first of all I would like to thank you for this wonderful project, which makes HomeMatic a usable hardware!
We are doing first tests, and found out the only problem so far: wired devices that have configurable inputs/outputs do not return “State” variables.
HMW-IO-12-FM
If I change behavior to value 0 (INPUT), it works properly.
HMW-IO-12-Sw14-DR
On this device, only outputs that are non-configurable work properly (6 relay outputs).
However Channels 7-14, that are of string type DIGITAL_ANALOG_OUTPUT, do not have “State” variable when switched to Config -> Behaviour -> Value 1 (DIGITAL_OUTPUT).
Do you have any idea what might be the problem?
We can send devices for testing.
Best regards,
Martin
