:36:09.680 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/1/VALVE_STATE
10/20/21 06:36:09.744 Module MAX: CUL "nanoCUL": Info: Sending (nanoCUL, WOR: yes): 0B960540FD2942140EF501EA
10/20/21 06:36:10.839 MAX packet received (nanoCUL, RSSI: 0x4B): 0E960202140EF5FD294200011B002A
10/20/21 06:36:10.839 Module MAX: Info: Queue 4547 is empty and there are no pending queues.
10/20/21 06:36:10.848 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/1/CONTROL_MODE
10/20/21 06:36:10.848 MQTT Client: Info: MQTT RPC call received. Method: setValue
10/20/21 06:36:10.848 RPC Server (Port 2001): Info: RPC Method called: setValue Parameters:
(Integer) 5
(Integer) 1
(String) CONTROL_MODE
(Integer) 3
10/20/21 06:36:10.878 Module MAX: CUL "nanoCUL": Info: Sending (nanoCUL, WOR: no): 0B970540FD2942140EF5016A
10/20/21 06:36:10.889 MQTT Client: MQTT Client Info: Publishing topic: hg/5756nc/plain/8/1/CONTROL_MODE
10/20/21 06:36:10.949 Module MAX: CUL "nanoCUL": Info: Sending (nanoCUL, WOR: yes): 0BAA0540FD29421AC12E01EA
10/20/21 06:36:10.967 MAX packet received (nanoCUL, RSSI: 0x4A): 0E970202140EF5FD2942000119172A
10/20/21 08:54:06.477 Starting Homegear...
10/20/21 08:54:06.477 Homegear version: 0.7.48-3324
Here are the logs and the core file:
- Could you kindly have a look into the details what could be the reason for that?
Anything else you might need for further checking kindly let me know and I will provide it for you.
Thanks a lot in advance
Regards
Tamás
